Split Scimitar Winglets
Old January 15th 15, 07:56 PM posted to rec.aviation.soaring
Default Split Scimitar Winglets
On a very large Biz Jet costing lord knows how much, adding some BS stuff sometimes helps the sale, especially with promises that it will go further, better, at less cost Sir -- honest it will. But no guarantees of course.
When Southwest adds them to its 37 fleet you will know they actually work, not before.
I'm sure I'm way behind on this, but yesterday I flew on a new 737-800 with "Split Scimitar" winglets. One airline claimed 3% fuel savings. That seems optimistic to me, but every little bit helps. Is anybody working on adaptations for gliders?
SF
Old January 15th 15, 08:47 PM posted to rec.aviation.soaring
Saw them on an SWA airplane in Dallas last week.
Old January 15th 15, 08:50 PM posted to rec.aviation.soaring
Papa3[_2_]
SW was a launch customer...
SF
Old January 15th 15, 09:22 PM posted to rec.aviation.soaring
Papa3[_2_]
http://aviationblog.dallasnews.com/2...airplane.html/
Old January 16th 15, 12:18 AM posted to rec.aviation.soaring
Ron Gleason
A friend flies for SW and he says they make cross wind landings a bit trickier as it is harder to hold the crab angle. Plus no one want to the first one to damage the $1mil+ winglets by scraping them on the ground
Old January 16th 15, 01:10 PM posted to rec.aviation.soaring
I started the split scimitar discussion as a bit of a joke, but as noted, when SWA is on board, this is serious.
I think that adapting SS winglets to gliders will require "retractability" for takeoffs or landings or we will be spending a lot of time and money repairing the fancy things. I'm sure someone with extensive modeling time can come up with a battery-powered RC motor that could lower the bottom blade after release and raise it before landing. Now all we need is someone from API to allow access to their patented technology so we can shape the new tips appropriately. (I knew I should have kept my wind tunnel.)
SF (Only sort of tongue-in-cheek)
Old January 16th 15, 02:42 PM posted to rec.aviation.soaring
Prior art: Peter Masak built and flew a set of similar split winglets over 20 years ago for his Nimbus.
Imagine- a landing gear position interlock that raises your hangie down things when the gear is down.
Before all this exotic and questionable "art" is applied to a glider, it would pay to have the best single element winglet. Many ships have winglets with significant improvement potential.
UH
Old January 16th 15, 06:45 PM posted to rec.aviation.soaring
Dan Marotta
....Or raise the lowers ala the Slingsby Vega tail wheel with a
mechanical linkage. Of course, it should be simple to make the linkage
connect automagically during assembly. Is it April 1 yet?
UH
Dan Marotta
Old January 16th 15, 07:32 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Wednesday, January 14, 2015 at 9:37:47 AM UTC-8, wrote:
SF
3% compared to no winglets or compared to previously used winglets?
Hmmmmmm
UH
"Each traditional pair of winglets on the 737 cuts fuel consumption by 3.5% to 4% on flights of more than 1,000 nautical miles. The split scimitar upgrade--which costs $545,000, before discounts-will reduce fuel burn by up to 2% more, says United, which hopes to save up to $60 million a year because of the devices, once its fleet is outfitted."
Old January 16th 15, 09:07 PM posted to rec.aviation.soaring
KN
mechanical linkage.* Of course, it should be simple to make the
linkage connect automagically during assembly.* Is it April 1 yet?
I thought it would make a good wing tip skid or with a small wheel fitted , a wing tip wheel, no?
Khanh
UH
Dan Marotta
Fleet Air Arm, Part 3 - faa30-Scimitar.jpg (1/1) [74K] Netko Aviation Photos 0 March 14th 11 06:51 PM
Fleet Air Arm, Part 2 - faa16-Scimitar.jpg (1/1) [97K] Netko Aviation Photos 0 March 13th 11 12:24 PM
MD-80 split elevators tscottme[_2_] Instrument Flight Rules 3 June 29th 08 07:24 PM
Scimitar Pjmac35 Aviation Photos 0 July 26th 07 11:37 PM
scimitar propeler Philippe Home Built 12 January 23rd 05 05:51 AM
