Blanche wrote in message ...
My worst complaint is the pilot (not from the area) who insists on doing a left pattern when the AF/D and the sectionals all explicitly state right pattern. Why? Because FTG is cozy in the SE corner of DEN's class B. A mile west or a mile north, and you're violating the Class B surfact airspace. Similar situation at our home airport. Left traffic for two of the runways snugs you up very close to Class B. And when the pilot is reminded about the right traffic, he (why is it *always* a man?) responds "not in my book!" *hee* *hee* Is there a directional indicator around the windsock? I'd have trouble not responding "see those little yellow thingies circling the windsock down there?" Yeah, and then there's published TPA of 800 ft but all the planes who insist on flying at 1000. Cheers, Sydney |
Whenever I am flying at a non-controlled airport, my primary runway will be
the one appropriate to the direction of the wind. If the wind changes, I will change. Also if I hear other aircraft still making for the "original" runway, I will advise them of the wind/preferred runway change. If I want to do some x-wind landing practice on a different runway from the preferred, I will clearly announce my intentions and what runway I will be using. However, I always make sure that I do not interfere with other pilots. Needless to say my outside scanning becomes much more intense in this situation; you never know when an airplane will be NORDO. Also, if the airport is busy on that particular day, I will defer my practices until another time. I'm not necessarily offering that as a suggestion, it's just the way I prefer. So far it has worked real well :-). Harry PP-ASEL "Snowbird" wrote in message om... What's the general viewpoint here? A non-towered airport near us has two runways, shaped like an "L". Totally flat, no obstructions to vision-- airplane at the departure end for one can see airplanes at the other. Left traffic both, so the downwind for the short runway crosses the longer runway at midfield. The possible conflict points are simultaneous T/O, or crosswind for the short runway/downwind for the long. Today at that airport, one aircraft was in the pattern for the shorter runway, which the wind favored. I wanted to use the longer runway for various reasons, so exercising a sharp look-out and making my radio calls, I proceded to do so. Later another plane joined him. There were no conflicts AFAIK. Everyone was doing a good job making transmissions and keeping track of each other. It was a good exercise for me since our new home airport has a similar setup with both runways frequently in use -- and the added complication of right traffic in one direction, left in the other. I'm still getting used to it. When a fourth aircraft called in, I decided the spatial relationships were getting complicated and taxied over to the short run way, did one short field landing which my instructor would have liked and I didn't (power on), and headed for the horizon. Question is: how would most pilots here feel about this? Would you feel I should have just joined with traffic for the shorter runway? In terms of my plane's capabilities and mine, it's plenty of runway, no reason why not. It just wasn't what I preferred initially. I used to be based at that airport and it wasn't uncommon, if I was in the pattern for the short runway, to have other planes land on the long. It never bothered me except when someone came straight-in and obviously had no idea where the rest of the traffic was. But one of the planes in the pattern seemed to indicate, um, let's say displeasure with me. That doesn't concern me -- people have to say whatever they feel improves safety and presents them in a professional light, *hee* *hee*, and I kept my rule of "don't argue on freq. just don't and say you didn't" However I figure I should ask for a sanity-check on whether what's SOP at home is regarded as inappropriate or rude elsewhere. Cheers, Sydney |
"Harry Gordon" wrote in message ...
