John Bell wrote: I would like to hear some feedback as to how pilots are violating airspace with GPS. Someone here just posted about busting SEA's class B (partly) due to being zoomed in too far to get the big picture. I flew straight into a class D instead of skirting it because I hadn't been using the GPS map for anything up to that point and someone else had switched it (rental plane) from track-up to north-up. I would have missed it (my pilotage was fine) but the map put it just north of me which I read as 'right in front of me' so I turned while I tried to figure out how I could possibly be where it said I was... -- Ben Jackson http://www.ben.com/ |
I use a Garmin 300 IFR GPS .. and a Garmin 196 handheld. I keep the IFR
database current and update the handheld about once a year. I've had no trouble working around and under the Class B shelves using them. When compared to prominent landmarks (roads, etc) that help identify the boundaries, they seem to be highly accurate. Some Class B's have VFR waypoints shown on the TAC and those help. An important thing is to keep the zoom set correctly so you can identify just where you're at in relation to the different B floors. If you're zoomed in too close .. you may think you're under the wrong one. I like to zoom so I can see the B space to it's outermost ring. "John Bell" wrote in message om... It appears that a lot of pilots are violating airspace even with GPS on board. I would like to hear some feedback as to how pilots are violating airspace with GPS. I address this in my online book, www.cockpitgps.com. I have my hypothesis, but I would like to hear your experience or scenarios that you have heard involving this issue. Also of interest is how you might be using GPS to successfully avoid airspace violations. Other hypothesis are also welcome. Thanks, John Bell www.cockpitgps.com Here is my hypothesis: I have already mentioned in my discussion of database currency that you should set up a routing around any airspace and check it with a current chart before flight. Even with a current database, it is possible for the GPS to get you into trouble with airspaces. Aviation receivers can be setup to display airspace boundaries and to give warnings before entering certain airspace classifications such as category B airspace. These warnings can be a great benefit or a nuisance depending on the type of flying that you are doing. Thus, most receivers allow you to turn them on or off. Additionally, which boundaries will display and at wh at point of zooming out they will disappear can be set. The ability to make these settings is a good feature and I would not want to see this changed. However, it is possible to have the GPS not display or not warn of an impending airspace violation if you have the GPS set up incorrectly for the mission. Even if the airspace boundary is displayed, it is often difficult to decide what boundary a given line applies to. On the Garmin aviation receivers it is possible to cursor over the point to get a description. On a handheld GPS just press the rocker pad up, down, left, or right to start moving the cursor. On the GPS 400 and 500 series, press in on the knob and then start moving the cursor. Move the cursor to highlight the line and press the ENTER button to get information on the airspace. This is a great feature at the planning stage and is occasionally useful in flight. When you have preplanned the route and have a route line, the context of the border is obvious. However, I think that it is possible to confuse borders and violate airspace without first creating a route using a chart before flight. |
On Thu, 30 Oct 2003 19:08:37 GMT, "John Bell"
wrote in Message-Id: : Other hypothesis are also welcome. It is imperative that a pilot maintain situational awareness at all times. The responsibility is his alone. GPS is a valuable aid. The pilot who relies upon GPS exclusively to provide situational awareness soon learns that won't work; it only provides positional information (and speed). Situational awareness encompasses a great deal more.... |
Many GPS and MFD displays are too crummy to be of any real use in avoiding
