As for that guy who flys a seaplane? There's something even stanger about guys who land on water than those of us who with our tail backwards (M20J). And what makes you think the M20E or M20J has a tail on backwards? Don't you know it's all those others that have it wrong :-)) Let's justy say those of us who drive Mooneys like our tail a little differently than some others. |
Do you do 'running' run-ups?
Yes. If you attend any of the major fly-ins your run-up will be a rolling one. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) "G. Burkhart" wrote in message news:lk6Ec.1801$AI.68@attbi_s04... When I did my training my CFI taught me to stop at the run-up area and go through the run-up checklist. This was done at airports that had run-up areas readily available. Fairly recently, I went with an instructor that taught me to do a run-up during taxi on airports that don't have a run-up area or require back taxi on the runway. Some of the local airstrips have narrow (or no) taxiways and they lead right to the runway with little room to stop to do a run-up so I've gotten into the habit of doing the run-up while taxiing. I make sure to check outside to where I'm going while checking the mag drops, etc. That way I'm ready for departure by the time I get to the runway, which is helpful when others are following behind me on the taxiway, especially during fly-ins. Some airports require back taxi on the runway from the ramp/taxiway and I'll do the (stopped) run-up before getting on the runway or a run-up during the back taxi so I'm ready to go when I turn around for departure. |
"Henry and Debbie McFarland" wrote in message link.net... Do you do 'running' run-ups? Yes. If you attend any of the major fly-ins your run-up will be a rolling one. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) You can add skis and floats to the list that require run-ups on the move. |
one. Amen. If you stop to do a "proper" run-up right before departing OSH (or SNF), you'll have four FAA guys in pink shirts absolutely apoplectic, jumping up and down and waving flags at you! "Rolling" run-ups are sometimes your only option. Many times the traffic gets backed up considerably, however, and you can kinda cock the plane to the side, and do a "real" run-up. Of course, then you get into the discussion of WHEN to do your run-up. If you do a run-up in line, and it's five or ten (or 20?) minutes till you depart, you've lost much of the utility of doing a run-up. Isn't the idea to do the run-up as close to departure as possible, to ensure that the engine and prop are functioning properly at take-off? It's probably my own paranoia, but I try to do my run-up right before fire-walling the throttle so that nothing else has a chance to break in the meantime. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Henry and Debbie McFarland wrote:
Do you do 'running' run-ups? Yes. If you attend any of the major fly-ins your run-up will be a rolling one. I just checked out in a new (to me) club airplane. At some point, I was taxiing and the CFI suggested I do something. I don't recall what it was, but it wasn't one of the items that *must* be done while moving (ie. checking for proper function of the AI, HI, and TC). I reminded him that, if I did as he suggested with a certain other CFI in the club for a checkout, I'd fail. So I guess the right answer is "it depends". - Andrew |
"G. Burkhart" wrote: Do you do 'running' run-ups? No. George Patterson None of us is as dumb as all of us. |
In article lk6Ec.1801$AI.68@attbi_s04,
"G. Burkhart" wrote: Do you do 'running' run-ups? Always. I fly from a turf field....stationary runup is bad for the prop. Once rolling I come up to 1700 for the mag check, then back to idle to control speed.....up to 2000 for a quick prop check. Being on grass the speed doesn't become a big issue...no need to hold brakes during the checks. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Do you do 'running' run-ups? Always. I fly from a turf field....stationary runup is bad for the prop. Once rolling I come up to 1700 for the mag check, then back to idle to control speed.....up to 2000 for a quick prop check. Being on grass the speed doesn't become a big issue...no need to hold brakes during the checks. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. You do mean, don't you, referring to your sign off, subject to the limitation "sith your clothes on"? |
| C-182 carb-heat causing rough running. | R.T. | Owning | 11 | November 26th 04 11:50 PM |
| YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE | Karsten | Home Built | 0 | September 3rd 04 08:34 PM |
| Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 05:56 PM |
| Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 04:46 AM |
