diesel 160-200HP engines
Old March 28th 04, 06:31 AM
jpollard###mnsi.net
On Fri, 26 Mar 2004 22:26:50 -0600, Dave Driscoll
I'd be happy to answer any questions that
people may have regarding the project.
Hi Dave
How do you get a diesel restarted in the air if you happen
to have multiple fuel tanks and run one dry so the injection
system gets air in it? Is there a way around this problem?
Old March 29th 04, 01:26 AM
Dave Driscoll
Jim,
The engine is designed to be fairly fault tolerant of air bubbles in the
low pressure fuel lines (the returns from the pump element gallery are
positioned above the high pressure gallery inlet etc.) and will continue
to deliver solid fuel through the high pressure lines even with bubbles
in the low pressure ones. It will also repurge the high pressure lines
even in the event that you run them completely dry. You simply have to
reintroduce fuel to the system and keep spinning the prop at greater
than 150 rpm. How long it takes for a restart is based upon how dry the
system was and how fast you can spin the prop. This however is not a
good practice as the high pressure pumps will be operating without
lubrication on the top side until the fuel is reintroduced. The
collective thoughts of the group are that you can certainly get away
with it a couple of times, but better be thinking about inspecting the
high pressure plungers after the 2nd full dry restart.
Dave Driscoll
DeltaHawk LLC
Hi Dave
Old March 29th 04, 08:16 PM
Dan Youngquist
On Sun, 28 Mar 2004, Dave Driscoll wrote:
This however is not a good practice as the high pressure pumps will be
operating without lubrication on the top side until the fuel is
reintroduced. The collective thoughts of the group are that you can
certainly get away with it a couple of times, but better be thinking
about inspecting the high pressure plungers after the 2nd full dry
restart.
Most of my diesel experience is with engines using Stanadyne DB2 injection
pumps. Stanadyne makes what they call an "Arctic kit" for this pump that
makes it insensitive to fuel lubricity by, if I understand correctly,
changing the material of some parts so any fuel, even gasoline, can be
used without damage to the injection pump. I've always wondered why they
don't make all the pumps that way to begin with; maybe there's a downside
I'm not aware of. Why doesn't DeltaHawk set up the injection pump that
way? Speaking strictly as a layman, it seems it would solve the run-dry
damage problem, as well as providing some emergency fuel flexibility.
-Dan
Old March 30th 04, 12:36 AM
Dave Driscoll
Dan,
The DB2 is a little different animal than what we use on the DeltaHawk.
The DeltaHawk uses an independent, high pressure, plunger style pump
element for each cylinder. These run at significantly higher pressure
than the DB2 and also allow for redundancy in that the failure of a
single pump element will only take out a cylinder not the entire fuel
system. While in the DeltaHawk application there are some significant
advantages to the plunger style pump, what is commercially available in
this style of pump is not as fault tolerant to fuel lubrisity as the
DB2. However, although we currently use an off the shelf element, there
are some improvements that can be realized when volumes will allow us to
create a high pressure injection pump tailored to our specific
application. The long and short of things, with the current pump is
that while repriming once or twice isn't going to destroy the engine, it
isn't something that should become routine.
Dave Driscoll
DeltaHawk LLC
restart.
-Dan
Old April 1st 04, 03:15 AM
Scott Gettings
Great concept for an engine with many advantages, but the weight will probably
exceed the aft CG limits for a Glass Goose. $31K is also very expensive. The
Jabiru 180 hp, Mazda 13B may be better solutions for something more powerful
than an 0-320.
Scott Gettings
All,
In addition to being an lurker and occasional poster on RAH, I also
happen to be one of the engineers responsible for the DeltaHawk (or the
sole reason the engine hasn't been in full production for the last 3
years according to the marketing guy). In any case, as this is one of
my few areas of RAH expertise, I'd be happy to answer any questions that
The web site
www.deltahawkengines.com
is generally pretty up to date, but there are certainly always specific
questions that a FAQ won't answer.
Dave Driscoll
DeltaHawk LLC
geo wrote:
Here's an interesting new diesel engine with much lower operating costs.
Looks like it would fill the bill for a Glass Goose (which I'm considering)
very nicely. Waddya think? http://www.deltahawkengines.com/object00.htm
Old April 2nd 04, 05:27 PM
Pete Schaefer
Yup. I'm penciling the inverted 180hp model in for an RV-8A right now (I
like the significantly better price point than that 200hp model). But, if
the 200 gets certified and the insurance benefit makes it more economical
over the long haul.....vroom! Fortuantely, it will be about 2 years before I
place my order, so plenty of time for DH to ring things out. Things should
time out nicely for me.
"Regnirps" wrote in message
If they can live up to their claims, the 200hp engine pays for itself in
fuel
and plug savings in the first 2,000 hours (and no weight penalty). If they
make
it, I'm picturing one in a Vans RV-8.....
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 05:04 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 01:44 AM