airspace. The Bendix-King displays are among the worst. Even the color MFD display is only half VGA quality and uses magenta lines for everything from depicting airspace to the flight planned route. It is very easy to mistake an airspace line for something else with this unit. Also, most displays cannot draw curved lines very well, so when you zoom into a lot of class B you discover that instead of a circle it is a complex polygon. I think the biggest troublemaker is the 'nearest' function on most GPS units. The pilot punches in 'nearest' thinking that is the airport he wants to go to when in fact the GPS selects some other waypoint. The pilot is busy and does not do a good job of checking. Another troublemaker is the flight plan route function. The pilot either leaves out an intermediate waypoint or enters an incorrect one with the same or a similar identifier, then follows the courseline right into airspace where he does not belong. Another problem is not clearing out an old flight plan before entering a new one. This is especially common on GPS units like the King KLN 94. A pilot will select direct to an airport without clearing the flight plan entered in a previous flight. When he wants to fly an approach, he presses PROC, selects the approach, and appends it to the old flight plan. Then he does not activate the approach and the next thing you know he has wandered off 180 degrees from where he should be. Getting confused on whether the CDI is displaying NAV or GPS information is another source of trouble. Pilots also blunder into airspace because they are fooling around with the GPS instead of paying attention to what they are doing. They are particularly likely to do this if the GPS goes off line for some reason. It is an especially serious problem with handheld GPS. Then there are outright database errors. Jeppesen mis-plotted some class B airspace a few months ago and someone posted just recently that Jeppesen missed that the Savannah VOR had been moved. Of course, most airspace violations are of things like the Washington ADIZ and TFRs, which are not in most GPS databases, depicted on any charts, or otherwise easily accessible. In fact, even the FAA is unable to plot many of these TFRs accurately. Many TFRs give as their center both a lat/long and a radial/DME, which may be a mile or more apart -- this is a big deal when you consider that a TFR may be only three miles in radius. Additionally, TFRs may change size, shape and duration with little or no notice, long after the pilot has taken off. The best navigation techniques in the world will not help you with that. The fundamental problem that I see the most is that pilots just get behind the airplane. Instead of setting up the GPS in advance, they wait until the last minute, attempting to do things like set up an approach as they enter the final approach course. It gets pretty wild watching students do that. Then they panic, wander off course, and get into airspace. I do not claim to have made all these mistakes myself, of course. |
Bingo...
"C J Campbell" Pilots also blunder into airspace because they are fooling around with the GPS instead of paying attention to what they are doing. |
CJ, Thanks very much for the response. Your perspective is very illuminating and confirms many of my suspicions and observations. I often fly over near Washington, D.C. I can't tell you how many times that I have heard the authorities trying to raise an aircraft that has violated the Washington ADIZ on 121.5. The same aircraft that is violating the airspace are usually not monitoring 121.5. Usually, it is a futile broadcast in the blind. In fact I have never heard a response from an errant aircraft. Thanks everybody else for your responses also. --John Bell www.cockpitgps.com |
errant aircraft. The response, had it been audible, probably would have been along the lines of: "I may be errant, but I'm not stupid!" all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"John Bell" wrote in message om... It appears that a lot of pilots are violating airspace even with GPS on board. I would like to hear some feedback as to how pilots are violating airspace with GPS. I address this in my online book, www.cockpitgps.com. I have my hypothesis, but I would like to hear your experience or scenarios that you have heard involving this issue. Also of interest is how you might be using GPS to successfully avoid airspace violations. Other hypothesis are also welcome. Thanks, John Bell I've had a couple of *near misses* with airspace. The first time, my GPS database was outdated, and I realized fairly late that the paper map didn't show the same thing the GPS map showed. The controlled airspace had expanded from a 5(?) radius around Montgomery, Ala to 10 (?) miles, and my GPS had the old data. I looked and looked at the map thinking "that's a bigger circle than what shows on the magic box"... Then I put a scale on the map and realized that my eyeball was correct. I was close enough that evasive action was necessary. Another time, I was climbing around a series of clouds in a scattered/broken layer, reached "on-top" and realized that I was surprisingly near Atlanta's Class "C". Again, I had to make a course correction to avoid the airspace. Obviously, I focused too hard to pick the best route around the clouds, and didn't focus enough on my actual position relative to the airspace... KB |
Interesting timing ...
