On Sat, 30 Oct 2004 13:02:40 -0600, "Louis L. Perley III"
wrote: I'll post a report on my annual if anyone is interested. This is the first one for the Aztec since I bought it. Thanks for the info. A re-cap post would be great. I don't have much experience with Aztec's but will definately be getting my feet wet over the next couple weeks. z |
I'd be extremely interested in a report on your Aztec's annual!!! Thanks!
What year/model? Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 |
On Wed, 3 Nov 2004 20:10:48 -0800, "Jim Burns"
wrote: I'd be extremely interested in a report on your Aztec's annual!!! Thanks! What year/model? Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 It's an F model. I don't know the year. I don't own it, my friend does. Since it's getting cold and he keeps it on a grass strip, he's now thinking of letting it sit until winter passes. He's undecided, but when it happens I give a report. z |
zatatime wrote:
Can anyone point me to a link for Piper Service Bulletin 1051B? It is what the Aztec falp tube AD refers to for compliance (2003-09-18?). I have not been able to find it on-line. I'm trying to help someone figure out the best way to comply, but if I can't read it I can't understand what is required. Unfortunately, they did not keep the copy that was mailed to them. TIA. z I have posted the text of S.B. 1051B he http://homepage.mac.com/scottdb/FileSharing7.html Happy Flying! Scott Skylane N92054 |
On Sat, 30 Oct 2004 12:53:55 -0800, Scott Skylane
wrote: zatatime wrote: Can anyone point me to a link for Piper Service Bulletin 1051B? It is what the Aztec falp tube AD refers to for compliance (2003-09-18?). I have not been able to find it on-line. I'm trying to help someone figure out the best way to comply, but if I can't read it I can't understand what is required. Unfortunately, they did not keep the copy that was mailed to them. TIA. z I have posted the text of S.B. 1051B he http://homepage.mac.com/scottdb/FileSharing7.html Happy Flying! Scott Skylane N92054 Thank you Mr. Skylane! Printing it now and will read it later tonight. Hopefully the illustrations aren't too important. Appreciate the time to put this up! z |
zatatime writes:
Can anyone point me to a link for Piper Service Bulletin 1051B? http://www.caa-rs.si/images/pripone/..._MSB_1051B.pdf http://www.airweb.faa.gov/Regulatory...A?OpenDocument http://www.tdatacorp.com/03-09-13.HTM I've got a paper copy around here somewhere. I complied with it years ago. --kyler |
On Sun, 31 Oct 2004 01:08:04 GMT, Kyler Laird
wrote: zatatime writes: Can anyone point me to a link for Piper Service Bulletin 1051B? http://www.caa-rs.si/images/pripone/..._MSB_1051B.pdf http://www.airweb.faa.gov/Regulatory...A?OpenDocument http://www.tdatacorp.com/03-09-13.HTM I've got a paper copy around here somewhere. I complied with it years ago. --kyler Thanks! I had the Tdata link and the AD itself. Now I've got a pdf of the SB and I'm psyched! Thank you for posting this for me. z |
My 2 cents. We complied with the AD by putting in the new torque tube.
drilled it at the mechanical facility at the FBO and reinstalled it. Airplane flew wing down and yawed left and right depending on the amount of flaps. Took it out and examined and reinstalled to no effect. Obtained an second new torque tube and had a machine shop drill it out and then installed. Airplane is in a slip at cruise and yaws with flaps. factory and dealer of no help. So.........while practicing approach to landing stalls, the aircraft suddenly fills with mist. The gear are down and locked. The mist appeared when lowering flaps. You got it . The torque tube had impinged on the aileron cable, placed it under tension, caused sideslip in the aircraft and also caused the aileron cable to saw through the hard aluminum hydraulic line leading to the flaps. I do not know that there is a moral to the story. Flying airplanes is expensive. "zatatime" wrote in message ... On Sun, 31 Oct 2004 01:08:04 GMT, Kyler Laird wrote: zatatime writes: Can anyone point me to a link for Piper Service Bulletin 1051B? http://www.caa-rs.si/images/pripone/..._MSB_1051B.pdf http://www.airweb.faa.gov/Regulatory...A?OpenDocument http://www.tdatacorp.com/03-09-13.HTM I've got a paper copy around here somewhere. I complied with it years ago. --kyler Thanks! I had the Tdata link and the AD itself. Now I've got a pdf of the SB and I'm psyched! Thank you for posting this for me. z |
I'll add my $0.02 as well... last April when my Aztec came due for its
annual ('69 D model) I considered the price of the tube and the labor involved in pulling to tube to inspect it, and redoing the inspection ever 500 hrs I decided to be done with it an just replace the tube. Here's where the fun began...Tube arrives, the mechanic looks closely at the instructions lays it out as per the instructions and first thing he notices is if you lined up the bell cranks with the curf cut as instructed, the flaps will not line up properly. turns out when Piper built the plane they drilled the hole wrong or cut the curf wrong or something. Ok, no problem, he rotated the bell crank a few degrees (the hole needed to be moved about 1/16" of an inch) lines the ends up flush and drills and reams out the hold. goes to put the tube in the airplane and finds out that the new tube is about 1/16" of an inch shorter than the original tube and won't fit in the bearing blocks, and is now trash. Second tube comes from the distributer in a FedEx tube, tube arrives with a 2" hole punched through the bottom and no torque tube. Third tube comes from the distributer, this time the torque tube is still inside (barely) and is successfully installed. In other words remember that these planes were really built one at a time and the instructions are just a guide but not always definitive. Jeff Steven wrote: My 2 cents. We complied with the AD by putting in the new torque tube. drilled it at the mechanical facility at the FBO and reinstalled it. Airplane flew wing down and yawed left and right depending on the amount of flaps. Took it out and examined and reinstalled to no effect. Obtained an second new torque tube and had a machine shop drill it out and then installed. Airplane is in a slip at cruise and yaws with flaps. factory and dealer of no help. So.........while practicing approach to landing stalls, the aircraft suddenly fills with mist. The gear are down and locked. The mist appeared when lowering flaps. You got it . The torque tube had impinged on the aileron cable, placed it under tension, caused sideslip in the aircraft and also caused the aileron cable to saw through the hard aluminum hydraulic line leading to the flaps. I do not know that there is a moral to the story. Flying airplanes is expensive. "zatatime" wrote in message ... On Sun, 31 Oct 2004 01:08:04 GMT, Kyler Laird wrote: zatatime writes: Can anyone point me to a link for Piper Service Bulletin 1051B? http://www.caa-rs.si/images/pripone/..._MSB_1051B.pdf http://www.airweb.faa.gov/Regulatory...A?OpenDocument http://www.tdatacorp.com/03-09-13.HTM I've got a paper copy around here somewhere. I complied with it years ago. --kyler Thanks! I had the Tdata link and the AD itself. Now I've got a pdf of the SB and I'm psyched! Thank you for posting this for me. z |
On Fri, 05 Nov 2004 15:13:28 -0500, Jeffrey Ross
wrote: In other words remember that these planes were really built one at a time and the instructions are just a guide but not always definitive. Jeff Sheeesh, that was more like a nickel, not just two cents!!! Maybe even a cuople thousand dollars by the time you add up everything from your post! Boy do I hope this is not the norm, and that you onlypaid for one tube! Thanks for the input, will be very vigillant when taking care of this. z |