Whenever I am flying at a non-controlled airport, my primary runway will be the one appropriate to the direction of the wind. If the wind changes, I will change. What if others are still using the "original" runway? If I want to do some x-wind landing practice on a different runway from the preferred, I will clearly announce my intentions Not meaning to pick, just curious: do you really announce "Pepsi County traffic, Cessna 12345 entering left downwind for 34 for crosswind landing practice" or some such? My personal tick on UNICOM is not being able to make necessary traffic calls in a timely manner because someone is taking up the frequency with a lengthy announcement full of unnecessary information. Of course, students gotta learn, but it's often not students I hear doing it. Needless to say my outside scanning becomes much more intense in this situation; you never know when an airplane will be NORDO. Just to point out that your outside scanning should be IMHO as intense as you can make it at all times. You never know when a NORDO aircraft is going to perceive an operational advantage in using a different runway than you prefer, at any time. You also never know when someone is going to say one thing and show up somewhere else. I have to admit I'm usually not directionally challenged but I've been known to make directionally-challenged radio calls myself. Also, if the airport is busy on that particular day, I will defer my practices until another time. Well, how do you define busy? One other aircraft? Two? Four? Seven? Cheers, Sydney |
Whenever I am flying at a non-controlled airport, my primary runway will be the one appropriate to the direction of the wind. If the wind changes, I will change. What if others are still using the "original" runway? One of the "problems" with posting to newsgroups is if you leave something out, it is automatically assumed the writer doesn't do it :-). Thus far, when that situation has occurred, and the other aircraft haven't made the adjustment, I will broadcast a CTAF message about the wind/runway change. Thus far the other aircraft have all followed suit and adjusted to the new runway. I haven't had the "opportunity" of someone refusing to change. If I want to do some x-wind landing practice on a different runway from the preferred, I will clearly announce my intentions Not meaning to pick, just curious: do you really announce "Pepsi County traffic, Cessna 12345 entering left downwind for 34 for crosswind landing practice" or some such? Yes. That is exactly what I do when 34 is NOT the desired runway for the given wind direction. I would rather use an extra 2 seconds of air time and avoid a potiential problem. My personal tick on UNICOM is not being able to make necessary traffic calls in a timely manner because someone is taking up the frequency with a lengthy announcement full of unnecessary information. Of course, students gotta learn, but it's often not students I hear doing it. Where I fly, the radio "problems" I have encountered isn't so much a long winded pilot but having to put up with the radio traffic coming from other uncontrolled airports :-(. About the only time I get frustrated with the radio traffic is going into a Class-C airspace and the controllers are so busy I have to go into a "holding pattern" while waiting to establish communications with them. Needless to say my outside scanning becomes much more intense in this situation; you never know when an airplane will be NORDO. Just to point out that your outside scanning should be IMHO as intense as you can make it at all times. See, there you go trying to read between the lines :-)). One day, I had a C172 take the runway for departure AFTER I had announced turning final for that runway. I had to do a go-around. Trust me, I am ALWAYS watching. :-) You never know when a NORDO aircraft is going to perceive an operational advantage in using a different runway than you prefer, at any time. You also never know when someone is going to say one thing and show up somewhere else. I have to admit I'm usually not directionally challenged but I've been known to make directionally-challenged radio calls myself. You too??? :-) At least I don't feel like the Lone Ranger now. I still have a hard time deciding if I am approaching from the S.E., N.W., S.W., etc. Also, if the airport is busy on that particular day, I will defer my practices until another time. Well, how do you define busy? One other aircraft? Two? Four? Seven? That is a hard question to answer. I just depends on what the other aircraft are doing. I have left the area with 2 in the pattern and have stayed with as many as 5. But, if it is "busy" I will not deviate from the pattern that the others are using. When I was a student, our practice area wasn't too far from the uncontrolled airport we would practice our landings/TOs. What I would do is fly over to the practice area for some other practice and then return back to the airport when the other aircraft went home. Sydney, where to you fligh out of primarily? Happy flying, Harry |
Whenever I am flying at a non-controlled airport, my primary runway will be the one appropriate to the direction of the wind. If the wind changes, I will change. What if others are still using the "original" runway? One of the "problems" with posting to newsgroups is if you leave something out, it is automatically assumed the writer doesn't do it :-). Thus far, when that situation has occurred, and the other aircraft haven't made the adjustment, I will broadcast a CTAF message about the wind/runway change. Perhaps I'm not clear enough on the scenario I'm thinking of. I'm not thinking of you being the guy "established" in the pattern, but rather of the following scenario: You are approaching a non-towered airport. There are several aircraft in the pattern for runway 18, happily making circuits. You observe that the wind actually favors runway 27. Are you saying you approach the airport with an announcement "Podunk traffic, Cessna 1234, the wind appears to favor runway 27, so that should be the active runway now" or something to that effect (what exactly would you say?) and so far, everyone just changes to runway 27 and you join them? Or are you saying you'd broadcast that you're landing on 27 because that's the runway the wind favors, and everyone else would break off their pattern and follow you? Yes. That is exactly what I do when 34 is NOT the desired runway for the given wind direction. I would rather use an extra 2 seconds of air time and avoid a potiential problem. OK, now I'm curious here again. How do you see broadcasting your reasons