Handheld Tranceiver Recommendation
Old March 30th 04, 08:12 AM
BTIZ
I have the ICOM A-22, I do not use alkaline batteries.. they only last one
day in glider operations.. I have had my A-22 for 6 years and only had to
replace the battery once, I went from the factory 1000mAhr NiCD to a
1500mAhr NiMH and that was four years ago.
I use the radio all day every weekend, I charge it after every second
weekend. I do carry the AA battery pack in my flight bag for when I forget
to charge, does not happen often. When I did have to use the AA pack, it
only lasted about 5 hours.
When on the ground, I find the A-22 able to reach aircraft about 9-10nm
distant. From the air, I have used the A-22 to talk with approach control
25nm away from a composite glider.
I always use the "rubber ducky" antenna, and I prefer the "at extra expense"
Speaker/Mic to clip to my parachute harness while flying.
I know other pilots who have abandoned the Sporty's model (failure), and
also had problems with the Yeasue (small radios, small battery packs) not
many options.
BT
"nospamPlease" wrote in message
I am thinking of purchasing a hand held radio (tranceiver).
Can anyone recommend one ? I am a student pilot.
Please reply to this newsgroup and not via email.
Old March 31st 04, 12:36 AM
Malcolm Teas
nospamPlease wrote in message ...
I bought the Yaseu/Vertex VXA-700 (The company changed it's name).
It's got the LiON battery with a nice long battery life, it was the
only handheld with a LiON battery when I bought it roughly a year ago.
It's small enough and light enough that I don't hesitate to carry it
- which is the point in a back up radio.
It receives VOR and COMM frequencies, weather radio in the US, and FM
commercial band as well as VHF 2 meter band. (So, if you're in CAP,
it can get their freqs too.)
I bought it when the DC ADIZ was set up, and used it when on a student
cross country with radio problems. Neither comm would work. Pretty
much a serious situation here. I plugged my headset into the handheld
(with the adapter I'd bought with the radio for that purpose) and was
able to re-enter the ADIZ and get back to home base.
(With the wisdom of more hours now, I should have landed outside and
phoned home. But having the extra radio is a good thing these days in
any case.)
Note that any handheld won't work as effectively as the plane's radio
since the antenna's not as good. Altitude helps of course, as does a
relay. I've seen people with their own plane put in an extra antenna
that can be plugged into the handheld too. But, you need your own
plane first... grin
-Malcolm Teas
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 05:01 PM
Terrain-Aware Handheld vs. IFR GPS? C Kingsbury Instrument Flight Rules 7 November 14th 04 06:33 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 04:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
Download GPS Track from Bendix/King handheld Andreas Medlhammer General Aviation 0 August 11th 03 03:50 PM
