"Cy Galley" wrote:
I thought the round the world non-stop Voyager was a canard... Guess I am wrong! GRIN Interestingly, though, the Scaled Composites design for the Fossett/Branson solo effort will apparently not be a canard. David O -- http://www.AirplaneZone.com |
So we have to take Voyager out of the Smithsonian?
Jim - -"Dan Apel" wrote: - -BTW if you want long range a canard is not for you. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote
So we have to take Voyager out of the Smithsonian? Jim - -"Dan Apel" wrote: - -BTW if you want long range a canard is not for you. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com That's right Jim, it just doesn't have enough range to be in there. Dan and the boys are trying to prove that this hero-worship of Rutan has just got to be stopped. pacplyer |
On Wed, 31 Dec 2003 10:27:17 -0600, "Dan Apel"
wrote: :As another aeronautical engineer I strongly agree (and second) this opinion. :BTW if you want long range a canard is not for you. A canard does some things badly. Like STOL, or loitering in a thermal. Range is one of the things it does very well. |
I've got to disagree with your assertion that canards are good for
range. I worked on the Voyager, Starship, Triumph, Catbird, ATTT, Ares and JetCruzer, plus I've analyzed the VariViggen, VariEze, Long EZ, Solitaire, Defiant, Predator, Quickie, Q2 and Dragonfly post-facto. To get long range, you want to fly at a speed slower than maximum, near or at the best L/D point. This involves flying at a higher lift coefficient and the induced drag becomes more important here. To get low induced drag, you need the sum of all lifting surfaces to have an elliptical lift distribution. The canard will by itself be nearly elliptically loaded. The aft wing, of greater span, will then need a hole in its lift distribution inboard to accomodate the canard's loading. This means that the inboard aft wing will be carrying little, if any, loading. However, it will physically be there, causing profile drag - a horse that is eating, but not pulling. Even worse, on a canard, you want the fuel on the CG, so as it is used, the CG won't shift. This means real big strakes on the aft wing usually. Thus, the part of the wing contributing profile drag, but no lift, gets even bigger. For a given L, the D has now been forced to get much bigger, clobbering L/D. The induced drag efficiency ("e") of the Voyager was around .5, as opposed to .75-.8 on conventional configurations. Simply put, the Voyager could have gone around the world with less fuel if it had been conventionally configured. The reason that the Voyager is in the Smithsonian is that Dick, Jeana, Burt and the rest of the crew created an airplane and performed a mission that no one had ever performed, plus many had dreamed of. Yes, the Long EZ has good range. However, a conventionally configured aircraft of the same GW, with the same engine and fuel quantity would have longer range. For the same L, the D would be lower. |
"David Lednicer" wrote in message ... I've got to disagree with your assertion that canards are good for range. I worked on the Voyager, Starship, Triumph, Catbird, ATTT, Ares and JetCruzer, plus I've analyzed the VariViggen, VariEze, Long EZ, Solitaire, Defiant, Predator, Quickie, Q2 and Dragonfly post-facto. To get long range, you want to fly at a speed slower than maximum, near or at the best L/D point. This involves flying at a higher lift coefficient and the induced drag becomes more important here. To get low induced drag, you need the sum of all lifting surfaces to have an elliptical lift distribution. The canard will by itself be nearly elliptically loaded. The aft wing, of greater span, will then need a hole in its lift distribution inboard to accomodate the canard's loading. This means that the inboard aft wing will be carrying little, if any, loading. However, it will physically be there, causing profile drag - a horse that is eating, but not pulling. Even worse, on a canard, you want the fuel on the CG, so as it is used, the CG won't shift. This means real big strakes on the aft wing usually. Thus, the part of the wing contributing profile drag, but no lift, gets even bigger. For a given L, the D has now been forced to get much bigger, clobbering L/D. The induced drag efficiency ("e") of the Voyager was around .5, as opposed to .75-.8 on conventional configurations. Simply put, the Voyager could have gone around the world with less fuel if it had been conventionally configured. The reason that the Voyager is in the Smithsonian is that Dick, Jeana, Burt and the rest of the crew created an airplane and performed a mission that no one had ever performed, plus many had dreamed of. Yes, the Long