Owning more expensive than renting
Old December 20th 04, 02:37 PM
OtisWinslow
Owning is a LOT more expensive than renting. While you may
get a breakeven at a certain number of hours .. few owners would
fly as much as they do if they were renting. So that comparison is
a bit fictitious.
"Jon Kraus" wrote in message
Well I have only been an airplane owner for a few months but so far owning
is more expensive than renting. I must say that the convenience of having
your own airplane to go to when ever you want is worth a few bucks. Has
anyone found owning more expensive than renting? :-)
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
Old December 20th 04, 04:14 PM
Gene Seibel
When you own you don't have to turn yourself in at the end of the
flight. You are free to go.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because I fly, I envy no one.
Old December 21st 04, 02:17 AM
A Lieberman
On Sat, 18 Dec 2004 13:38:17 GMT, Jon Kraus wrote:
Has anyone found owning more expensive than renting? :-)
After my major overhaul after an inflight cylinder failure on my 1976
Sundowner. I thought I was through the "worst" case scenario, but a new
problem is about to bite me in my rear end that has my A&P scratching his
head.....
Last flight, I noticed under the wing root, some blue dye on my nice shiny
white paint. Thought, ok, maybe when I was topped off, that some fuel
dripped down and left it's traces. Wiped it off, nothing leaking, so I
thought.... Flew the plane, landed, no obvious signs of leaking.
Today, go out, same thing, just enough leakage, that it doesn't make it to
the bottom of the fusalage, nothing on the ground, yet I have a fuel leak
from the root of the wing.
My A&P took a look, sure enough, said I have never seen anything like this.
The Sundowner doesn't have any access panels to the fuel tanks! Everything
is riveted tight as a drum. So.... now do I have a leaky fuel tank, or do
I have a fuel line problem.
A&P said run it today, with the warmer weather and see if I get seepage.
Came back, sure enough, very fine strip of blue from fuel seeping out.
I wiped it off after the flight, to see if I get any seepage. I am
figuring if no seepage, then there is a good chance it's a fuel line
leaking under pressure. I asked for the tank to be topped off as well.
Either way, it's going to be very expensive to repair.... If it's the
tank, the entire wing will probably have to be removed from what I gather,
as it does not appear to be "bladders" according to my A&P.
Total time on airframe is 2253, so be very careful in buying "underused"
airplanes. Sitting on the ramp is worse then being used on a regular basis
as I am learning the hard way.
Allen
Old December 24th 04, 06:35 AM
this. The Sundowner doesn't have any access panels to the fuel tanks!
Everything is riveted tight as a drum. So.... now do I have a leaky fuel
tank, or do
I don't know squat about Sundowners, but I'm wondering how it could be that
here are NO access/inspection holes on the wings. Certainly, there has to
be access to the wing attach bolts. Also, how does the fuel line get
connected after a wing is installed if there are no access points?
I've seen some remarkable snorkeling periscope tools that allow one to
"peek" around corners inside a wing when the inspection hole isn't where the
problem it.
Have you considered that Beech technical support might be able to help on
this problem?
Good luck, and let us know what happens.
-Elliott Drucker
Old December 25th 04, 05:28 AM
Slip'er
I have access to a 20 ft fiberoptic borescope. I'm here in San Diego.
Wouldn't mind playing with it as long as we don't break it. I could never
afford to replace it...
news:YUNyd.5511$h.2950@trnddc04...
fuel
tank, or do
that
problem it.
this problem?
-Elliott Drucker
Owning Update mindenpilot Owning 9 November 23rd 04 03:13 PM
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield Paul J. Adam Military Aviation 1 August 9th 04 09:29 PM
Buying a plane versus renting RD Owning 35 March 5th 04 10:42 PM
Legality of owning ex-military intercontinental aircraft. Bill Silvey Military Aviation 71 October 15th 03 10:50 PM
renting plane out to flight school - profitable? David Megginson Aviation Marketplace 1 October 13th 03 03:36 AM
