Engine failure on final
Old January 23rd 05, 11:09 PM
Hilton
Blueskies wrote:
Hilton wrote:
Ron Garret wrote:
The discussion about cutting power on final reminded me of something
I've been puzzled about for some time now.
If you fly final with some amount of power (which I gather most people
do -- I always have) that seems to guarantee that if you lose your
engine on final you will land short, and there's pretty much nothing
you
can do about it. Is that true? Or have I missed something? What
should you do if you lose your engine just after turning base to final?
Is that true? Have you missed something? Yes, lots!
0. Airspeed! Best place to land! (Rmember ABC)
1. Raise flaps
2. Prop low RPM
3. Raise gear
4. Then quickly run through obvious engine stuff - don't forget to pump
primer
Of course, 1-4 apply if you think you're not going to make a runway.
Hilton
Also, lower nose if necessary to get best glide speed...
That's the most important thing - that's why I listed it first.
Since you brought up the aircraft's attitude, you'll probably find that
you'll need to raise the nose, not lower it during the entire sequence.
Why? Because you'll probably be close the Vbg and possibly above it (I tend
to keep my speed up and slow down towards the end), but most importantly,
you need to pitch up to 'counteract' the raising the flaps; i.e. raising the
flaps lowers the Cl, so increase the attitude to increase the Cl to its
starting value - that way you don't get that 'pilot-is-a-passenger' sinking
feeling - same goes for climb-out when using flaps for take-off.
Hilton
Old January 26th 05, 07:58 AM
C J Campbell
"Ron Garret" wrote in message
engine on final you will land short, and there's pretty much nothing you
The "I always cut power on final" guys to the contrary (and I am not saying
that they are full of it, only that they may not have considered all
possibilities), I think you are missing something.
So try it. Set up just as you would for a power on landing, flaps down,
recommended airspeed, right on glide slope, and cut your power. See if you
can make it. If you can't, figure out why not.
But then you are on base. Well, turn straight toward the runway. Forget
about flying a square pattern. Set up for best glide. Experiment with it. Is
it easier to make the runway if you raise your flaps? How does the wind
affect it? Can you still do it if you start out somewhat low and slow? What
does it take to milk that last bit of distance out of your altitude? You can
read about this stuff forever, but actually practicing things and trying
them out will teach you a heck of a lot.
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
Diesel engine Bryan Home Built 41 May 1st 04 08:23 PM
Night engine failure in Boston Dan Luke Piloting 8 February 13th 04 06:33 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
