Oil leak on top of the engine
Old February 11th 05, 05:03 PM
Trent Moorehead
"Jay Honeck" wrote in message
news:6q3Pd.63958$eT5.59714@attbi_s51...
To those who think that the bolt might have been loose from the start,
remember: I watched the shop build this engine, and I personally saw them
check the torque on the engine case bolts. They *were* tightened to spec.
I also know that they never re-checked them, however, and my main mechanic
has admitted that they never check these as a matter of course.
Now, I am not an A&P, but is it possible that when the bolts were torqued
that they needed to be torqued in a particular order, reminiscent of
tightening lug nuts on a wheel? Sometimes when tightening several bolts, the
action of tightening later bolts causes the first bolt to become loose. In
this scenario, the last bolt is torqued correctly and the first bolt is
fairly loose. Just thinking here....
-Trent
PP-ASEL
Old February 11th 05, 06:58 PM
Jon Woellhaf
Jay wrote, "I've bought a torque wrench, and I'm going to be checking ALL of
these bolts every time I change the oil, from now on."
Jay,
I'm sure you know this from your motorcycle Zen days, but I've learned (and
relearned a couple times) to be certain the click-type torque wrench setting
is correct before using it -- and to loosen it completely before putting it
away. (Maybe the latter is an old wives' tale.)
I've also learned to be careful to note whether foot-pounds or inch-pounds
is specified. It seems that aircraft bolts are often torqued considerably
less than I would expect them to be.
Regards,
Jon (not an A&P or even a motorcycle mechanic)
PS: I shall now be checking my engine's bolts. Thanks for the heads up!
Old February 11th 05, 07:27 PM
Orval Fairbairn
In article 6q3Pd.63958$eT5.59714@attbi_s51,
"Jay Honeck" wrote:
The point I'm trying to make is it appears that some bolts being torqued
have been overlooked and what is the chance that the cylinder nuts & thru
bolts had been overlooked also?
Simply, You don't know until you check. It'll require 10 minutes if you
have easy access to the engine.
I'm having my shop check these this morning.
In the case of the O-540, anyway, the case bolts are torqued surprisingly
low, and they are not secured in any way. No cotter pin, no safety wire, no
LocTite, no lock washer -- NOTHING prevents those nuts/bolts from loosening
over time. It seems like a ridiculous over-sight, but that's the way it
is.
A guy on the Cherokee Chat actually had a case bolt FALL OUT after loosening
over time from vibration, so this is not an unheard-of problem. I'm
surprised it's never been addressed in this forum before -- at least not in
my 7 years here.
I've bought a torque wrench, and I'm going to be checking ALL of these bolts
Another caveat on torquing (from an old AI): All torquing should be done
"wet", with a drop of oil to lube the nut, so as not to get a false
torque reading.
Old February 11th 05, 10:26 PM
Jon A.
On Fri, 11 Feb 2005 14:36:50 GMT, "Jay Honeck"
Good for you.
New bolts, new nuts, new lock washers, torque wrench calibrated
recently?
Tsk, tsk! What else do they not do?
is.
If all of the engines would have failed, they would have changed the
procedure. Something else is wrong.
my 7 years here.
Have it calibrated, and remember that each time you torque it, the
bolt stretches. Some years ago, when it was credible, AVWEB had an
article on torque. You can probably still pull it up.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
