Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder
Old November 25th 03, 10:16 PM
Ian Strachan
In article , John Ferguson
. co.uk writes
HELP
I find the IGC site terrible to navigate -
Complain to the webmaster. I also do not find a lot of web sites easy
to navigate.
Where do
I find a simple explanation/list of recorders and their
classification into suitable for World records, etc.
The qualifications in any IGC-approval are in the approval document
itself, all of which documents are at the end of:
http://www.fai.org/gliding/gnss/igc_approved_frs.pdf
It is true that there is not yet a list of recorders at the three
approval levels. There probably will be in the future, IGC officials are
working in their own time and these things take time, I am afraid. The
current situation is:
All 24 IGC-approved recorders are at the "all flights" level except:
1. Badge flights up to and including Diamonds level: the EW series.
2. All IGC badge and distance diploma flights:
2.1 Now: Scheffel Themi
2.2 From 1 April 2004:
Cambridge 10, 20 and 25
Filser LX20 first batch (no RSA, no micro)
Peschges VP8
Print Technik GR1000
possibly the Zander GP940 (under consideration at the moment)
I hope this helps.
Ian Strachan
Chairman IGC GFA Committee
Old November 26th 03, 03:00 AM
Mark Hawkins
Ian,OUTSTANDING!!!! Let's hope they listen. Later!-MarkAt 23:36 25 November 2003, Ian Forbes wrote:On Mon, 24 Nov 2003 13:00:36 +0000, CH wrote: And why Ian is it, that suddenly the Cambridge 25
Model should not be save enough anymore. Was the safety standard proposed
by the IGC not good enough - too lax?The politics of flight recorders seems to be as complicated
as some oftheir technical aspects. Clearly there is a lot of
mistrust surroundingthe motivation of the decisions of the 'GNSS Flight
Recorder ApprovalCommittee' (GFAC) both now and in years gone by. Perhaps
the technicalissues should be separated from the political ones.If the GFAC defined a series of 'levels of security'
for GNSS FlightRecorders. For example:Level 610: Encryption, microswitch, ENL, internal GPS,
barometric hightLevel 600: Encryption, microswitch, no ENL, internal
GPS, barometric hightLevel 510: ENL, internal GPS, barometric hightLevel 500: Internal GPS, barometric hightLevel 400: External GPS, barometric hightLevel 300: Commercial GPS with logging functionLevel 200: GPS + PDA + SoftwareMy numbering leaves lots of scope for slotting in new
categories inbetween. Perhaps a new level around 550 for a logger
with GPS only and nobarometric hight. The list is probably longer than
the GFAC would care toadminister but it illustrates the point. The next generation
of recorderswill do things we have not thought of yet, but after
they have beeninvented, they can classified into a new 700 category.The GFAC would have the job of defining the above levels,
testingrecorders and awarding approval at the appropriate
level.Then the various bodies that monitor performances in
the sport couldspecify what level of Flight Recorder is suitable for
each performance. EGthe IGC could determine requirements for world records
and badges atvarious levels. (Currently this would be minimum 610
for a world record ina m/g, minimum 500 for a 1000km diploma in a pure glider
and minimum 400for a gold badge).National bodies and competition organizers could specify
their minimumrequirements for national and regional competitions.The Online Contest organizers (who process far more
flight claims thananybody else and have their own unique requirements)
could also specifytheir minimum requirements. (Or just list the security
level of the loggerused for each claim, for peer review).It could even be extended to other sports like hang
gliding andparagliding. They could use the same numbering system,
and supplyvolunteers to help with the work of the GFAC. This
could double thepotential market size for these devices.Manufacturers would design for a certain level of approval.
There would beno moving of the technical goal posts between time
of R&D and time offinal approval. Once approved a design would not loose
its approval.Most important the buyers would know what they are
getting. Clearly alevel 610 logger is better than a level 500 one. The
authors of PDAsoftware would know they have got a way to go to get
from level 200 to610.Finally if the IGC were faced with a proposal that
level 500 is no longersuitable for world records then hopefully all the delegates
voting on theissue would realize that the proposal effects existing
equipment as wellas new equipment.The development of loggers has resulted in new forms
of competition likethe OLC. This has motivated a major interest in cross
country flying atour club and I am sure at many other clubs around the
world. This has beena very positive development, which has only become
possible now that alarge number of pilots have access to loggers. It has
taken over 6 yearsfrom the development of the first loggers to reach
this point. I am justnot sure if the politics of the GFAC over that time
has aided or hinderedthe process.Ian
Old November 26th 03, 06:24 AM
tango4
A good point has been raised on the IGC mailing list. With the new
categories it may be possible to have a ratified national record that
exceeds the same task world record.
