A thought on BRS
Old April 27th 04, 06:06 PM
Bill Daniels
I still have reservations about BRS, not because of the philosophy, but I'm
not sure the engineers have all the bugs out of it. Any system that will
lower a disabled aircraft and its occupant(s) to the ground safely is a very
good thing. The short history of the Cirrus BRS is very encouraging, at
least I haven't heard of any injuries to the passengers.
I know BRS has a long and exemplary record with ultralights but they are
slow and light and usually flown by the young and able. The idea of hitting
the ground in a seated position at 20 FPS is disturbing to a 60 something
glider pilot. I know using a personal 'chute is just as problematic but I
would land with my legs under me. A broken leg is vastly better than a
broken back.
For now, personal 'chutes with egress aids like DG's NOAH look better to me.
At least this idea could be retrofitted to an older glider. The 35 pounds
or so the BRS adds to the non-flying part of the glider bothers me too.
Bill Daniels
Old April 27th 04, 09:07 PM
Eric Greenwell
broken back.
I believe the current designs lower the glider nose down, and the
cockpit has to be properly designed to avoid injury to the pilot, as it
must absorb the impact. It's not a simple problem, and gliders that
aren't designed for it from the start almost surely won't be suitable
for retrofitting.
Certainly a much more practical addition!
The 35 pounds
It would likely reduce the allowable cockpit load.
Eric Greenwell
Washington State
USA
Old April 27th 04, 09:59 PM
Martin Gregorie
On Tue, 27 Apr 2004 12:07:37 -0700, Eric Greenwell
Bill Daniels wrote:
The 35 pounds
Surely, as the BRS would be installed on or just behind the CG, it
would be more like carrying a turbo in that the cockpit load would
remain as before but the permitted amount of water ballast would be
decreased.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old April 27th 04, 10:39 PM
Eric Greenwell
Bill Daniels wrote:
The 35 pounds
decreased.
I simplified it a bit too much, perhaps. It would come out of the
"non-lifting parts" limit (basically the fuselage and everything in it).
Generally, the effect would be to reduce the cockpit allowed load, but
not always, depending on the exact weight of fuselage and installed
equipment. The amount of water ballast allowed would not likely change,
since it is carried by the wing (a lifting part), not the fuselage.
A glider designed to carry a motor will have a higher "non-lifting
parts" limit (perhaps from more structure, stronger lift pins, etc) than
a similar non-motorized one, in order to preserve the cockpit load.
Eric Greenwell
Washington State
USA
Old April 28th 04, 02:37 PM
Pete Reinhart
"Bill Daniels" wrote in message
news:Jxvjc.42417$GR.5925024@attbi_s01...
I'm
very
hitting
broken back.
me.
Bill Daniels
Bill,
I talked to the BRS people at the SSA convention a couple of years ago
regarding fitting one of their syatems to the Nimbus. They said no dice
because the energy absorption characteristics of the cockpit configuration,
descent rate, etc., etc., just wouldn't work.
Just as you said.
Streifeneder has been doing some certificatoin work in Germany on a retrofit
package for some ship but I do'nt remember the details. It looks like some
of the newer gliders may be taking the BRS sytem into account in in their
initial design now however.Too bad there's not an off the shelf retrofit
package.
Cheers!, Pete
A Question For Real Airline Pilots Blue Simulators 34 September 6th 04 02:55 AM
I thought some of these are classics goneill Soaring 0 April 8th 04 11:51 AM
Rumsfeld is an even bigger asshole than I thought noname Military Aviation 0 March 20th 04 04:48 AM
And you thought aviation reporting was bad! C J Campbell Piloting 14 February 17th 04 03:41 AM
About the book entitled: Test Pilot, 1001 things you thought you knew about aviation Koopas Ly Piloting 1 December 2nd 03 03:54 AM
