Navy pilots say flaring to land is like squatting to pee. Real men don't do
it! -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - wrote in message news:1104445981.bbab3be025bbb3c0b0b08c046e6f0180@t eranews... On Sat, 25 Dec 2004 18:35:35 -0600, Journeyman wrote: In article , Bob Moore wrote: "Ramapriya" wrote Note that jets landing on an aircraft carrier do not flare. Jets do not land on carriers. They make controlled crashes. Morris (yeah, old joke, but someone had to say it) I've heard it said that Navy pilots basically fly the airplane into the carrier. |
Bob Moore wrote: Note that jets landing on an aircraft carrier do not flare. But their landing gear is stressed for 2,000 fpm descent rate. |
On Thu, 30 Dec 2004 11:28:08 -0500, BUFF5200 wrote:
Note that jets landing on an aircraft carrier do not flare. But their landing gear is stressed for 2,000 fpm descent rate. Yes, every carrier landing is essentially a crash landing, or so they tell me. I'm not conscious that I flare, either. Does one flare when making a wheelie on a conventional-gear aircraft? Did the Wright Bros flare, or were they making crash landings also? |
Cub Driver wrote: On Thu, 30 Dec 2004 11:28:08 -0500, BUFF5200 wrote: I'm not conscious that I flare, either. Does one flare when making a wheelie on a conventional-gear aircraft? Yes. They have to reduce the sink rate to a minimum before touching down, and then raise the tail a bit to keep the wheels planted. Banging the mains on with insufficient flare causes what we know as "jackrabbiting" down the runway, and propstrikes are often the result. Dan |
On 25 Dec 2004 02:00:24 -0800, "Ramapriya" wrote:
Has anyone seen wheelbarrowing occur? Prima facie, it appears too improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Saw one today by someone who was obviously uncomfortable in their new Bonanza. z |
On Sat, 25 Dec 2004 23:23:57 GMT, zatatime wrote:
On 25 Dec 2004 02:00:24 -0800, "Ramapriya" wrote: Has anyone seen wheelbarrowing occur? Prima facie, it appears too improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Saw one today by someone who was obviously uncomfortable in their new Bonanza. The curse of the Bo pilotG According to the Bo specific Pilot Proficiency training I went to, most Bo pilots land their planes way too fast. They really had to work to get most of them to slow down. OTOH you should have heard the complaints when told they were going to do full departure stalls with the yoke blocked so they couldn't use the ailerons. LOL Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com z |
On Sat, 25 Dec 2004 22:11:36 -0500, Roger
wrote: Saw one today by someone who was obviously uncomfortable in their new Bonanza. The curse of the Bo pilotG According to the Bo specific Pilot Proficiency training I went to, most Bo pilots land their planes way too fast. They really had to work to get most of them to slow down. From general observation, I totally agree. The guy today was carrying significant power all the way to the runway and must've touched down at around 100 - half way down the 3500 foot strip. I could see him where I stood, and he looked busier than anything I can make an analogy for. I kind of felt bad for him. OTOH you should have heard the complaints when told they were going to do full departure stalls with the yoke blocked so they couldn't use the ailerons. LOL That made me laugh! God forbid they need to do something they'll learn from! z |
Wheelbarrowing and porpoising are very different things. In
wheelbarrowing, insufficient back pressure leads to directional instability. A fairly common response is to release even more back pressure and concentrate on trying to steer, which immediately makes things worse as the airplane swerves sown the runway in a series of overcorrections. In porpoising, the aircraft's nosewheel hits, causing it to bounce in the air, drop to the runway, and repeat. This is often a divergent oscillation -- the amplitude increases with each bounce until either back pressure is applied or the energy decreases sufficiently. It usually happens on touchdown. A nosewheel landing usually results in a porpoise. Releasing back pressure on rollout (often in crosswinds) is the normal way to initiate wheelbarrowing. On Cessnas, retracting flaps for a touch and go without adding back pressure can start the wheelbarrow. Paul |
On 28 Dec 2004 07:24:15 -0800, wrote:
In porpoising, the aircraft's nosewheel hits, I probably shouldn't say this, but taildraggers can porpoise too. |
Cub Driver wrote: On 28 Dec 2004 07:24:15 -0800, wrote: In porpoising, the aircraft's nosewheel hits, I probably shouldn't say this, but taildraggers can porpoise too. Just remember the old adage: "A nosegear is nNOT a *landing* gear! |
