Andrew Gideon wrote in message gonline.com...
Roger Long wrote: The web site for this theory does just as much of a dis-service to the aliens (they aren't really aliens because they are actually right next to us and have been her all along) as the popular lift explanations do to Bernoulli and Newton. Wait...are you suggesting that it's the aliens lifting our aircraft? That would explain so much! Why do *I* end up with the lazy alien, I'd like to know. and density altitude is a myth. The higher you go the bigger they get until theres not enough room on the wing for them. If its warm they tend to sunbathe on the wing lessening the area and numbers of lift fairies available :-) |
How about the force one one side ****ers the force (gravity) on the other.
Turning an airfoil upside down doesn't violate Bernoulli. You just change teh angle of attack to componesate. However, I wish it were new - wouldn't that be fun to discuss? Imagine all of those smart wing and airfoil designers who would feel stupid that they missed this all along! I hear Nobel Prize! Better yet, Bluelight Special! |
"Gary G" wrote in message
... How about the force one one side ****ers the force (gravity) on the other. Turning an airfoil upside down doesn't violate Bernoulli. You just change teh angle of attack to componesate. However, I wish it were new - wouldn't that be fun to discuss? Imagine all of those smart wing and airfoil designers who would feel stupid that they missed this all along! I hear Nobel Prize! Better yet, Bluelight Special! Better yet: Ig prize for shure................... |
I hear Nobel Prize! Better yet, Bluelight Special! it's more like "clean-up on isle 10"... -lance smith |
"Gary G" wrote in message ...
How about the force one one side ****ers the force (gravity) on the other. Turning an airfoil upside down doesn't violate Bernoulli. You just change teh angle of attack to componesate. Gee, if a golfer is someone who golfs, what would a ****er be? |
How does this comport with the theory of lift gnomes? As everyone knows,
lift gnomes reside on the upper surface of the wing (which ever side is "up" at the moment) and derive nourishment from exhaust gases. When throttle is added, the gnomes get stronger and lift the airplane into the air...the reverse is true when power is reduced. Which side of the airfoil is "up" is immaterial. Most maneuvers can be explained by the lift gnome theory. Bob Gardner "Mark Oliver" wrote in message . .. The current theory of flight is based upon the Bernoulli's Principal, the pressure of a fluid (liquid or gas) decreases at points where the speed of the fluid increases. The airfoil is designed to increase the velocity of the airflow above its surface, thereby decreasing pressure above the airfoil. Simultaneously, the impact of the air on the lower surface of the airfoil increases the pressure below. This combination of pressure decrease above and increase below produces lift. Pressure is reduced due to the smaller space the air has above the wing than below. Air cannot go through the wing, so it must push around it. The surface air molecules push between the wing and outer layers of air. Due to the bump of the airfoil, the space is smaller and the molecules must go faster. THIS HAS A MAJOR PROBLEM - specifically inverted flight. The current theory of flight utilizing the Bernoulli's Principal is only applicable to normal level flight. However, we know and observe that inverted flight is possible. Thus, the Bernoulli's Principal is no longer applicable to inverted flight, so there must be another theory that supports flight, be it level or inverted. The new theory of flight is based upon the new theory of Gravitational Vector Force (released Sept 2004). Utilizing Newton's laws that equal opposite force is generated at right angles, be it applied at once or successively, and if the angle is oblique (slanted) a new force is generated. Then inverted flight is possible as force is always generated at right angles, and this is towards the ground in all cases. The net difference between the initial velocity and resistance force generated at the leading edge at right angles (downwards) creates a new force called Gravitational Vector Force, and it travels in the opposite direction (upwards) to maintain balance, impacting the bottom of the wing. The wing becomes less efficient in inverted flight due to the design of the airfoil, however it is still possible. This new theory of flight also supports the following; 1) the new force manifests at a faster rate than initial velocity, hence the wing becomes more efficient at faster speeds 2) As you extend spoilers and flaps at the leading and trailing edges, the bottom of the wing now becomes "cupped" like a satellite dish, and able to capture more Gravitational Vector Force, creating more lift You may read more about this new theory at www.threexd.com Mark Oliver |