At present I'm trying (without much success) to investigate an apparent anomoly where my GPSMAP 295 (with latest database and firmware) is steadfastly refusing to acknowledge some of our controlled airspace - and is yet quite happy to display adjacent controlled airspace. As it stands at the moment with my GPS I could quite happily fly into the middle of the Nelson TMA and not have the GPS give any indication of being in any kind of controlled airspace. See my post from yesterday if anyone is able to help us resolve this (no replies to date) Cheers, Colin "John Bell" wrote in message om... It appears that a lot of pilots are violating airspace even with GPS on board. I would like to hear some feedback as to how pilots are violating airspace with GPS. I address this in my online book, www.cockpitgps.com. I have my hypothesis, but I would like to hear your experience or scenarios that you have heard involving this issue. Also of interest is how you might be using GPS to successfully avoid airspace violations. Other hypothesis are also welcome. Thanks, John Bell www.cockpitgps.com Here is my hypothesis: I have already mentioned in my discussion of database currency that you should set up a routing around any airspace and check it with a current chart before flight. Even with a current database, it is possible for the GPS to get you into trouble with airspaces. Aviation receivers can be setup to display airspace boundaries and to give warnings before entering certain airspace classifications such as category B airspace. These warnings can be a great benefit or a nuisance depending on the type of flying that you are doing. Thus, most receivers allow you to turn them on or off. Additionally, which boundaries will display and at what point of zooming out they will disappear can be set. The ability to make these settings is a good feature and I would not want to see this changed. However, it is possible to have the GPS not display or not warn of an impending airspace violation if you have the GPS set up incorrectly for the mission. Even if the airspace boundary is displayed, it is often difficult to decide what boundary a given line applies to. On the Garmin aviation receivers it is possible to cursor over the point to get a description. On a handheld GPS just press the rocker pad up, down, left, or right to start moving the cursor. On the GPS 400 and 500 series, press in on the knob and then start moving the cursor. Move the cursor to highlight the line and press the ENTER button to get information on the airspace. This is a great feature at the planning stage and is occasionally useful in flight. When you have preplanned the route and have a route line, the context of the border is obvious. However, I think that it is possible to confuse borders and violate airspace without first creating a route using a chart before flight. |
The biggest problem appears to be when the pilot has the Zoom level too
tight and they can't see all the rings and miss read one level for another. Kobra "John Bell" wrote in message om... It appears that a lot of pilots are violating airspace even with GPS on board. I would like to hear some feedback as to how pilots are violating airspace with GPS. I address this in my online book, www.cockpitgps.com. I have my hypothesis, but I would like to hear your experience or scenarios that you have heard involving this issue. Also of interest is how you might be using GPS to successfully avoid airspace violations. Other hypothesis are also welcome. Thanks, John Bell www.cockpitgps.com Here is my hypothesis: I have already mentioned in my discussion of database currency that you should set up a routing around any airspace and check it with a current chart before flight. Even with a current database, it is possible for the GPS to get you into trouble with airspaces. Aviation receivers can be setup to display airspace boundaries and to give warnings before entering certain airspace classifications such as category B airspace. These warnings can be a great benefit or a nuisance depending on the type of flying that you are doing. Thus, most receivers allow you to turn them on or off. Additionally, which boundaries will display and at what point of zooming out they will disappear can be set. The ability to make these settings is a good feature and I would not want to see this changed. However, it is possible to have the GPS not display or not warn of an impending airspace violation if you have the GPS set up incorrectly for the mission. Even if the airspace boundary is displayed, it is often difficult to decide what boundary a given line applies to. On the Garmin aviation receivers it is possible to cursor over the point to get a description. On a handheld GPS just press the rocker pad up, down, left, or right to start moving the cursor. On the GPS 400 and 500 series, press in on the knob and then start moving the cursor. Move the cursor to highlight the line and press the ENTER button to get information on the airspace. This is a great feature at the planning stage and is occasionally useful in flight. When you have preplanned the route and have a route line, the context of the border is obvious. However, I think that it is possible to confuse borders and violate airspace without first creating a route using a chart before flight. |
| Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 03:29 AM |
| most of eastern Massachussetts airspace closed in July | Christopher C. Stacy | Instrument Flight Rules | 29 | June 19th 04 01:47 AM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? | steve mew | Piloting | 38 | October 28th 03 07:08 PM |
| FA: Congested Airspace: A Pilot's Guide | The Ink Company | Aviation Marketplace | 0 | August 10th 03 06:51 PM |