for choosing the runway you are using as "avoiding a potential problem"? Needless to say my outside scanning becomes much more intense in this situation; you never know when an airplane will be NORDO. Just to point out that your outside scanning should be IMHO as intense as you can make it at all times. See, there you go trying to read between the lines :-)). Um, Harry -- no offense intended here, but when you say "my outside scanning becomes much more intense in this situation", I don't think there's much reading between the lines going on on my part. Perhaps you need to adjust what you write, to better match what you mean? My point is, I don't think it's a situation calling for a beyond-normal level of alertness, because it's a situation which could always be occuring without notice. You too??? :-) At least I don't feel like the Lone Ranger now. I still have a hard time deciding if I am approaching from the S.E., N.W., S.W., etc. Me too. Actually I know what direction I'm approaching from but my brain has been known to disengage before the words emerge from my mouth "southeast--um, sorry, no, northwest--" (and there I go, exhibiting the peeve my fingers warned us against) It's a consistant trait of mine, I mis-speak in other walks of life. I would make a horrible ATCS, or any other profession which had to talk for a living! Cheers, Sydney |
Perhaps I'm not clear enough on the scenario I'm thinking of. I'm not thinking of you being the guy "established" in the pattern, but rather of the following scenario: You are approaching a non-towered airport. There are several aircraft in the pattern for runway 18, happily making circuits. You observe that the wind actually favors runway 27. Are you saying you approach the airport with an announcement "Podunk traffic, Cessna 1234, the wind appears to favor runway 27, so that should be the active runway now" or something to that effect (what exactly would you say?) and so far, everyone just changes to runway 27 and you join them? Or are you saying you'd broadcast that you're landing on 27 because that's the runway the wind favors, and everyone else would break off their pattern and follow you? When I or others have announced a wind change, there has never been an issue about switching to another runway. Communications are brief and contain the relative information: "Podunk traffic, Cessna 1234, new wind direction 250, perferred runway now 27, Podunk." Thus far, no one has refused to adjust their pattern to the new runway. In fact, I have seen pilots turn their planes around on the ground and taxi to another runway because of a wind change that was announced by another pilot. OK, now I'm curious here again. How do you see broadcasting your reasons for choosing the runway you are using as "avoiding a potential problem"? Remember, you broadcast your position, intentions, etc., regardless of whether or not there are other aircraft in the pattern. The reason I broadcast my message is to eliminate the possible confusion (maybe I should have used that word rather than "problem") over an airplane approaching the field who has listened to AWOS, obtained the wind direction and determined what runway they will be using. And then when they switch to CTAF have them hear me using a different runway. It also gives them the ability to contact me if they so desire. And be assured that I NEVER us a non-preferred runway for x-wind practice when other aircraft are using the field (of course if they are NORAD, then I can't respond to their approaching until I see them.) Perhaps I need to say this since we don't know each other. I consider myself a very "sky friendly" pilot. When I fly, I fly with other pilots in the sky. I will not do anything that jeperdizes either their safety nor mine - at least intentionally :-). I guess I am becoming confused over whether your challenging what I do or if you're looking for rationale for making your flying experiences better. See, there you go trying to read between the lines :-)). .... Perhaps you need to adjust what you write, to better match what you mean? Perhaps your right. Before I retired I spent over 35 years in jobs requiring intensive writing skills, you would think that I could be a little clearer wouldn't you? :-). I guess the problem with communicating in these newsgroups is the fundmental principle of written/verbal communications - know your audience and then taylor your communications to that audience. No two people who post to this newsgroup have the same background. Everyone is different. Some are very young and some are retired; some are fresh students and others have tens-of-thousands of flying hours and hold every rating in the book, not to mention those in between; some have great communication skills, others..., well you get the idea. Added to that is the frame-of-mind the writer/reader is in at the time the writting/reading takes place. That frame-of-mind will determine the inflection given to words as they are written/read (that is referred to as tone-of-font). What the reader perceives as the "tone" may not in any way reflect that of the writer's. Unfortunately, the definition of communications is not what is written or said but what is perceived by the receiver to have been written or said. I hope we're communicating. :-) Harry |
My pet peeve is the motormouth types who clog the CTAF with
personal chatter that has little or nothing to do with the safety of flight. Some of these folks aren't even flying - and seem to think the CTAF is a personal CB channel. The temptation to become "voluntary NORDO" is quite strong at the airport I have in mind. Equally annoying is the Class C scenario in which you can't get a word in edgewise due to the congestion on frequency. Sometimes it is simply too many aircraft coming and going at once. Other times there is the stuck mike or the pilot with a limited command of English, or somebody who takes 100 words to say what a the average person could say in ten. David Johnson |
However I figure I should ask for a sanity-check on whether what's SOP at home is regarded as inappropriate or rude elsewhere. Sanity is hereby checked, Sydney. You went with the flow as soon as a flow made itself evident. If that wasn't fast enough for the pilot of the plane that fussed, that aint' your problem. -- Jim Fisher |
| Thread Tools | |
| Display Modes | |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 06:35 PM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 05:02 PM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Piloting | 16 | January 20th 04 05:02 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
