nafod40,
"I guess we're there!" In the case of the Green Lizard (VA-95) crew, "there" was practice penetrations of Taiwanese airspace to exercise Nationalist air defense capabilities. Due to the aforementioned ship's posit error, the Lizard crew found themselves headed toward a Mainland China coast-in point. Fortunately they 180ed and bustered for Mother before being "welcomed" by the PLAAF. -- Mike Kanze "Do witches run spell-checkers?" - Old word processing joke "nafod40" wrote in message ... Mike Kanze wrote: Of course it helps mightily if you have a reasonably accurate fix from the ship before you launch - unlike the pre-launch (and pre-GPS) 40 nm-in-error "fix" that the CORAL MARU gave a VA-95 crew during its 1975 cruise. (Sea story previously shared in this NG.) If you don't know from where you started, DR by itself isn't going to get you home. Worse if you THINK you know from where you started - like the VA-95 crew, but are wrong and don't know it. We were doing blue water ops, and launched on an alert. I was a nugget null-P in the E-2. The CAPC makes a big deal about grabbing an accurate chart that's up to date before we going flying. We get airborne and he opens the chart up...and it's all blue. Top to bottom, left to right. He looks at it for a second, closes it back up and sticks it in the navbag and says, "I guess we're there!" |
Today, we primarily use Tacan. However, knowing where the boat should be is
always a good preflight brief item to write down on your kneeboard card. You never know when the "cake dryer" needs that "common" part that seems to exist in the guts of the Tacan system.(or the ACLS/ICLS). However, the next generation of carrier is supposed to have differential gps-like signal that is transmitted so that aircraft don't need to be in T/R on the new nav system. I think the name is JPALS (joint precision aircraft landing system?). Eventually, all ships that have aircraft flying off of them would have JPALS retrofitted onto the ships. Of course, it, much like other procurement items, may not come to fruition. "Rich" wrote in message om... (Al Dykes) wrote in message ... As an armchair admiral, I've always wondered how A/C in WWII knew how to find the carrier after being away for a couple hours on a mission. I assume the pilots were told, roughly, where the carrier plans to be, but sh*t happens. I always assume the carrier doesn't broadcast any radio signals. How do they do it, today ? Well, for WWII USN carriers, generally pilots got a "Point Option" that would give them a general idea where their carrier was supposed to be. Then it became a matter of sorting out the homing signal. Presume the RN worked the same way as they had similar homing equipment. Don't think the Japanese used homing signals. Rich |
"Al Dykes" wrote in message ... How do they do it, today ? In the late 70's, you just looked for the biggest cloud. The ship was usually under it. |
In the early 60's we used a CHART PLOTTING BOARD Mark 6A, it was about 14"
by 14". The ships course and speed and the flight plan could be plotted at the same time. It was a hand job but it worked, most of the time. If it didn't you started a square search at the point you were suppose to meet. Also it opened up and was a good place for porn pictures! On 28/10/04 5:46 PM, in article , "Frank Minich" wrote: "Al Dykes" wrote in message ... How do they do it, today ? In the late 70's, you just looked for the biggest cloud. The ship was usually under it. |
"B.C. Mallam" wrote in message
In the early 60's we used a CHART PLOTTING BOARD Mark 6A, it was about 14" by 14". Ayup. I was taught and used in the S2 'till that platforms retirement in '75. I know this 'cause I taught it!!!!! ;-) The ships course and speed and the flight plan could be plotted at the same time. It was a hand job but it worked, most of the time. It did require some "position sense" and somebody with a quick pencil. When the ASN-30A worked it was great. But that device had a two cat shot/arrestment warranty. :-( So you had to be ready with your backup. If it didn't you started a square search at the point you were suppose to meet. That was one way. Another was to drop a CODAR pair or a DIFAR bouy and look for the "singing screw" on Mother. Also it opened up and was a good place for porn pictures! I guess this kind of ties in the "singing screw." Bill Kambic VS-27, VS-30, VS-73, FASOTRAGRULANT |
How do they do it, today ? BRBR
We had a Tacan.....most of the time that is. P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
We had a Tacan
Or not. A certain Adm Jerry Tuttle had an aversion to radiating from his ships. EMCON night recoveries north of the arctic circle. Pitching deck, 70 knots of wind over the deck, and the most memorable night trap in my life (yes, you CAN experience the 3 ultimate physical pleasures simultaneously). The E-2 would set up the recovery (which typically included a misdirection penatration followed by a 25-50 mile vector at 1200 feet). Pulse single-scan could really help on the run in. Figure out the BRC/FB on flyover, turn downwind and dirty up, time 30 seconds while descending to 600 feet. Level turn to FB, fiddle with lineup and descend when the ball looked centered. Cut lights (hopefully just once) and fly the ball. Not bad when the weather was reasonable. Not fun when it was not. R / John |
"John Carrier" wrote...
Or not. A certain Adm Jerry Tuttle had an aversion to radiating from his ships. EMCON night recoveries north of the arctic circle. Pitching deck, 70 knots of wind over the deck, and the most memorable night trap in my life (yes, you CAN experience the 3 ultimate physical pleasures simultaneously). Hmmm... Tuttle must have been friends with Chuck McGrail when McGrail was CO of Midway in the early 80s... EMCON recoveries (day and night) and "stealth transits" were routine for a while! I've heard of the "7 basic pleasures of life," and can only guess which of the 3 you refer to as "ultimate"... :-) The E-2 would set up the recovery (which typically included a misdirection penatration followed by a 25-50 mile vector at 1200 feet). Pulse single-scan could really help on the run in. ....but not available in the KA-6D, even for "cheating"... |
John,
...but not available in the KA-6D, even for "cheating"... Amen. One tactic would be to find a navigationally-competent friend up there and promise some gas for a lead home. (Note I said "promise." g) -- Mike Kanze 436 Greenbrier Road Half Moon Bay, California 94019-2259 USA 650-726-7890 "Do witches run spell-checkers?" - Old word processing joke "John R Weiss" wrote in message news:sIugd.271445$wV.72828@attbi_s54... "John Carrier" wrote... Or not. A certain Adm Jerry Tuttle had an aversion to radiating from his ships. EMCON night recoveries north of the arctic circle. Pitching deck, 70 knots of wind over the deck, and the most memorable night trap in my life (yes, you CAN experience the 3 ultimate physical pleasures simultaneously). Hmmm... Tuttle must have been friends with Chuck McGrail when McGrail was CO of Midway in the early 80s... EMCON recoveries (day and night) and "stealth transits" were routine for a while! I've heard of the "7 basic pleasures of life," and can only guess which of the 3 you refer to as "ultimate"... :-) The E-2 would set up the recovery (which typically included a misdirection penatration followed by a 25-50 mile vector at 1200 feet). Pulse single-scan could really help on the run in. ...but not available in the KA-6D, even for "cheating"... |
| Thread Tools | |
| Display Modes | |
| General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 2nd 04 12:16 AM |
| Next Generation Aircraft Carrier Contract Awarded | Otis Willie | Naval Aviation | 6 | May 23rd 04 03:53 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Naval Aviation | 4 | February 21st 04 10:01 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Military Aviation | 2 | February 12th 04 01:52 AM |
| The "Gipper" is ready! | Phineas Pinkham | Naval Aviation | 0 | July 8th 03 11:57 PM |
