Stupid hp to thrust question
Old December 5th 03, 02:24 AM
Mark
Default Stupid hp to thrust question
Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a
prop spinning 2300 rpm on a 100 hp motor ?
Old December 5th 03, 02:48 AM
Larry Smith
"Mark" wrote in message
a
I'm no authority on the subject, mind you, but it seems you get more thrust
from the more powerful engine because it will turn a prop with more pitch,
thus moves more air, thus more bite. Thus more thrust.
Old December 5th 03, 02:49 AM
RR Urban
Theoretically speaking -
If the props are identical....
so is the thrust on the test stand.
Barnyard BOb --
If I'm wrong, never mind.
Old December 5th 03, 02:51 AM
Stu Fields
Assuming both engines are producing the same torque at that rpm, then yes.
Torque x RPM = horsepower. Note: the props will not be both the same
diameter and pitch.
Stu Fields
"RR Urban" wrote in message
a
Barnyard BOb --
Old December 5th 03, 03:30 AM
Del Rawlins
On 04 Dec 2003 04:24 PM, Mark posted the following:
than a prop spinning 2300 rpm on a 100 hp motor ?
Yes, unless the 150hp motor is an automotive engine, in which case
bolting a prop to it will cause it to violently self destruct before
reaching 2300rpm. 8^P
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old December 5th 03, 03:33 AM
Ernest Christley
Assuming the same prop on both engines, then no.
A spinning prop produces thrust by throwing air backwards. Based upon
pitch, diameter and airfoil design, a given prop can throw a given
amount of air at a given RPM. It takes a specific amount of power for
the prop to do that.
If the 150hp motor is at full throttle, then the 100hp motor won't be
able to turn the prop at 2300. If the 100hp can turn at 2300, then a
150hp engine will be under-propped with that propeller and will easily
redline (either that or the 150hp engine isn't producing 100hp).
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old December 5th 03, 04:04 AM
Gilan
people sure like to over think things. The same prop can be put on any
engine of any horse power and if it is turned 2300 rpm then the thrust is
the same.
Have a good day and stay out of the trees!
See ya on Sport Aircraft group
http://groups.yahoo.com/group/Sport_Aircraft/
Flying Gators annual Fly-in
http://www.mitchellwing.com/flying_g...annual_fly.htm
Old December 5th 03, 04:21 AM
Richard Isakson
"Gilan" wrote ...
the same.
Not necessarily. If one of the engines has a larger frontal area then part
of the flow will be blocked and that engine/prop will produce less thrust.
The extreme example is the engine that's larger than the prop diameter.
Rich
Old December 5th 03, 04:22 AM
Gilan
there you go thinking again.
you just added something into the question that wasn't there
Just stick to the original question and the answer is still the same.
Old December 5th 03, 04:45 AM
ChuckSlusarczyk
In article , Mark says...
If it's the same prop and it turns 2300 on a 150 hp engine the 100hp engine
won't have the power to turn it 2300. If it turns 2300 on the 100 hp engine then
the 150 hp engine will over rev it and run away the prop. At 2300 rpm the prop
will produce the same thrust regardless of engine but the 150 hp engine would
really like a bigger prop to use the remaining 50 hp.
see ya Chuck (ain't no free ride in airplanes) S
Stupid super cub question Robert Loer Home Built 9 November 22nd 03 06:28 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
question about EZRocket David O Home Built 6 October 1st 03 07:03 PM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 04:20 AM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 12:07 PM