"Bob Gardner" wrote in message ... How does this comport with the theory of lift gnomes? As everyone knows, lift gnomes reside on the upper surface of the wing (which ever side is "up" at the moment) and derive nourishment from exhaust gases. When throttle is added, the gnomes get stronger and lift the airplane into the air...the reverse is true when power is reduced. Which side of the airfoil is "up" is immaterial. Most maneuvers can be explained by the lift gnome theory. Bob Gardner In addition...............from a fine friend of mine in engineering at NASA " The Emerging Science of Lift Demons Abstract- Advanced formal study of Lift has become respectable as its radical tenets undergo controlled experimental confirmation. As in other difficult fields, theorists rely on gut intuition, finding beauty in simplicity, in formulating grant proposals. Introduction to Lift Demons Ariel: "...I come To answer thy best pleasure; be't to fly, To swim, to dive into the fire, to ride On the curled clouds, to thy strong bidding task Ariel and all his quality." [SHKSPR]Graham E. Laucht posted the following helpful overview of Lift- [Discussion Thread] Discuss "the hump on top of the wing that produces lift" ... Definitely Lift Demons, they wait unseen near the downwind end of the runway and hop on for the ride dismounting again on landing ready for the next plane. That's why taking off from the other end (looking into the big end of the windsock) can be tricky. It's also why air traffic control regulates arrivals and departures especially in areas where there is a lack of lift demons. Like at large international airports where the supply of them and baggage carts is limited. They are very sensitive to poor pilotage and can easily fall off the wing if a pilot lifts the nose too much whilst going slowly. A slightly roughened surfaces helps them to stay on longer. Originally discovered and bred in captivity by a certain Mr Bernoulli which accounts for why early attempts at manned flight were often so unsuccessful. Being air breathing creatures they are not found at very high altitudes, they don't like it much when the wings are icy or dirty which seems fair enough. Male demons outnumber females by approximately three to one and are predominantly found on the mainwing topsides whilst the females, which can only push, are found on the underside of wings and tailplanes. The males find it fairly easy to "pull" the females due to the imbalance in numbers. A favourite area for congregating males is near the wing's hump where the view is often better. Known scientifically as humping. Humping can be controlled by the pilot by raising and lowering flags at the wing ends to signify the end he would like them to pull hardest. The female of the species being on the undersides are often kept in the dark especially about the cost impact of aviation. Demons are sexually very active and have it away near the wing tips. Demon spawn can sometimes be seen streaming off the tips in a conical cocoon. Kitbuilders generally find enough in the box for the first flight, however builders of porkies might not have enough to fly properly. Neutered Demons are called vacuum and are useful for keeping coffee warm. An excess of neutered demons can cause breathing difficulties and should have a government health warning attached. Research into demon I.Q.s shows lift demons have no comprehension whatsoever of what a downwind turn is. Real NASA Wonks Discuss Lift Demons in Drag; and Stalling. Mary Shafer ) explains lift: --the real, intuitively-obvious-even-to-the-lay-person explanation of lift. People, lift is caused by lift demons. These little, invisible demons hold on to the leading and trailing edges of the aircraft and lift it into the air by flapping their wings (so, in a reductionist sense, lift is actually caused by feathers). Some of the demons are a little confused and they hold on backwards, causing drag. The reason that planes stall at high alpha is that the leading edge demons get scared and let go when they can't see the ground anymore. Lift demons have good taste and don't like to look at ugly aircraft, so they hold on backwards on ugly planes. That's why gliders have so much lift and so little drag and why F-4s have lots of drag. John Wolter ) asked: What I would like is a simple *intuitive* explanation of what causes lift on a lift demon's wing. (Here we go again... ;-) ) Mary Shafer ) replied: Feathers. The multiple filaments on feathers trap the air molecules and they struggle to escape, which causes the action-reaction that we call lift. Bat wings don't have feathers but they're hairy and that works just about as well (air molecules are a little claustrophobic). Once too often bitten milking demons for research, Dave Santos ) kindly tackles annoying questions by lay-people. Can Lift Demons be held securely? Stupid question. The little monsters are trapped in bags, for balloon or airship use, but escape given any opportunity. Instead of captivity, winged aircraft are designed to entice the demons to visit. This is not easy since they abandon common aircraft on very weak pretexts. For example, lift demons enjoy engine roar and go elsewhere when this noise stops. Birds are so lucky. They just waggle their wings to signal a desire to fly and the demons eagerly bear them aloft (Penguins, an exception, are associated with ice, which lift demons hate. See [Grahm] (above). Other flightless birds are overweight, a condition despised by lift demons (see [Grahm] ("porkies")), and [Santos] (below)). Note that bird feathers are merely ornaments evolved to attract demons, whose own "feathers" are the true source of lift [Shafer] (above). True enough, lift demons are held by cables or chain, as in elevators and hoists, and in pillars and walls, by applied weight, but such abuse ruins them for flight (ordinary stairs cage lift demons such that, conditions permitting, they are heard to groan underfoot). How Do Lift Demons Get Away WithDefying Gravity? Lift demons are the ******* offspring of "Gravity Wells", who tolerate the defiant demons without acknowledging them. The rest of us risk "falling" afoul of these vengeful G wells, except those who flee fast enough (popularly usage: Escape Velocity) and far enough to also defy Gravity (slang- "weightlessness"). Lift demons try to drop anything heavy, out of deep resentment. What about the Sound Barrier? What about it? Dumbest question yet... Under proper conditions, lift demons penetrate either sound or unsound barriers. Tibetan- mkha' rgyu'i yi dwags - air-dwelling hungry ghost / preta, hungry ghost living in the air mkha' la rgyu ba'i yi dwags - the pretas living in the air. Coming Soon: Lift Demons and the FAA. DRAFT// Grant Proposal- Just 8 million dollars is requested for the formal study of Lift by field experiment, and over the Internet (from Tahiti!). With jet travel and modern communications, Tahiti is no longer a paradigm obstacle. It is anticipated that native lift demons, as explored with state-of-the-art frizbees, kites, hang-gliders, and yachts, will display a high Q factor. Phase I (5 yr. min) will result in a completed Abstract of Phase II, a proposal for increased funding. Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired |
Gee, I better start ground school again.
I always thought lift demons were actually pushing the Earth from underneath the airplanes when you pointed the empennage downward. (Although it might be still the case here in Canada. We are a weird bunch up here, anyways...) "Dudley Henriques" wrote in message ink.net... "Bob Gardner" wrote in message ... How does this comport with the theory of lift gnomes? As everyone knows, lift gnomes reside on the upper surface of the wing (which ever side is "up" at the moment) and derive nourishment from exhaust gases. When throttle is added, the gnomes get stronger and lift the airplane into the air...the reverse is true when power is reduced. Which side of the airfoil is "up" is immaterial. Most maneuvers can be explained by the lift gnome theory. Bob Gardner In addition...............from a fine friend of mine in engineering at NASA " The Emerging Science of Lift Demons Abstract- Advanced formal study of Lift has become respectable as its radical tenets undergo controlled experimental confirmation. As in other difficult fields, theorists rely on gut intuition, finding beauty in simplicity, in formulating grant proposals. Introduction to Lift Demons Ariel: "...I come To answer thy best pleasure; be't to fly, To swim, to dive into the fire, to ride On the curled clouds, to thy strong bidding task Ariel and all his quality." [SHKSPR]Graham E. Laucht posted the following helpful overview of Lift- [Discussion Thread] Discuss "the hump on top of the wing that produces lift" ... Definitely Lift Demons, they wait unseen near the downwind end of the runway and hop on for the ride dismounting again on landing ready for the next plane. That's why taking off from the other end (looking into the big end of the windsock) can be tricky. It's also why air traffic control regulates arrivals and departures especially in areas where there is a lack of lift demons. Like at large international airports where the supply of them and baggage carts is limited. They are very sensitive to poor pilotage and can easily fall off the wing if a pilot lifts the nose too much whilst going slowly. A slightly roughened surfaces helps them to stay on longer. Originally discovered and bred in captivity by a certain Mr Bernoulli which accounts for why early attempts at manned flight were often so unsuccessful. Being air breathing creatures they are not found at very high altitudes, they don't like it much when the wings are icy or dirty which seems fair enough. Male demons outnumber females by approximately three to one and are predominantly found on the mainwing topsides whilst the females, which can only push, are found on the underside of wings and tailplanes. The males find it fairly easy to "pull" the females due to the imbalance in numbers. A favourite area for congregating males is near the wing's hump where the view is often better. Known scientifically as humping. Humping can be controlled by the pilot by raising and lowering flags at the wing ends to signify the end he would like them to pull hardest. The female of the species being on the undersides are often kept in the dark especially about the cost impact of aviation. Demons are sexually very active and have it away near the wing tips. Demon spawn can sometimes be seen streaming off