Ian
Old November 26th 03, 08:51 AM
Ian Strachan
In article , tango4
writes
In principle this has always been possible because FAI and IGC (rightly)
cannot control criteria for events and flights for which the rules are
made by the National body.
For example, one of Jim Payne's USA 100 km triangle records was for a
time at a faster speed than the world record. This was because of
different criteria on the shape of triangles.
Ian Strachan
Bentworth Hall West
Tel: +44 1420 564 195 Bentworth, Alton
Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND
Old November 26th 03, 02:05 PM
Pat Russell
This is true, but it does not apply to your exampe, below:
In fact, the criteria were identical when the flight took place.
The IGC criteria changed after the flight, specifically for the
purpose of disapproving it.
It has always been the intention and practice of the USA to use
international rules for the homologation of national records.
-Pat
Old November 26th 03, 05:07 PM
Ian Strachan
In article , Pat Russell
writes
I think that is a bit hard. What happened was a difference in
interpretation of the then Sporting Code rule on triangle shape, the SSA
one was more generous than that of IGC. For the world record the matter
went to FAI arbitration via a Tribunal called by the President of the
FAI Air Sport General Commission (CASI). Personally, I was all for
approving it as a world record and gave evidence to the Tribunal to that
effect, as, I think did Bernald Smith on behalf of the SSA. However,
the decision went the other way. That's life!
So it is merely factual that for a while, until Jim Payne did an even
faster flight, the US 100k triangle record was in excess of the world
record.
This confirms my point that it is not possible for IGC/FAI to control
flights for which the evidence and interpretation is to National rules
and procedures rather than those of the IGC and FAI.
Ian Strachan
Old November 28th 03, 08:55 PM
John Ferguson
In my day job I do a bit of IT. We normally balance
risk of the outcome with reward when we talk of security.
Question - who in gliding is going to make a killing
from faking a GNSS log.
It really has to be 'just secure enough' to balance
the risk/reward question. I don't know anyone who is
going to become rich from declaring (and passing) a
new world record.
In reality, does the common gliding herd really mind
if someone fakes it. Who are GFAC/IGC protecting ?
If IGC suspect that someone has been cheating (remember
that they used to cheat with cameras) just refuse to
ratify the claim.
John
Old November 28th 03, 08:58 PM
Robert Danewid
Thanks for that input!
Robert
new world record.
ratify the claim.
John
Old November 26th 03, 11:46 PM
John Galloway
At 20:36 26 November 2003, Pat Russell wrote:
What if: a pilot who already holds a world record
uses the same
flight recorder on a flight that beats the old record.
He
submits his claim, gets a new national record, but
is not
allowed to claim a new world record because the flight
recorder
was downgraded in the meantime.
This is not a matter of 'interpretation,' nor has it
ever
existed before. It is merely bizarre.
Pat,
I don't see that as bizarre at all. In any sport equipment
approvals can be changed so that what was OK last year
is not this year. It would be truly bizarre if this
could not be the case.
I find it hard to imagine that anyone in the position
to be going for a world record would be unable to fix
him or herself up with an approved logger for the flight
one way or another.
John Galloway
Old November 27th 03, 12:03 AM
Robert Danewid
John, you are completely right. But i do not htink that that is the real
issue.
I ask myself, why this increase in security? What is the reason? How
many cases of cheating or falsifying document has been revealed?
Why increase the security level just because things has deloped over the
years? Suppose that what was decided in 1994 was "overkill" and still is
good enough?
What really is annoying is that our own world organization is now using
the same arguments as our CAA:s and airspace authorities are using when
increasing controlled airspace and making transponders etc mandatory.
This is not just a case of security for loggers, this is a case of bad
thinking and bad philosophy by our elected leaders.
Robert
uses the same
He
is not
recorder
ever
Pat,
one way or another.
John Galloway
Air Force Print News for April 30, 2004 Otis Willie Military Aviation 0 May 1st 04 11:20 PM
Mil Acft Comms Log, Florida - Friday 30 April 2004 AllanStern Military Aviation 0 May 1st 04 08:12 AM
Air Force Print News for April 23, 2004 Otis Willie Military Aviation 0 April 24th 04 11:11 PM
Air Force Print News for April 19, 2004 Otis Willie Military Aviation 0 April 21st 04 01:22 AM
FS 2004 'Shimmer' Effect of Ground Scenery Mr Zee Simulators 3 August 24th 03 05:40 PM
