On 25 Dec 2004 02:00:24 -0800, "Ramapriya" wrote:
Has anyone seen wheelbarrowing occur? Prima facie, it appears too I've seen it a couple of times, but porpoising is much more common. Wheelbarrowing is due to forcing the plane down when it's still going too fast to land. Porpoising OTOH is from not getting the nose up soon enough. The plane is rotating (nose coming up) when the nose wheel hits first, this leads to the nose rebounding up and the mains come down and rebound. You can get some pretty dramatic bounces this way. The best way to stop a porpoise is to just give it the power and go around. The typical porpoise ends up with the pilot behind the airplane (OK so it started that way), and each bounce gets bigger. They say three times and out. I saw two instances where this was true. On the third time they busted the nose gear right off on both planes. improbable (ludicrous almost) a thing to happen but even the FAA Airplane Flying Handbook copy that I have mentions it! Some well known planes are quite prone to porpoising if the pilot gets behind it. They are a bit heavy up front although the CG is fine. The problem comes in landing. That is why you see cautions about checking firewalls for wrinkles when purchasing a used plane. Also, while the ways of performing a flare is mentioned at many places, the reason for a flare is conspicuously absent everywhere. Just why is Actually it's not. *Almost* anything that flys flares on landing whether it has jet engines or feathers. a flare needed vis-a-vis a 3-point landing? After all, birds just come in and sit, without having to flare... Virtually all the birds I've seen flare and they are really good at it with many almost coming to a stop just before their feet touch down. As some one else mentioned, with your interest you should take up flying if you haven't already. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Ramapriya |
Roger wrote: I've seen it a couple of times, but porpoising is much more common. Wheelbarrowing is due to forcing the plane down when it's still going too fast to land. I guess I'm just more creative. I was getting a check-out in a 207 long ago. There was just the CFI and me in the airplane, not a lot of gas. The first takeoff we used 10 or 20 flap, I guess I held a little forward pressure on the yoke because I was worried about this "big, heavy, fast airplane" coming off the ground to slow. G The initial liftoff was main wheels first. I can tell you from experience that a 207 doesn't handle well with just the nosewheel on the ground. Since I wasn't doing very well driving it I rotated to try flying it and things calmed down. I have NEVER done that again. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
We had a friend earn his ticket in Iowa City a few years ago who porpoised a rental Archer so badly that the nosewheel collapsed and the engine had to be torn down. The prop was a total loss, too, of course. Sadly, it rattled him so badly that he absolutely disappeared off the face of the earth after that episode. I've never seen him again, and I presume he's quit flying. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote: Sadly, it rattled him so badly that he absolutely disappeared off the face of the earth after that episode. I've never seen him again, and I presume he's quit flying. Probably still making installments on the damage bill. George Patterson The desire for safety stands against every great and noble enterprise. |
| Thread Tools | |
| Display Modes | |
