Do the RAF really want the A400m?
Old August 25th 04, 04:04 PM
Prowlus
Default Do the RAF really want the A400m?
Just curious really, wouldn't going from a fast tactical jet transport
(c-17) to a slower prop transport be like swapping a stallion for a
mule to the RAF?
Old August 25th 04, 04:10 PM
Keith Willshaw
"Prowlus" wrote in message
om...
mule to the RAF?
They want both, the A-400 is intended to replace the
Hercules C-130K's not the C-17
Keith
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Old August 25th 04, 06:33 PM
John Penta
On Wed, 25 Aug 2004 15:10:40 +0100, "Keith Willshaw"
Yabbut ain't C17 meant (by design anyhow) to replace C130?
Old August 25th 04, 09:24 PM
Keith Willshaw
"John Penta" wrote in message
Not really , the C-17 is seen as the strategic airlift component
bringing troops and supplies into the theare with the C-130
operating in the tactical role shuttling men and materials to
the battlefield.
Keith
Old August 26th 04, 04:05 AM
Lyle
On Wed, 25 Aug 2004 20:24:58 +0100, "Keith Willshaw"
C-17 is meant to replace the C-141
the battlefield.
Keith
Old August 26th 04, 04:42 AM
Brett
The last C-141C will be retired to Davis-Montham AFB by the end of 2006, so
the remark should be: the designated C-141 replacement will be the C-17.
Old August 26th 04, 05:16 AM
Bob Coe
The C-17 isn't really a C-141 replacement. The 141 was/is a strategic airlift
aircraft. The C-130 and C-17 are designed for tactical airlift, but the C-17
fulfills the strategic role well enough, that it is considered dual purpose. It can
launch from a major airfield, and land on unimproved runways in the battle zone.
I believe, like the YC-14 and YC-15, the major goal was to be able to carry an
M-1 tank that could roll off. The rest is just fluff.
Old August 26th 04, 06:01 AM
Kevin Brooks
"Bob Coe" wrote in message
news:8CcXc.14360$ni.13641@okepread01...
so
airlift
C-17
purpose. It can
zone.
Uhmmm...no, not exactly. The C-17 is indeed a strategic airlifter first and
foremost, albeit one intended to have tactical capabilities that surpass
those of its predecessor the C-141, and has been since its outset. Unlike
previous aircraft used by the US in the strategic role, it is better suited
to handling unimproved/short runways and can therefore often move equipment
further into the A/O than its predecessors, and it was intended to replace
the C-141 in service (note that it is the C-141 units that have been sending
their birds to AMARC and reequipping with the C-17). Like the Starlifter, it
can also deliver tactical forces directly into battle (as it did with the
173rd BCT (Abn) during OIF), and it will soon manifest itself in a special
operations low level (SOLL) variant to replace that capability lost as the
existing C-141 SOLL's hit the boneyard.
carry an
Your "fluff" is a bit off, I am afraid. The YC-14 and YC-15 were never
intended to be able to carry main battle tanks, which is why the AMST
program specs they were designed and built to meet used a maximum payload (I
don't think it was much over 40,000 pounds) well below that of the
then-standard M-60A1 (which is quite a bit lighter than the M-1; the only
way you could transport a M-1 via YC-15 would be to cut it in half first and
sent it by *two* YC-15's); in fact, the USAF studied what it *would* take
for the YC-15 to handle an MBT load, and concluded that it would have to be
stretched, have a larger wing, etc. See:
www.dau.mil/pubs/arq/94arq/batte.pdf
AMST went the way of the dodo bird, and the successor program, C-X, which
yielded the C-17, was conceived from the get-go to result in a larger
aircraft that would be able to perform strategic airlift of outsized loads
into what was then considered the tactical A/O, which would reduce the
stress on the C-130 fleet and at the same time allow air delivery of heavy
unit assets to a much greater range of APOD's than compared to the C-5.
Brooks
Old August 27th 04, 01:00 AM
Brett
so
Which isn't the comment I made, my comment was "the designated C-141
replacement will be the C-17"
The C-X RFP from 1979/1980 required an aircraft that could deliver a full
range of combat equipment over intercontinental distances. The McDonnell
Douglas submission that won the "contest" eventually became the C-17 that is
currently being operated by USAF. So the C-17 is a strategic airlift
aircraft that you might try to operate on unprepared fields. The CX-HLS
proposal that led to the C-5 had that aircraft taxing in ploughed fields
over large tree stumps and landing and taking off from unprepared dirt
strips, and those capabilities were demonstrated in the early 70's by that
aircraft. It doesn't mean that many commanders were ever willing to put an
expensive piece of hardware into a situation where could easily be lost by
using it in a questionable tactical situation.
but the C-17
purpose.
It fulfills that role because that was supposed to be the primary mission of
the aircraft that won the C-X proposal.
It can
zone.
The C-5 can still perform that mission I believe, it doesn't mean that any
mission planner would suggest it be used in many situations for either the
C-17 or C-5.
Old August 27th 04, 04:47 AM
Guy Alcala
Brett wrote:
snip
It can
zone.
C-17 or C-5.
While the C-5 was theoretically able to land on unimproved strips, in practice
it is never done. The same hasn't been the case with the C-17, which was so
used in Afghanistan (FOB Bravo), at a minimum. The USAF wasn't all that
enthusiastic about the idea, but the Marines needed its larger payload, so it
appears CINCCENT (if not even higher up the chain) told the USAF to stop
dragging their feet and use the a/c as it was designed to be used. USAF also
refused to land their C-130s at max. gross landing weight on unimproved strips
in either Afghanistan or Iraq (I forget which) for much the same reason (using
up remaining fatigue life), which didn't make the U.S. Army (IIRR) very happy.
Since the USMC own their own KC-130s they can keep the argument in their own
chain of command, and find it easier to order instead of having to negotiate.
Guy