the tips in a conical cocoon. Kitbuilders generally find enough in the box for the first flight, however builders of porkies might not have enough to fly properly. Neutered Demons are called vacuum and are useful for keeping coffee warm. An excess of neutered demons can cause breathing difficulties and should have a government health warning attached. Research into demon I.Q.s shows lift demons have no comprehension whatsoever of what a downwind turn is. Real NASA Wonks Discuss Lift Demons in Drag; and Stalling. Mary Shafer ) explains lift: --the real, intuitively-obvious-even-to-the-lay-person explanation of lift. People, lift is caused by lift demons. These little, invisible demons hold on to the leading and trailing edges of the aircraft and lift it into the air by flapping their wings (so, in a reductionist sense, lift is actually caused by feathers). Some of the demons are a little confused and they hold on backwards, causing drag. The reason that planes stall at high alpha is that the leading edge demons get scared and let go when they can't see the ground anymore. Lift demons have good taste and don't like to look at ugly aircraft, so they hold on backwards on ugly planes. That's why gliders have so much lift and so little drag and why F-4s have lots of drag. John Wolter ) asked: What I would like is a simple *intuitive* explanation of what causes lift on a lift demon's wing. (Here we go again... ;-) ) Mary Shafer ) replied: Feathers. The multiple filaments on feathers trap the air molecules and they struggle to escape, which causes the action-reaction that we call lift. Bat wings don't have feathers but they're hairy and that works just about as well (air molecules are a little claustrophobic). Once too often bitten milking demons for research, Dave Santos ) kindly tackles annoying questions by lay-people. Can Lift Demons be held securely? Stupid question. The little monsters are trapped in bags, for balloon or airship use, but escape given any opportunity. Instead of captivity, winged aircraft are designed to entice the demons to visit. This is not easy since they abandon common aircraft on very weak pretexts. For example, lift demons enjoy engine roar and go elsewhere when this noise stops. Birds are so lucky. They just waggle their wings to signal a desire to fly and the demons eagerly bear them aloft (Penguins, an exception, are associated with ice, which lift demons hate. See [Grahm] (above). Other flightless birds are overweight, a condition despised by lift demons (see [Grahm] ("porkies")), and [Santos] (below)). Note that bird feathers are merely ornaments evolved to attract demons, whose own "feathers" are the true source of lift [Shafer] (above). True enough, lift demons are held by cables or chain, as in elevators and hoists, and in pillars and walls, by applied weight, but such abuse ruins them for flight (ordinary stairs cage lift demons such that, conditions permitting, they are heard to groan underfoot). How Do Lift Demons Get Away WithDefying Gravity? Lift demons are the ******* offspring of "Gravity Wells", who tolerate the defiant demons without acknowledging them. The rest of us risk "falling" afoul of these vengeful G wells, except those who flee fast enough (popularly usage: Escape Velocity) and far enough to also defy Gravity (slang- "weightlessness"). Lift demons try to drop anything heavy, out of deep resentment. What about the Sound Barrier? What about it? Dumbest question yet... Under proper conditions, lift demons penetrate either sound or unsound barriers. Tibetan- mkha' rgyu'i yi dwags - air-dwelling hungry ghost / preta, hungry ghost living in the air mkha' la rgyu ba'i yi dwags - the pretas living in the air. Coming Soon: Lift Demons and the FAA. DRAFT// Grant Proposal- Just 8 million dollars is requested for the formal study of Lift by field experiment, and over the Internet (from Tahiti!). With jet travel and modern communications, Tahiti is no longer a paradigm obstacle. It is anticipated that native lift demons, as explored with state-of-the-art frizbees, kites, hang-gliders, and yachts, will display a high Q factor. Phase I (5 yr. min) will result in a completed Abstract of Phase II, a proposal for increased funding. Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired |
"Apa" wrote in message ... Gee, I better start ground school again. I always thought lift demons were actually pushing the Earth from underneath the airplanes when you pointed the empennage downward. (Although it might be still the case here in Canada. We are a weird bunch up here, anyways...) Hesitation point rolls are a lot of fun for a pilot watching lift demons. It's an absolute riot to watch them scramble off the wings and onto the fuselage then back again as the roll progresses. The most I've ever been able to disturb them this way was 16. Australian lift demons can't seem to figure out which side of the wing to climb onto when they're here in the states, but they get even when ours opt for an outback vacation on their time shares. :-) Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 08:16 PM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
