Task Planning Software
Old January 19th 16, 12:24 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Task Planning Software
Was wondering if anyone could recommend a task planning program or excel file, that I could use to plan tasks i.e., FAI triangles, etc. Western USA with emphasis on CA, NV, UT.
Old January 19th 16, 01:07 AM posted to rec.aviation.soaring
waremark
In the UK Naviter's SeeYou is pretty much regarded as the gold standard for task planning, flight analysis, management of flight computer files, and communication with electronic instruments. It is not free, but does not cost much and I consider it worth supporting professional software developers for the support they in turn give the sport.
Old January 19th 16, 04:05 AM posted to rec.aviation.soaring
Matt Herron Jr.
Glideplan can also be used.
Old January 19th 16, 05:43 AM posted to rec.aviation.soaring
Larry Suter
+1 on Glideplan
Larry
Old January 19th 16, 07:24 AM posted to rec.aviation.soaring
Surge
You can do task planning online for free at http://www.prosoar.de/
Load a custom way point file, click on the map and build your FAI triangle.
You can change the turn point types as well.
Then export the task to XCSoar or SeeYou (it even supports QR codes so you don't even need to copy any files).
Old January 19th 16, 11:13 AM posted to rec.aviation.soaring
Surge
FYI:
The proSoar code running on the http://www.prosoar.de/ website is a bit fussy about the way point file format.
If you're using SeeYou cup files and they won't load, check that there is a valid elevation for the turn points. I added "0m" to the turn points in my way point file to fix the problem.
Old January 19th 16, 11:35 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I use a combination of SPINE and NOTAMPlot - the latter because its
screen is less cluttered than SPINE. Either is good for setting up the
task once you've checked weather (I use Avbrief + RASP for that), and
SPINE lets me download plottable NOTAMS in OpenAir format for use by
LK8000. However, this combo is unlikely to be useful outside the UK: both
programs use BGA turnpoints and UK NOTAM sources and don't appear to be
configurable for other data sources. Both are free programs.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 19th 16, 02:42 PM posted to rec.aviation.soaring
Casey[_2_]
org |
Martin,
NOTAM Plot is neat. One can select different types of flying sites like HG tow sites which the ones in the US are long enough to land a glider in. And the soaring forecast is nice too. Too bad NOTAM Plot is not available for US pilots.
Old January 19th 16, 04:19 PM posted to rec.aviation.soaring
Don Grillo[_2_]
I use SeeYou. You can create hundreds of tasks and then sort them by distance or name. If you have a MFD (ex. LXNav 9050) that accepts the file you can load all your created tasks into it then select the task you want to fly (on the fly).
You can also load all igc files into SeeYou and watch your days flight with stunning detail. If you load your fellow competitors igc files into it as well you will see everyone's flight. It's worth the yearly subscription fee.
Don
F2
Old January 19th 16, 10:15 PM posted to rec.aviation.soaring
Dan Marotta
XCSoar
Dan, 5J
Handicap Task Software Jim White[_3_] Soaring 2 March 28th 14 06:24 PM
Paragliding task score software [email protected] Soaring 5 July 12th 12 03:08 PM
$10 Flight Planning Software [email protected] General Aviation 0 February 15th 07 07:56 PM
$10 Flight Planning Software [email protected] Aviation Marketplace 0 February 15th 07 07:55 PM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 05:12 PM
