Schweitzer tow hook rubber
Old August 8th 16, 11:24 PM posted to rec.aviation.soaring
Neil Muxworthy
Default Schweitzer tow hook rubber
Anyone know of a good source to order the black rubber piece that is part
of
the Schweitzer tow hook?
Old August 9th 16, 12:43 AM posted to rec.aviation.soaring
of
Look at McMaster Carr supply. They have a large variety of rubber products. You will find the rubber you need for your Schweizer(no t) hook.
Good luck
UH
Old August 9th 16, 01:34 AM posted to rec.aviation.soaring
Casey[_2_]
http://www.klsoaring.com/index.php?o...id=15&Itemid=8
Old August 9th 16, 05:38 AM posted to rec.aviation.soaring
Stephen Damon
Buy the right stuff from K and L , along with the bolt and nut and spacer. Why risk incorrect strength hardness rubber that cost nothing compared to a incorrect made jury rigged part!!!!
Old August 9th 16, 11:56 AM posted to rec.aviation.soaring
Cookie
There is no "t" in Schweizer!
of
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 11:40 PM
Schweitzer Sailplanes: Still In Business ? Robert11[_2_] Piloting 4 April 29th 09 06:26 AM
Manual for Schweitzer 2-32 Daniel L. Lieberman Soaring 24 November 25th 06 09:20 PM
Schweitzer Sailplane Logbook? jcarlyle Soaring 1 February 15th 06 07:40 PM
Schweitzer 2-33A Weights? Scott Soaring 2 August 22nd 04 11:12 PM
