Vx and Vy get a little more complicate with altitude change.
Vx increases with altitude, Vy decreases with altitude. Robert M. Gary wrote: BTW: There is a formula to get Vy, Vx, and Vso (and probably best glide) for each weight. I don't have it in front of me right now. That formula is on the Flight Engineer FAA written exam. -Robert, CFI |
BTW: There is a formula to get Vy, Vx, and Vso (and probably best glide) for each weight. I don't have it in front of me right now. That formula is on the Flight Engineer FAA written exam. Vs is easy, but modifying Vx and Vy for weight would be a very complex equation if done correctly since it would have to compensate for propellor efficiency, engine efficiency, etc as the airspeed changes. Hilton |
Terry wrote:
the best glide speed of a warrior is quoted as 73 kts. but best glide should be at best lift /drag ratio... It is. which I recall is at about 4 degree angle of attack. Who told you this? CFI? POH? Seems awful low to me; I've never seen an AOA quote for Vbg for a GA aircraft. But this must be a function of weight. The airspeed is, not the AOA. So my questions are what weight is the 73 kts based on? Best lift over drag as you suggest. My flying school actually rounds it off to 75kts, regardless of weight. Stupid. Fly 73, not 75 - if you can't fly 73, you need practise. There are numerous rules of thumb, to get it accurately, scale by sqrt(weight) / sqrt(gross) - ensure you use CAS, not IAS. Hope this helps, Hilton |
"Hilton" wrote in message nk.net... Terry wrote: the best glide speed of a warrior is quoted as 73 kts. but best glide should be at best lift /drag ratio... It is. which I recall is at about 4 degree angle of attack. Who told you this? CFI? POH? Seems awful low to me; I've never seen an AOA quote for Vbg for a GA aircraft. The 4 degrees comes from my theory books ( trevor Thom) and I understand it is pretty much the same for all light aircraft. which is why the wing is usually set at this angle when the aircraft is level ( the riggers angle I believe they call it) But since we dont have an angle of attack meter the number is pretty much academic. the principle is that the best glide speed is at a constant angle of attack and if the weight changes the speed to achieve that angle of attack must change. I just wanted to understand how much it changes. But this must be a function of weight. The airspeed is, not the AOA. yes I agree, I didnt write this well but the change in airpseed is what I am after, since we dont know tha aoa So my questions are what weight is the 73 kts based on? Best lift over drag as you suggest. My flying school actually rounds it off to 75kts, regardless of weight. Stupid. Fly 73, not 75 - if you can't fly 73, you need practise. There are numerous rules of thumb, to get it accurately, scale by sqrt(weight) / sqrt(gross) - ensure you use CAS, not IAS. Im certainly doing the practice and good pt about using CAS Hope this helps, It does, thanks Terry |
"d&tm" wrote in message
... The 4 degrees comes from my theory books ( trevor Thom) and I understand it is pretty much the same for all light aircraft. which is why the wing is usually set at this angle when the aircraft is level ( the riggers angle I believe they call it) The angle is called "angle of incidence", and while not just one factor controls the choice of angle of incidence, most often the primary factor is the desire to keep the cabin relatively level during cruise. Cruise speed usually results in an angle of attack well below the "best glide" angle of attack (and an airspeed well above Vbg). I don't know off the top of my head what a typical best-glide angle of attack is, but it's above a normal cruise angle of attack, and if 4 degrees is a typical angle of incidence (and thus a typical cruise angle of attack), the a typical best-glide angle of attack would be greater than 4 degrees. Pete |
The best glide speed in the book is calc'd at gross weight. At lighter
