"Andrew Gideon" wrote in message
So one can use one of many different GPSs? How long does the iPAQ's battery run both the GPS and the iPAQ? One of the major niches for what I'm looking to purchase is a backup. This would include, of course, electrical failure. So battery operation is important. Yes, the AWM solution is compatible with a range of GPS receivers. As others mentioned, ControlVision offers a remote GPS solution with its own batteries. This configuration should offer several hours of operation on a set of fully charged batteries. FWIW, my Sentinel setup running on just the iPAQ internal battery (I have an external power pack I can use) gives me well over 2 hours of continuous use. However, what I like about the iPAQ type solutions is the range of backup available. It looks expensive, but there's even a backup "gyro" available for the thing. That, plus the weather, plus the nav backup...very tempting. soapbox enabled=true The thing about backups of any kind is that they have to be ready for immediate use at the time they're needed. For instance, having a handheld transceiver is a great backup idea for when you lose all electrical power - unless the handheld is in your flight bag packed away in the baggage area. Similarly, for the solid-state AI and handheld GPS to be useful as backups, they have to be handy at the time they're needed. Imagine flying at night when all electrical is lost. Is this the time to be trying to set up a handheld GPS with remote antenna? What about the backup AI? For that matter, where's your flashlight? Don't get me wrong. I have the handheld units to use as backups, too. I just make sure the handheld GPS is setup while I'm on the ground (especially before a night flight) and the transceiver is within arm's reach without having to turn my head. /soapbox Since the airplanes I fly tend to have IFR GPSs, I'm less thrown by the fact that it may be not quite as user-friendly as a dedicated GPS. I don't, though, want to be messing with a nest of cables. I get enough of that at work laugh. My iPAQ setup has a single wire that I find easy to keep out of the way. Frankly, I find myself moving the headset cord around much more than the GPS cable. A concern I have is stability of the iPAQ's OS. It's an MSFT product, no? I've little faith in them, but I've never tried their portable versions. Have you had a problem with this thing crashing? While Windows does have a reputation for crashing at inopportune moments, this opinion is usually propagated by UNIX holdouts, Linux/open source champions or McLovers. ![]() Kidding aside, the only time I've ever needed to perform a reset on my device has been during app development (pesky closed loops will do that every time). The AWM software has never needed a reboot, in my experience. -- John T http://tknowlogy.com/tknoFlyer __________ |
If you are looking at the PDA / GPS solution I would recommend taking a
look at pocketfms ( www.pocietfms.com )before you pay for a commercial moving map solution. It does everything you can think of, and it is free. It will even download the wind info and calculate your flight plan for you. Very nice tool. For those that don't have PDA, the program installs on your PC and then downloads the info to the PDA so you can also use it for flight planning on your PC. Very nice program. "John T" wrote in message ws.com... "Andrew Gideon" wrote in message So one can use one of many different GPSs? How long does the iPAQ's battery run both the GPS and the iPAQ? One of the major niches for what I'm looking to purchase is a backup. This would include, of course, electrical failure. So battery operation is important. Yes, the AWM solution is compatible with a range of GPS receivers. As others mentioned, ControlVision offers a remote GPS solution with its own batteries. This configuration should offer several hours of operation on a set of fully charged batteries. FWIW, my Sentinel setup running on just the iPAQ internal battery (I have an external power pack I can use) gives me well over 2 hours of continuous use. However, what I like about the iPAQ type solutions is the range of backup available. It looks expensive, but there's even a backup "gyro" available for the thing. That, plus the weather, plus the nav backup...very tempting. soapbox enabled=true The thing about backups of any kind is that they have to be ready for immediate use at the time they're needed. For instance, having a handheld transceiver is a great backup idea for when you lose all electrical power - unless the handheld is in your flight bag packed away in the baggage area. Similarly, for the solid-state AI and handheld GPS to be useful as backups, they have to be handy at the time they're needed. Imagine flying at night when all electrical is lost. Is this the time to be trying to set up a handheld GPS with remote antenna? What about the backup AI? For that matter, where's your flashlight? Don't get me wrong. I have the handheld units to use as backups, too. I just make sure the handheld GPS is setup while I'm on the ground (especially before a night flight) and the transceiver is within arm's reach without having to turn my head. /soapbox Since the airplanes I fly tend to have IFR GPSs, I'm less thrown by the fact that it may be not quite as user-friendly as a dedicated GPS. I don't, though, want to be messing with a nest of cables. I get enough of that at work laugh. My iPAQ setup has a single wire that I find easy to keep out of the way. Frankly, I find myself moving the headset cord around much more than the GPS cable. A concern I have is stability of the iPAQ's OS. It's an MSFT product, no? I've little faith in them, but I've never tried their portable versions. Have you had a problem with this thing crashing? While Windows does have a reputation for crashing at inopportune moments, this opinion is usually propagated by UNIX holdouts, Linux/open source champions or McLovers. ![]() Kidding aside, the only time I've ever needed to perform a reset on my device has been during app development (pesky closed loops will do that every time). The AWM software has never needed a reboot, in my experience. -- John T http://tknowlogy.com/tknoFlyer __________ |
"Tom Hyslip" wrote in message m... If you are looking at the PDA / GPS solution I would recommend taking a look at pocketfms ( www.pocietfms.com )before you pay for a commercial moving map solution. It does everything you can think of, and it is free. It will even download the wind info and calculate your flight plan for you. Very nice tool. For those that don't have PDA, the program installs on your PC and then downloads the info to the PDA so you can also use it for flight planning on your PC. Very nice program. Dead Link |
Hmmm...Is it my imagination or is there no way to "download" the free
software? I didn't see a link. Carl "Tom Hyslip" wrote in message m... If you are looking at the PDA / GPS solution I would recommend taking a look at pocketfms ( www.pocietfms.com )before you pay for a commercial moving map solution. It does everything you can think of, and it is free. |
| Thread Tools | |
| Display Modes | |
| Garmin 430 Reception | Jon Kraus | Owning | 16 | November 7th 04 04:17 AM |
| Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 10:03 AM |
| Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 03:04 AM |
| Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 10:04 PM |
| Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 10:32 PM |
