Running runup?
Old June 30th 04, 09:00 AM
Thomas Borchert
Ajw,
You do mean, don't you, referring to your sign off, subject to the limitation
"sith your clothes on"?
Ah, to be young again ;-)
Thomas Borchert (EDDH)
Old June 30th 04, 04:03 PM
G.R. Patterson III
This time with money. :-)
George Patterson
None of us is as dumb as all of us.
Thomas Borchert
Dale,
Always. I fly from a turf field....stationary runup is bad for the
prop.
How? If it were dirt, I might understand, but turf?
Being on
grass the speed doesn't become a big issue...no need to hold brakes
during the checks.
I disagree, strongly. Going with 2000 rpm, our Tobago would move like a
rocket on our turf field.
Old June 30th 04, 06:01 PM
Dale
There's dirt under that grass. Even water can erode a prop, imagine
what dirt or small stones can do.
Dale L. Falk
Old June 30th 04, 06:02 PM
Dale
Have you tried it? Sure, you'll be moving faster than a "walking pace"
taxi, but not so fast as to be a hazard.
Dale L. Falk
Old July 1st 04, 04:01 AM
Newps
"Dale" wrote in message
Have you tried it?
Yes. At 2000 rpm I would accelerating at quite a clip. After a couple
hundred yards I'd be doing in excess of 30 mph.
Old July 1st 04, 04:34 PM
G.R. Patterson III
If I tried to do my runup with no brakes, I'd be airborne before I finished the mag
check.
George Patterson
Old July 1st 04, 05:50 PM
Dale
Good grief, how long does it take you to cycle a prop? G You're only
at that power setting for a few seconds...but by all means do what
you're comfortable with.
Dale L. Falk
Old July 1st 04, 11:00 AM
Thomas Borchert
Dale,
Yes. And I disagree. Definitely hazardous.
Old June 30th 04, 11:47 AM
Cub Driver
prop. Once rolling I come up to 1700 for the mag check, then back to
idle to control speed.....up to 2000 for a quick prop check. Being on
during the checks.
Wow. I think I will leave that one for the next life.
I fly from a turf field too. The only time the surface has ever been
an issue is when a 172 driver was taxiing too fast and dug up some
stones with his prop.
We do have the occasional walk-through by the Boy Scouts, who pick up
stones and stuff. I suppose the scout-master is a pilot.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
C-182 carb-heat causing rough running. R.T. Owning 11 November 26th 04 11:50 PM
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 08:34 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 05:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 04:46 AM