weights, the best glide will be lower. The calculation for best glide at various weights is straight forward but I don't know it. I'm going to guess that it will be about 6 knots slower at empty weight plus a standard pilot (can't wait to find out what the real number is) Flying that speed accurately is valuable but perhaps not as valuable as understanding the other major variable in doing an engine out glide to a spot on the ground. That variable is wind. Since this is a ground reference manuever so to speak, wind plays a signinficant role. The task at hand is generally "best glide speed for distance over the ground". If you are flying upwind to a spot, best glide speed will be higher. Downwind to a spot, a slower than best glide speed will take you further. Accurately flying 73 knots to make maximum distance over the ground into a 20 knot headwind is a mistake. (I'd guesstimate that 80-85 knots would be more like it). I don't know the formula for doing the calc and doubt you will have it if faced with the problem. When faced with the problem, I had a gps driven glide computer in my glider which would give you precise guidance based on wind, glide polar, and vertical air motion. A couple of rough rules of thumb - err on the high side for upwind max distance glides - you really need to go faster upwind and there is disportianate penalty for being slower than optimal - err on the high side for downwind - you can get a little more distance by going slower than best glide speed, but not much. Just fly best glide if in doubt I'm really interested to see what the actual speeds are for different weights and wind conditions. "d&tm" wrote in message ... the best glide speed of a warrior is quoted as 73 kts. but best glide should be at best lift /drag ratio which I recall is at about 4 degree angle of attack. But this must be a function of weight. So my questions are what weight is the 73 kts based on ? and how much does this best speed change say between maximum weight and minimum wight , or lets just say an 80 kg ( 176 pounds for the folks up over ) pilot flying solo with half fuel? Why ? I am just curious, I like practicising my forced landings ( solo) and just wondered how much extra time /distance i might get by flying at a more "correct" speed. My flying school actually rounds it off to 75kts, regardless of weight. Terry |
Maule Driver wrote: Flying that speed accurately is valuable but perhaps not as valuable as understanding the other major variable in doing an engine out glide to a spot on the ground. Several experts (people like Barry Schiff) claim that the best speed to use is actually a speed which will keep you in the air longest. That gives you the most time to attempt a restart and use the radio. The only time you should use best glide is when you actually need to in order to reach a suitable spot to land. George Patterson The desire for safety stands against every great and noble enterprise. |
"G.R. Patterson III"
Flying that speed accurately is valuable but perhaps not as valuable as understanding the other major variable in doing an engine out glide to a spot on the ground. Several experts (people like Barry Schiff) claim that the best speed to use is actually a speed which will keep you in the air longest. That gives you the most time to attempt a restart and use the radio. The only time you should use best glide is when you actually need to in order to reach a suitable spot to land. That makes some sense. My thinking for an engine failure at altitude is to: 1) Slow to best glide 2) Point the plane in a useful direction 3) Concurrent with one, troubleshoot and communicate To maximize time in the air, one would want to fly at minimum sink speed which will be slower than best L/D. So the experts are suggesting not flying at best glide but flying minimum sink. Hmmm. Don't think I agree unless I don't have anything landable under me (open water), or my best landing option is well with gliding distance. |
"G.R. Patterson III" wrote in message ... Maule Driver wrote: Flying that speed accurately is valuable but perhaps not as valuable as understanding the other major variable in doing an engine out glide to a spot on the ground. Several experts (people like Barry Schiff) claim that the best speed to use is actually a speed which will keep you in the air longest. That gives you the most time to attempt a restart and use the radio. The only time you should use best glide is when you actually need to in order to reach a suitable spot to land. Wont the best glide speed also keep you in the air the longest? if not what speed will? Terry |
d&tm wrote: Wont the best glide speed also keep you in the air the longest? if not what speed will? No, best glide doesn't do that. The best loiter speed is a bit lower than that for the best angle of climb. It's usually not published, but you can determine it pretty well by empirical experimentation. George Patterson The desire for safety stands against every great and noble enterprise. |
| Best Glide Speed | john smith | Piloting | 5 | September 4th 04 11:04 AM |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| Space Elevator | Big John | Home Built | 111 | July 21st 04 05:31 PM |
| Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 09:35 PM |
| Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 11:01 PM |
