Flight Computer Input Devices
Old February 28th 14, 05:16 PM posted to rec.aviation.soaring
Mike the Strike
Default Flight Computer Input Devices
I was leaning towards the ClearNav/LX approach of buttons rather than the trackball, although I believe both are quite workable. I currently use an Oudie and have had problems in rough air with the touchscreen.
The LX 9000 does look most interesting, but would be a lot more attractive if the Euro was at 0.8 to the US dollar instead of 1.35! The idea of putting the computer on a RAM mount within easy reach wasn't an idea I had originally considered, but might actually be viable.
I wonder how many here have taken that approach?
Mike
Old February 28th 14, 05:50 PM posted to rec.aviation.soaring
Renny[_2_]
Mike
Mike,
I just installed an LX9000 on a RAM mount over the winter in my LAK and it seems to be working out just fine. You can see the photos on the Cumulus Soaring website.
It is very easy to reach and control and I am very confident that it will work out great during the coming soaring season at Moriarty. Once I have a few flights under my belt with this set-up, I'll provide an update on RAS.
Thx - Renny
son_of_flubber
I recall that Frank Paynter mentioned in his Soaring Cafe account that he had his Clear Nav on a RAM mount when he crashed. It abruptly detached. Subsequent trajectory unknown. A short well-anchored leash might make sense.
Old February 28th 14, 11:21 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Mike
Dunno whether this helps, but I have a PNA running LK8000 on a RAM Flex-
mount. That works for me. However, I fly in fairly non-turbulent
conditions and find that resting some fingers on the edge of the PNA
while prodding it with thumb or index finger helps a lot.
Of course, the thing that helps most of all is the ability of LK8000 and
XCSoar to let you fly a task without any pilot inputs provided, of
course, that conditions are good enough to complete the task without
needing to abandon any TPs.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 28th 14, 11:27 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Mike
I have had CN on a ram mount for two seasons... no issues, works great, solid as the proverbial rock (lotsa ridge flying). The tunnel or behind panel mounts are prettier, but the ram mount allowed me to keep all my antique 80mm gauges. Hit me up if you have any CN questions or browse our forum for more info.
Evan Ludeman for CNi
Old March 1st 14, 12:14 AM posted to rec.aviation.soaring
Craig Funston[_2_]
Mike
org |
The lovely thing about LK8000 is that for most flying you just need to touch in large zones rather than try to hit buttons. It works well, even in turbulence.
Craig
7Q
Old March 1st 14, 02:39 AM posted to rec.aviation.soaring
On Fri, 28 Feb 2014 15:14:33 -0800, Craig Funston wrote:
And, hopefully, almost all prodding it will ever need in flight involves
simply tapping the top left screen corner to dial round the list of TPs,
HOME and the 1st and 2nd nearest alternate landout fields.
org |
Old March 1st 14, 02:51 AM posted to rec.aviation.soaring
The key is not requiring 'precise' touchpad control. A touchpad is no problem if the buttons are big enough.
And for those who have never seen an aircraft trackball. They have a grip that the fingers grab while you use the thumb or another finger to move the trackball. At least the ones that I have seen ( but never used ) are like that.
Old March 1st 14, 06:46 AM posted to rec.aviation.soaring
I can't stand touch screens even when sitting still on the ground with nothing else needing my attention. Just a personal thing. Too bad as otherwise I could have upgraded my avionics during the PowerFLARM install for a LOT less money.
Old March 2nd 14, 03:04 AM posted to rec.aviation.soaring
K
Mike
This is not a paid advertisement . I just came from the convention and I horsed around with the Craggy Ultimate and a trackball. Thought Id not like it but I actually found it VERY easy to use and I did spend some time on it. I am a SYM man myself but I understand you have a choice of software with the ultimate (Unlike some of the others).
Zander ZS 1 Flight Computer [email protected] Soaring 1 July 28th 13 07:48 AM
Loading flight data to iPhone from serial port devices Craig Funston Soaring 5 July 25th 11 09:09 PM
Glider flight software on non PDA devices- soon. brianDG303 Soaring 23 November 19th 08 01:30 AM
Flight computer for Sale [email protected] Piloting 0 August 20th 05 07:12 PM
Zander 820 Flight COmputer Dave Kuchenbecker Soaring 0 May 7th 04 03:27 AM
