Why are TE probes so long?
Old May 6th 04, 07:04 AM
Craig Funston
No. The ASI measures the dynamic pressure as the difference between the
total pressure and the static pressure. The pitot measures total pressure.
Thanks, I mispoke. It's what I was thinking as I wrote, but not what I wrote.
Old May 5th 04, 06:53 PM
Derrick Steed
I have driven many miles with an automobile test rig consisting of a
pitot, a static and a TE probe connected to a pair of side by side
U-tube water manometers. The manometers share the same static and one
uses the pitot signal while the other uses the TE signal. A properly
calibrated TE probe will cause exactly the same pressure difference as
the pitot, just with the opposite sign.
I understand we need the TE probe to generate the difference
static-dynamic because classical instruments are pure mechanical and
need the TE information to compensate the vario. But given electronic
devices/computers, do we really need the TE probe at all? The
information is given, when static and dynamic pressure are known. The
rest can be calculated. Wrong?
Eggert
Eggert, right. You are correct and some electronic instruments do just that
- they take the pitot and the static (instead of static and TE) and subtract
them electronically, and it's not just mechanical instruments which use TE,
the B50 has three inputs: pitot, TE, and static.
A TE probe isn't the only way of compensating for airspeed changes, ancient
glider pilots used diaphrams to achieve the same thing.
I sent some notes to Eckhard yesterday relating to how you might try and
achieve the calculation in Cumulus.
Rgds,
Derrick.
Old May 6th 04, 02:07 AM
Mike Borgelt
On 5 May 2004 16:53:06 GMT, Derrick Steed
Eggert
Rgds,
Derrick.
The B50 does not do electronic TE from the pitot/static. The TE probe
provides TE for the vario and the pitot/static measures airspeed for
the TAS/speed to fly/relative netto computation.
The reason for this is that is is *much* easier to get satisfactory TE
this way for the users.
The diaphragm compensator was one of the giant setbacks to the cause
of good glider instruments. Read any of the stuff by Moffat et al from
the 1960's and you will be treated to many stories of trying to get
good TE(and mostly failing). They only work properly at one altitude
too.
Althaus's revival of the venturi type probe in about 1969 was a great
improvement and they provide correct compenation at all altitudes.
It seems to me most TE probes are somewhat shorter than this thread!
Mike Borgelt
Borgelt Instruments
Old May 6th 04, 08:35 AM
Derrick Steed
Eggert
that
subtract
TE,
ancient
Rgds,
Derrick.
too.
Mike Borgelt
Borgelt Instruments
I should correct the impression given above - I wasn't trying to imply the
B50 did it electronically, but I did, although it seemed obvious to me when
I wrote my bit that if it took the TE input then it used it as just that in
the conventional way.
I cherish memories of a british army nationals pilot that I crewed for back
in '69 and '70 trying to repair his diaphram compensator with a sheet of
latex material cut from a male contractive - I think he might have got a lot
more pleasure from using it in the conventional manner.
I think the thread on high energy pull ups with or without water was longer
- there was just as misconception, bogus physics, and appalling arithmetic
there too!
Still, it's a good laugh innit?
Rgds,
Derrick.
Old May 7th 04, 12:05 AM
Mike Borgelt
On 6 May 2004 06:35:06 GMT, Derrick Steed
there too!
Rgds,
Derrick.
Sure is. Are you frightened too by the fact that we have a high tech
civilization that might as well be running on magic as far as most
people are concerned? I do know the quote about "any sufficiently
advanced technology is indistinguishable from magic". Arthur C. Clarke
wasn't it?
Mike
Old May 8th 04, 12:46 PM
Martin Gregorie
On Fri, 07 May 2004 08:05:40 +1000, Mike Borgelt
there too!
Rgds,
Derrick.
wasn't it?
That's the man.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old May 7th 04, 08:37 AM
Derrick Steed
when
in
back
lot
longer
there too!
Rgds,
Derrick.
wasn't it?
Mike
I remember the quote, I've read Arthur, it may also have been Isaac Asimov
(now there was an ego!) in his foundation series. The Arthur C. Clarke novel
which really sticks in my memory is "Childhoods end", the solution that the
aliens applied to prevent us from perpetuating all the cruelty we inflict on
other species on our planet was particularly aposite, GWB, Rumsfeld & co
could certainly do with a dose of it.
And yes, I am frightened by it - I get the feeling that once the princes of
this world get control of the information again (they had it back in the
middle ages, think about that), life will be a lot worse for all of us
because the technology _will_ be elevated to the status of magic with only
the wizards privy to the knowledge necessary to make sense of it. Or are we
already there?
I'm not a conspiracy theorist, I'm a stupid theorist: the world is
controlled by very intelligent, very arrogant, extremely over-confident
people who seem to be terminally stupid to the extent that they can't see
the consequences of all their complicated plans and intrigues, with the
consequence that the rest of us suffer as a result.
Rgds,
Derrick.
Old May 7th 04, 06:29 PM
ADP
"Whenever you hear the word conspiracy, think stupidity." Don't remember
where I read that.
"Simple explanations are preferred to complicated ones." William of Ockham,
mid 19th century.
"The simplest explanation is always stupidity." Darwin Minor "Darwin's
Blade" - Dan Simmons, Harper Torch, 2000.
The point being, stupidity rules.
Allan
Rgds,
Derrick.
Old May 8th 04, 02:35 AM
Steve Bralla
In article , "ADP"
writes:
Parts of "Darwin's Blade" take place at and above the Warner Springs
gliderport. If I remember Darwin flys a flapped (?) L-33 in the book, also a
"metal and canvas skinned" Twin Astir.
Steve
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 01:11 AM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 04:02 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 06:09 AM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 03:40 PM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 03:14 AM
