"Koopas Ly" wrote in message
m... Is this "weathervaning effect" caused by your leftward relative motion due to the left bank OR by the rightward crosswind ITSELF? Personally, I think that the former applies. Yes, the former applies. It doesn't have anything to do with the crosswind, and has everything to do with the airplane's sideways motion through the airmass. The vertical stabilizer tends to orient the airplane into the relative wind, and in a slip, you are trying to maintain an orientation at an angle to the relative wind. Rudder is necessary to counteract the vertical stabilizer's normal force. (Oversimplifying, of course, since there are other forces involved that act in a variety of directions, including both with and against your rudder input). Next thing I was wondering, which is related to the above: say you're dead on centerline on landing, and all of a sudden a crosswind from the left starts blowing. The effect would be that you should only be displaced to the right of runway centerline. Your airplane nose would still be parallel to the centerline. Do you agree? I disagree. Because of inertia, a change in the air mass's momentum will momentarily not be compensated for by the airplane's configuration. Until the airplane "catches up" with the air mass, the relative wind is from the left, and will cause a temporary yaw force turning the airplane to the left. The force will gradually diminish as the airplane accelerates in the direction of the new movement of the airmass. The airplane will remain in this orientation unless the pilot adjust for it (and of course, the pilot most likely will). Pete |
"Robert Moore" wrote in message
. 7... There is NO weathervaning effect until the wheels touch the ground. Of course there is. There is "weathervaning" any time the relative wind is not parallel to the longitudinal axis. Banking an airplane (putting a wing down) causes it to turn. Actually, in some aircraft, banking an airplane causes it to turn in a direction *opposite* of the bank. Rudder is necessary in a turn, to make sure the turn is coordinated and is as efficient as possible. Many airplanes, without the use of rudder, will simply slip sideways without any change in heading at all. You use opposite rudder simply to keep it from turning due to the bank. That's one way to look at it. But think about why the airplane is turning due to the bank. The yaw occurs because bank alone causes a slip, which causes the relative wind to come from an angle to the vertical stabilizer, which causes yaw. That yaw can be described as "weathervaning" and the rudder is used to counteract it. Pete |
"Peter Duniho" writes:
Actually, in some aircraft, banking an airplane causes it to turn in a direction *opposite* of the bank. Rudder is necessary in a turn, to make sure the turn is coordinated and is as efficient as possible. Many airplanes, without the use of rudder, will simply slip sideways without any change in heading at all. That would require extremely draggy ailerons. I know that some planes turn sloppy without rudder, but what planes don't change heading at all? Gliders? All the best, David |
David Megginson wrote: That would require extremely draggy ailerons. I know that some planes turn sloppy without rudder, but what planes don't change heading at all? Maules, for one. Give mine aileron and no rudder, and she will quite happily fly sideways on the same heading. Something about "adverse yaw"? George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
"G.R. Patterson III" writes:
Maules, for one. Give mine aileron and no rudder, and she will quite happily fly sideways on the same heading. Something about "adverse yaw"? At what bank angle, and for how long? With very draggy ailerons, I can imagine that there might be one bank angle where drag from the aileron on the high wing exactly counteracted the weathervaning tendency of the plane, but it would be amazing if that were true of every bank angle up to 30 deg (for example). All the best, David |
"David Megginson" wrote in message
... That would require extremely draggy ailerons. I know that some planes turn sloppy without rudder, but what planes don't change heading at all? Gliders? Gliders are the most common, most dramatic example, yes. And it's true that even most of the "worst behaved" airplanes probably will eventually get around to changing heading. But those that do, may still take a while to get around to it, and even a "well behaved" airplane can demonstrate adverse yaw. Just put in a bunch of aileron input without using the rudder and note the heading change on the DG as the bank occurs. If you want to find an airplane that just keeps on slipping without turning, I'd guess that airplanes like a Pitts or some fighter jets would be good examples. I know for a fact that the Marchetti SF260 is a good example, but haven't had a chance to fly other aircraft with similar characteristics. Generally speaking, less stable aircraft are more likely to not bother to yaw in the direction of the slip, by definition. Probably for the vast majority of airplanes, saying that they simply won't ever change heading is an overstatement, I admit. But many will turn opposite the bank, and many will take a VERY long time to make any significant heading change. Pete |
"Peter Duniho" wrote
Of course there is. There is "weathervaning" any time the relative wind is not parallel to the longitudinal axis. But I think that the discussion was weathervaning into the actual wind, not the relative wind. If I bank away from the wind, does the airplane then weathervane into or away from the wind? The only thing that can cause the airplane to weathervane into the actual wind is for the wheels to be in contact with the ground. Without the pivot, a weathervane doesn't weathervane. Bob |
To weathervane, you need differential force. A steady wind while on the ground
allows such a force to develop. A steady wind in the air does not. However, a gust in the air does (the resistance would be due to inertia, and centered at the center of gravity). Jose -- (for Email, make the obvious changes in my address) |
