Best warbird to own
Old November 7th 03, 07:18 PM
Roger Halstead
On 7 Nov 2003 12:37:59 -0400, Gregg Germain
In rec.aviation.military Charles Talleyrand wrote:
: There are lots of P51s out there, so they are not rare enough.
: Further, they are said to be even harder to fly than normal for
: vintage and type.
Where does it say P-51's are hard to fly? Or harder to fly than
"normal"?
Every thing is relative.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
--- Gregg
"Improvise, adapt, overcome."
Smithsonian Center for Astrophysics
Phone: (617) 496-1558
Old November 7th 03, 06:56 PM
Gregg Germain
In rec.aviation.military Roger Halstead wrote:
: On 7 Nov 2003 12:37:59 -0400, Gregg Germain
: wrote:
:In rec.aviation.military Charles Talleyrand wrote:
:: There are lots of P51s out there, so they are not rare enough.
:: Further, they are said to be even harder to fly than normal for
:: vintage and type.
: Where does it say P-51's are hard to fly? Or harder to fly than
: "normal"?
: Every thing is relative.
That's why I added "Or harder to fly than 'normal'" and why I put
normal in quotes.
I'm curious as to how the conclusion was reached - it's certainly
harder to fly than a Cessna 152, but not nearly as hard to fly as the
space shuttle.
I'm assuming he compared them to aircraft contemporary with the P-51
since he used the word "vintage".
Was it harder to fly than the P-39? the 39 has some tough spin
characteristics.
Other than the 51 being somewhat less stable when the aft gas tank
was full, I don't know of any other difficult characteristics.
Just curious what he meant by "harder".
--- Gregg
Old November 8th 03, 03:39 AM
Charles Talleyrand
"Gregg Germain" wrote in message ...
: "normal"?
space shuttle.
characteristics.
I've read three things. The p51 is unstable in pitch with full tanks and the
resulting aft CG, and that a p51 has a high speed stall that's tougher than
most other WWII fighters. And finally the p51 has a higher stall speed
than other contemporary fighters.
I myself have no idea, and will defer to people with actual knowledge. But
this is the scuttle-butt around this household.
Old November 8th 03, 08:52 AM
killfile
"Charles Talleyrand" wrote in message
: "normal"?
space shuttle.
characteristics.
and the
than
But
The P-51 is a little more unforgiving than some other WWII fighters because
of it's high speed laminar-flow wing - this gives it speed and range, at the
cost of a more 'sudden' wing stall and a higher stall speed.
The Spitfire is more forgiving to fly because, due to a design quirk, it's
airframe actually gives a little shudder to warn you you're near a wing
stall state.
Matt
Old November 8th 03, 03:41 PM
G.R. Patterson III
The balance problem is caused by the aft fuselage tank. Many Mustangs have had
this removed. In any case, you won't need to fill it unless you're planning a
1600 mile trip. Stall speed in military configuration was about 95, which isn't
out of line with other fighters of the era and is actually a bit lower than the
Bf-109. I've read, however, that the plane doesn't give warning before the stall
and drops the left wing dramatically when it does. Len Deighton claims that few
military pilots three-pointed the Mustang because that gets you too close to the
stall speed. Some years back, I got to watch 52 of these planes land at Sun'n
Fun. Every landing was a wheel landing with the tail slightly low.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Old November 7th 03, 07:03 PM
Erik Pfeister
om...
I'm fantasy shopping for my new warbird or historic aircraft. My
requirements are ...
- Historic value (rare and interesting aircraft)
- Reasonably easy to fly
- No turbines and under 12,500 lbs (no type rating needed)
- Seats two
- Aerobatic
- Easy on the eyes
I have two brand new, less than 250 TT Henschel Hs 126, Greek Air Force
markings.
100 K Euros each.
Old November 7th 03, 09:30 PM
CC
T-33, T-34
No good deed goes unpunished!
Old November 7th 03, 11:09 PM
Leanne
"CC" wrote in message
T-33, T-34
There is or was an outfit in Mass that was importing reworked O-1's with
Italian markings and a turboprop on the front end. They had a couple at Sun n
Fun
two years ago.
Leanne
Old November 8th 03, 06:48 AM
WaltBJ
T6G Harvard. Nice bird, acrobatic, parts available.
Walt BJ
Old November 8th 03, 07:46 AM
John Keeney
"WaltBJ" wrote in message
om...
Walt BJ
You guys are much to conventional in your thinking for a
fantasy plane. How about making it something useful when
you want to make that back woods fishing trip? Say a
J2F Grumman Duck, a SO3C Curtiss Seamew on floats or
even a SC Curtiss Seahawk. There might be problems with
the last two being unobtainium rare but the Duck should
be doable.
Military & vintage warbird slides for sale Wings Of Fury Aviation Marketplace 0 July 10th 04 02:17 AM
Florida Mil Comms; Tico Warbird Acft AllanStern Military Aviation 4 March 16th 04 02:49 PM
Keeping Me Out of Your Warbird? Stephen Harding Military Aviation 47 February 12th 04 05:34 PM
Vintage & Warbird mailing list. Darryl Gibbs General Aviation 0 September 13th 03 10:53 AM
Vintage & Warbird mailing list. Darryl Gibbs Owning 0 September 13th 03 10:53 AM
