Flarm Butterfly display
Old May 6th 13, 06:40 PM posted to rec.aviation.soaring
Andy[_1_]
Default Flarm Butterfly display
The larger font of 3.1 also has an issue in landscape mode. The data block for the selected target is shown in the upper right of the display. When the selected target is no longer received the residue of the left side of the target data remains displayed after the data block is removed. It appears that the "clear area" specification was not updated to correspond to the larger font size.
Result is an block of garbage at 2 o'clock on the outer range ring. It goes away when the target is deselected.
Andy
Power Flarm Display SteveB_Z5 Soaring 64 March 25th 13 09:17 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 01:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 08:20 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 10:00 PM
Best PDA/PNA for FLARM display? Frank Paynter[_2_] Soaring 14 August 28th 11 10:24 AM