EZ has good range. However, a conventionally configured aircraft of the same GW, with the same engine and fuel quantity would have longer range. For the same L, the D would be lower. Absolutely agree. Burt Rutan once designed a canard sailplane where L/D is paramount called the Solitaire. It was a miserable failure. Conventional designs of the same span, weight and general fit and finish, had much more performance. (And, if powered, would have more range.) In a sailplane, there is nowhere for the designer to hide - aerodynamic problems are plain for all to see. More power and less weight can hide aerodynamic problems in powered aircraft, but not in a sailplane. For me, the Solitaire drove the final nail in the canard's coffin. In addition to poor aerodynamics, canards have poor TO and landing performance, suffer from FOD, and have a notably worse safety record than conventional airplanes. They are an all-round bad idea. Bill Daniels |
David Lednicer wrote:
The induced drag efficiency ("e") of the Voyager was around .5, as opposed to .75-.8 on conventional configurations. Simply put, the Voyager could have gone around the world with less fuel if it had been conventionally configured. Great post, thanks. Why'd they choose a canard configuration? Were their aero estimates optimistic or was there some other reason for the canard? Dave 'trim drag' Hyde |
To get long range, you want to fly at a speed slower than maximum, near or at the best L/D point. snip Hold it right there, pilgrim. Your premise, which forms the basis for your entire post, fails the practicality test. When people talk about the cruise range for aircraft such as a Long EZ or an RV-4, they are not talking about lumbering along "near or at L/D max" (about 70 kt in both the Long EZ and the RV-4). Rather, they are talking about the range at cruise speeds (65% and 75% power at altitude). In a like manor, the cruise range for piston powered aircraft is typically specified at 65% and 75% power at altitude, not throttled way back to max L/D speeds. In truth, the actual cruise range for the Long EZ and RV-4 are practically identical given the same engine and same fuel load. That's the difference between reality and an argument based upon an inappropriate premise and CFD "analysis". The previous poster's comment that "if you want good range don't choose a canard" remains laughably absurd in both theory and practice, and his subsequent post reveals his considerable grudge ax -- no surprise there. As for the Voyager, it didn't lumber along "near or at L/D max" either. The average speed was 122 mph. I find your claim that a non-canard Voyager would have had better range quite suspect. One simply can not make such a determination by punching in a few what-if scenarios into a CFD program, especially for such a highly specialized aircraft. For example, the Voyager's canard forms a structural box with the booms and the main wing. Remove the canard and you would have to add significant structural weight elsewhere to obtain the same airframe strength. If a non-canard "Voyager" would indeed have greater range then I will believe it when I hear it from Burt Rutan himself. I expect that any realized range difference, one way or the other, would be quite small. Yes, the new Rutan designed GlobalFlyer will not be a canard configuration. That design choice, however, could be based solely on the wishes Fossett/Branson rather than on technical considerations. The authoritative answer to these questions will come in time but certainly not here in Usenet (unless Burt himself decides to chime in as in the old days). David O -- http://www.AirplaneZone.com |
To get
low induced drag, you need the sum of all lifting surfaces to have an elliptical lift distribution. Lemme display my ignorance here. I always thought that the elliptical lift distribution minimized wingtiptip effects. That being the case (ignoring the wake of the canard for the moment), then each wing should have an elliptical lift distribution. When you toss in the wake effects, is having the sum of all lifting surfaces give you an elliptical distribution a handy approximation, or is it what you really want from first prinicples? thanks Ed Wischmeyer currently building the C-frame table for the RV-10 project |
| Thread Tools | |
| Display Modes | |
| Web site info needed | dave | Home Built | 1 | December 3rd 03 05:12 AM |
| parachute needed | VO | Aerobatics | 1 | November 25th 03 01:35 AM |
| Cable parts needed in Dallas | dave | Home Built | 4 | October 23rd 03 05:12 AM |
| 0-235 lyc cylinders needed (3) | Captain Dave | Home Built | 0 | October 8th 03 09:00 PM |
| PSRU - Universal Engineering | Merle Wagner | Home Built | 0 | July 7th 03 01:38 AM |
