Recording your flight time
Old December 21st 03, 07:53 PM
Teacherjh
14CFR Part 1
Sec 1.1
Flight time means:
(1) Pilot time that commences when an aircraft moves under its own
power for the purpose of flight and ends when the aircraft comes to rest
after landing; or
Ok, so I'm at Dulles. I start up, release the brakes, and start the timer.
Start taxiing (it takes forever at Dulles), do my runup, am sixteenth behind a
row of jumbos, have to hold a while for IFR release, andforty minutes later the
tower tells me position and hold. (not too far off for some flights!).
Cleared for takeoff, I accelerate to flying speed, but something isn't right,
so I abort the takeoff and taxi back to the ramp and shut down.
It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it
if you actually managed to get three feet in the air for twelve seconds before
aborting the takeoff and landing again on the mile of runway remaining?
Jose
Old December 22nd 03, 03:07 AM
Tom Sixkiller
"Ron Rosenfeld" wrote in message
On Sun, 21 Dec 2003 11:00:59 -0800, A Lieberman
I could'nt find anything in the FARS for "when" to start counting, but I
am under the impression from my experiences, that anytime the prop is
turning is the time you count.
You didn't look at the beginning:
14CFR Part 1
Sec 1.1
Flight time means:
after landing; or
(2) For a glider without self-launch capability, pilot time that
commences when the glider is towed for the purpose of flight and ends when
the glider comes to rest after landing.
For most people with a Hobbs, that could be an extra half hour, from master
switch "ON", to shutdown.
I wonder: does ANYONE does it that way?
Old December 22nd 03, 05:32 AM
Newps
I do. My Hobbs does not have an oil pressure switch, it starts counting
from Master On. A typical roundtrip breakfast flight will have .2 taxi
time to the runway.
Old December 21st 03, 08:22 PM
Ron Natalie
"A Lieberman" wrote in message ...
At what point can one start recording _Flight Time_? Engine start? First
master switch?
Flight time is defined in part 1.
Old December 22nd 03, 03:02 AM
Tom Sixkiller
master switch?
That's about what I've always used; from engine startup.
Old December 21st 03, 08:21 PM
Ron Natalie
"Tom Sixkiller" wrote in message ...
master switch?
Since we are talking pilot time (we have bounced back and forth here), the
rules say: elapsed time form the time the aircraft first moves under its
own power for the purpose of flight until the time it comes to rest at
its . Since my plane rears forward a little bit at engine
start, and I don't tend to run it for very long when I finally get fully
parked, the ENGINE RUNNING (hobbs) time is usually pretty danged
close to the definition.
Old December 22nd 03, 03:10 AM
Tom Sixkiller
"Ron Natalie" wrote in message
m...
master switch?
I remember, several years back, a lot of pilots would do their engine start,
and THEN do their ATIS, CD, Ground...
Too expensive to do it that way except for the corporate jocks, big iron...
Old December 21st 03, 06:27 PM
BTIZ
I have always used either my watch (no hobbs) or if equipped .. the hobbs...
one should only apply the 1.3factor to straight tach time.
BT
"Jay Honeck" wrote in message
news:7oiFb.618964$Fm2.558042@attbi_s04...
With built-in flight timers becoming the norm in virtually all new
avionics
(heck, even the new transponder I'm getting has one), just wondering if
folks are migrating away from using hobbs/tach time to record their flight
time?
And if you *are* using the flight timer, have you stopped using the old
archaic "1.3 hours" method of recording flight time? Anyone using actual
hours and minutes in their logbook instead?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 21st 03, 06:32 PM
Bob Noel
In article 7oiFb.618964$Fm2.558042@attbi_s04, "Jay Honeck"
avionics
flight
time?
I record engine start to engine stop (excluding the taxi time
rom the pump back to my hangar).
Bob Noel
Old December 21st 03, 07:52 PM
Robert M. Gary
"Jay Honeck" wrote in message news:7oiFb.618964$Fm2.558042@attbi_s04...
With built-in flight timers becoming the norm in virtually all new avionics
time?
I can't think of any reason to stop using the hobbs. I don't have to
leave the avionics on after the flight to check the GPS time, the
hobbs is always right there as I'm closing the door. I also use my
hobbs to track the time I've spend on each tank (even though I have an
EDM fuel flow computer). The hobbs seems like a perfect, simple
device.
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 03:16 PM
p3/95 [email protected] Military Aviation 1 September 27th 04 01:27 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
