Scott wrote:
I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. Find a set of thin-wall tubes that just fit inside each other so they will "telescope". Brass tubes from a hobby store work well. The largest tube ID should just fit the OD of your rod. Keep placing the tubes inside each other until the ID of the innermost tube is approximately the same size as your drill bit. The length of the tubes should be cut so that your drill bit will reach all the way down to the rod stock. Lube, stick in the bit, and drill. This will pretty much guarantee a perfectly centered and aligned hole. I've used this technique successfully many times. Regards, -Doug |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
