"Dudley Henriques" wrote in message
ink.net... "David Brooks" wrote in message ... IIRC, this discussion earlier revealed that the T-bird pilots have super-wizzo-thingummy altimeters that can indeed set QFE at high elevations. Granted, yours and mine can't. -- David Brooks Hi David; The Thunderbirds use a standard altimeter setting for the point of demonstration and do not use a 0 altimeter set. Their maneuver profiles are corrected to MSL altitudes. Stricklin unfortunately on the way up the front side of his maneuver mentally "corrected" his reverse top target gate to Nellis' elevation instead of where he was. This put the Viper way low of where it should have been at the top side commit. He missed his visual cues as well. The airplane simply didn't have the g available vs the altitude under it to cut the corner. Well, yes, I got that. I think that was fairly clear from the descriptions that erupted here a couple of months back. I was merely responding to the assertion that altimeters don't go down that low, and I learned in the earlier thread that the military ones do - not that they use this ability in the shows. I do seem to recall that the pilot makes a call at the top of his pattern to a safety officer - was it of his height AGL? That does seem to be a weak spot in the safety chain; if the pilot is calculating his elevation incorrectly, the call of what he thinks is the value is not much use as a crosscheck. -- David Brooks |
| Setting Up An Airport Trust Fund? | Jay Honeck | Piloting | 4 | February 24th 04 11:54 PM |
| low altimeter and FL180 | Michael 182 | Piloting | 26 | October 31st 03 05:29 AM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
| Prop bolt torque setting | Whunicut | Home Built | 2 | September 4th 03 01:12 PM |
| WOT in cruise? | Roger Long | Owning | 10 | July 28th 03 09:00 AM |
