With my Husky, I go fastest with the prop full forward. I am not sure
if this is true with all small GA aircraft with Constant speed prop. The Husky has essentially the same prop/engine config as the Lycoming 0-360 Mooneys. What the CS prop gives me is a smoother ride, better fuel economy and another knob to turn. Nathan Young wrote in message . .. On 7 Oct 2004 13:02:37 -0700, (PaulH) wrote: At any altitude that permits you to develop 75% power with your current prop, a constant speed prop won't gain you an inch unless you want to fly at a higher power setting. Can you better explain this? My understanding is that a fixed pitch prop is typically a compromise in both takeoff pitch, and cruise pitch. Using the typical car driving analogy - a prop that is stuck in 3rd or 4th gear in a 5 speed transmission. So I would think a CS prop would net gains at both cruise and takeoff/climb. What the CS prop primarily gives is better climb and increased drag in descent if you need get down in a hurry. I've often thought a CS prop would be very beneficial in long descents. I often cruise @ 8-11k feet, and during descent, it is easy to redline the engine, so I have to remove some power, which decreases the airspeed. |
Doug wrote: With my Husky, I go fastest with the prop full forward. I am not sure if this is true with all small GA aircraft with Constant speed prop. Of course it is. Set whatever rpm you want. Add in some more rpm and you will go faster. The Husky has essentially the same prop/engine config as the Lycoming 0-360 Mooneys. What the CS prop gives me is a smoother ride, better fuel economy and another knob to turn. Smoother ride? Never heard that one before. |
Well, I have heard from people SAY that they go faster with the prop
pulled back a bit. My experience is limited to the Husky (for constant speeds). I've flown other CS prop planes, but not enough to have done speed tests. As for smoother, my engine runs smoothest at about 2450 rpm. Anywhere else is more vibration. So there you go. You can choose the smoothest rpm. Newps wrote in message ... Doug wrote: With my Husky, I go fastest with the prop full forward. I am not sure if this is true with all small GA aircraft with Constant speed prop. Of course it is. Set whatever rpm you want. Add in some more rpm and you will go faster. The Husky has essentially the same prop/engine config as the Lycoming 0-360 Mooneys. What the CS prop gives me is a smoother ride, better fuel economy and another knob to turn. Smoother ride? Never heard that one before. |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Is there a minimum prop speed? | Jim Carter | Owning | 2 | June 29th 04 02:49 AM |
| Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 11:08 PM |
| Rotax 914 / Constant Speed? | Richard Riley | Home Built | 4 | February 26th 04 04:01 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
