Speedbrakes for a Bonanza: Opinions?
Old January 13th 05, 10:05 PM
markjenn
To be fair, Mark, the speedbrakes from Precision Flight are US $4,100,
plus 35 hours installation labor, not 15k. However, I have learned
enough in the last few days to agree in principle with your point.
BTW, this Bonanza is equipped with TKS Weeping Wing, but the previous
owner shows me an invoice that was higher than 15k for that mod.
Fair enough. I was just guessing as I have neither mod.
- Mark
Old January 13th 05, 05:30 AM
Jon A.
On Tue, 11 Jan 2005 18:50:22 -0800, "markjenn"
They're not a bad idea on some aircraft, but Bonanzas, with their 154K gear
speeds, really don't need them. I also think that shock-cooling is an
overrated thing, but that's another discussion.
Some Bonanzas have gear speeds at 100mph
Old January 13th 05, 05:47 AM
Orval Fairbairn
I have 100 mph gear speed on my 1946 Johnson Rocket -- I have found the
best way to bleed off speed is to do the 360 overhead approach, where
you overfly the runway, on desired runway heading, at pattern altitude
and "break" to the downwind (assuming that nobody is already on
downwind), reducing throttle as speed bleeds off. i hit gear speed about
the 180 degree point, drop the gear, drop flaps even with the TD point
and continue with a short base and final.
If you do it right, you won't have to add any power and can make the
numbers with a nice 3-pointer. This also works great in a T-34.
Old January 13th 05, 08:09 AM
Scott Skylane
Oh God. Oh, God...
Old January 13th 05, 03:48 PM
Frank Stutzman
Gee Orval, you must be a lot fun for ATC at a busy controled field.
Its been a long time, but I don't remember you ever doing that when you
flew in and out of Palo Alto.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old January 13th 05, 06:20 PM
Dude
I gotta ask, is this really that tough on ATC? I have been vectored in to
busy airports on more than one occassion in almost exactly the same pattern.
They brought me in over the field at 1500 AGL from whatever direction, then
turned me straight into the downwind (there never is anyone flying the
pattern at these fields) then called my base.
Worked well for everyone.
Old January 13th 05, 11:28 PM
Orval Fairbairn
I usually didn't arrive from the south and had not really discovered the
efficiency of the 360 overhead at that time. Reid-Hillview would
sometimes request a 360 overhead, but I never really perfected it until
I moved to Spruce Creek and got into formation flying.
It really works!
Old January 13th 05, 06:45 AM
Matt Barrow
"Jon A." wrote in message
gear
Which ones?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old January 13th 05, 01:36 PM
Jon A.
Models prior to the G or H (1956, 57) IIRC. The J, K, M ('58 - 60)
were 140 mph and the newer ones crept up to 157 or so.
On Wed, 12 Jan 2005 22:45:04 -0700, "Matt Barrow"
gear
Which ones?
Old January 13th 05, 06:00 PM
Matt Barrow
(mph or kts??)
Were they even fast enough to require flaps? :~)
gear
Which ones?
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 10:08 PM
Thanks for your opinions - Going to pick up plane tomorrow!! Larryskydives Owning 0 February 13th 04 05:44 AM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 11:43 PM
Rallye/Koliber AD's and opinions R. Wubben Owning 2 October 16th 03 06:39 AM
Early Bonanza or Apache? Brinks Owning 11 July 16th 03 07:01 PM
