G,
......altimeter set to ***airfield elevation***, correct?? That will make the Kollsmann show the QNH. And, as has been mentioned in this thread, that is not ambient pressure at the field's elevation. Thus, it is NOT what MP will show. -- Thomas Borchert (EDDH) |
No.
It should be close to the setting seen when field elevation is dialed in. Karl "Thomas Borchert" wrote in message ... Robert, it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? -- Thomas Borchert (EDDH) |
well.. if he is at EDDH.. he is close to zero feet..
BT "kage" wrote in message ... No. It should be close to the setting seen when field elevation is dialed in. Karl "Thomas Borchert" wrote in message ... Robert, it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? -- Thomas Borchert (EDDH) |
Kage,
It should be close to the setting seen when field elevation is dialed in. I think you're wrong. When you dial in field elevation, the Kollsmann will show the altimeter setting for the field on that day. And that, as has been mentioned in this thread, is not ambient pressure at the field's elevation, it is rather the pressure as corrected for MSL. Thus, it is NOT what MP will show. -- Thomas Borchert (EDDH) |
Thomas,
Well it might be wrong, but it will be close, like I said----not exact. And it is a good preflight check to see if there are gross errors in the instruments. Your: "it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right?" won't even be close, unless you're at sea level, and is completely erroneous. Karl "Thomas Borchert" wrote in message ... Kage, It should be close to the setting seen when field elevation is dialed in. I think you're wrong. When you dial in field elevation, the Kollsmann will show the altimeter setting for the field on that day. And that, as has been mentioned in this thread, is not ambient pressure at the field's elevation, it is rather the pressure as corrected for MSL. Thus, it is NOT what MP will show. -- Thomas Borchert (EDDH) |
I cannot adjust my altimeter to "zero feet", the adjustment does not go that
far.. BT "Thomas Borchert" wrote in message ... Robert, it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? -- Thomas Borchert (EDDH) |
BTIZ wrote:
I cannot adjust my altimeter to "zero feet", the adjustment does not go that far.. BTIZ, you're high again. Jack |
Thomas Borchert wrote in message ...
Robert, it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? Altimeter setting is defined to be the number required to make your altimeter indicate field elevation on the field. It was a mistake many years ago that they used the same scale as pressure does. It will be somewhat close, but not the same, especially on a hot day. -Robert |
Robert,
Altimeter setting is defined to be the number required to make your altimeter indicate field elevation on the field. I know that. -- Thomas Borchert (EDDH) |
Robert, Altimeter setting is defined to be the number required to make your altimeter indicate field elevation on the field. I know that. I may have misunderstood what you meant by "zero feet" then. I thought you were referring to zero MSL but it would be zero AGL. -Robert |
| Thread Tools | |
| Display Modes | |
| Special prop to increase manifold pressure | Fly | Owning | 7 | December 2nd 04 08:23 PM |
| Cabin Pressure Altitude | Greg Esres | Piloting | 4 | March 24th 04 09:35 PM |
| Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 04:46 AM |
| Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 01:35 AM |
| Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 06:18 AM |
