I also highly recommend John C Eckalbar's books FLYING THE BEECH BONANZA and FLYING HIGH PERFORMANCE SINGLES AND TWINS These books will describe the relationship between aircraft weight and the various V-speeds you should know when you fly. |
Ge,
here's another vote for the engine management columns by John Deakin at www.avweb.com -- Thomas Borchert (EDDH) |
I think Deakin is worth reading, but some of what he says should be taken
with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. Keeping all that in mind, Deakin's columns are still probably the best exposition on how to use a constant speed propeller. You will note right away that everything is about power and performance. A fair number of people think it is also about fuel economy, but that is at best a secondary consideration. Fuel economy is a natural result of getting maximum power for your fuel burn, but if that were really the goal there would be no turbocharged engines. |
"C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. See above. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. I bellieve they run Lycoming on the test bed as well, everything from pipsqueaks to the big 540's. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. I think GAMI generated enough data on their stand to run a computer dry. http://www.engineteststand.com/ |
On Thu, 24 Jun 2004 09:14:59 -0700, Tom Sixkiller wrote:
"C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. See above. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. I bellieve they run Lycoming on the test bed as well, everything from pipsqueaks to the big 540's. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. I think GAMI generated enough data on their stand to run a computer dry. http://www.engineteststand.com/ Is the data offered in the articles you refer to or is it available on the web site? It does not appear to be jumping out at me. I see a couple of pictures of some graphs, a webring link, and email address, and a link to gami.com. What am I missing? Thanks, Greg |
"Tom Sixkiller" wrote in message ... "C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? I merely point out that his theories are controversial -- they are hardly universally accepted, as even this thread amply demonstrates. As I said, I think he has a point, but I have to consider that the engine manufacturers and aircraft manufacturers might know at least as much about their products as GAMI does. |
"C J Campbell" wrote in message ... "Tom Sixkiller" wrote in message ... "C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? I merely point out that his theories are controversial -- they are hardly universally accepted, as even this thread amply demonstrates. Ah...no, you said he doesn't support his conclusions. Charles "Cory" Scott actually did a very elaborate reply that explains it better than I have the patience for. As I said, I think he has a point, but I have to consider that the engine manufacturers and aircraft manufacturers might know at least as much about their products as GAMI does. You might want to look into that, because the test stand data shows they may not know as much as they pretend. Sounds more to me like the manufacturers are trying to cover their asses for poor quality and potential legal liability. Have you looked at the data that Cory and I pointed you to? |
I merely point out that his theories are controversial -- they are hardly universally accepted, as even this thread amply demonstrates. A thread on usenet demonstrates no such thing. Evolution is hardly controversial within the scientific community, yet it is debated ad nauseam on usenet. Deakin's theories (which are really not his at all, and not really theories) are really no more controversial - in fact, they formed the basis of normal operating practice for piston fighter and airliners for as long as there were piston fighters and airliners. As I said, I think he has a point, but I have to consider that the engine manufacturers and aircraft manufacturers might know at least as much about their products as GAMI does. That was true once, but is true no longer. For all practical purposes, there hasn't been any progress made in piston aircraft engines for decades. Neither Lycoming nor Continental have a design engineering staff anymore. Most of the knowledge has been lost. It's actually fairly common for knowledge to be lost that way. Doing development is fun; documenting it isn't. When the people who did the development move on, a lot is lost. Corporate-mandated processes generally don't help much - they just cause the brightest people to move on sooner. Michael |
Howdy!
In article , C J Campbell wrote: "Tom Sixkiller" wrote in message ... "C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? I merely point out that his theories are controversial -- they are hardly universally accepted, as even this thread amply demonstrates. As I said, I think he has a point, but I have to consider that the engine manufacturers and aircraft manufacturers might know at least as much about their products as GAMI does. No. You do not "merely" point out... You do it in a manner that, intentional or no, suggests that he is blowing smoke up your backside. You further appear to completely disregard the supporting data and arguments, both from GAMI testbeds and from historical operating practices for piston engined aircraft. He does offer credible arguments that the engine manufacturers offer recommendations contrary to good engineering and operating practices. Let's be honest here. yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
"Michael Houghton" wrote in message ... No. You do not "merely" point out... You do it in a manner that, intentional or no, suggests that he is blowing smoke up your backside. You further appear to completely disregard the supporting data and arguments, both from GAMI testbeds and from historical operating practices for piston engined aircraft. He does offer credible arguments that the engine manufacturers offer recommendations contrary to good engineering and operating practices. Let's be honest here. All right, let's be honest. I am not disregarding the data that he as presented in his articles. I will also not disregard the anecdotal evidence that I have from several engine shops that engines consistently run LOP generally do not make TBO, nor do they last as long as engines run according to manufacturers' specifications. When Deakin comes up with hard evidence that applies to anything other than GAMI's special setups then I will welcome it. If there is anything that drives me up the wall, it is these vague references to "historical operating practices." It is really just a substitute for "bull****." |
| PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 05:41 AM |
| Constant speed prop oil leak | DP | Piloting | 23 | April 21st 04 11:15 PM |
| Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 04:41 AM |
| Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 03:42 AM |
| Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 11:08 PM |
