Canopy causes cockpit fire
Old May 5th 04, 07:07 PM
Finbar
I think I can see how this would happen with the canopy open, and the
sunlight hitting it from "inside," reflecting off the canopy surface
onto the focal point of the almost-parabolic canopy. I'm still
holding onto the idea, though, that this can't happen in flight
because the sun can't hit the canopy from the inside. The thought of
an in-flight cockpit fire is really not comforting. Has anyone had
solar/canopy - related charring happen in flight?
Old May 5th 04, 08:15 PM
Robert Ehrlich
I completely agree, focusing solar light can only occur by reflection,
by transmission, as the canopy has parallel inner and outer surfaces, it
cannot change the direction of light rays, only slightly offset them.
Hey, this is just why we can see through it as if it were not there !
Old May 6th 04, 03:10 AM
Bob C
If you look at the photo link in my original post,
there is a photo of Mark duplicating the hot spot with
a flashlight.
http://www.silentwingsairshows.com/canopy.html
I tried it with the jet Silent this morning, and sure
as s**t when the canopy is open and the tail is pointed
toward a low sun, it gets smokin' hot just up near
the rudder pedals.
Bob C.
At 18:30 05 May 2004, Robert Ehrlich wrote:
open, and the
sunlight hitting it from 'inside,' reflecting off
the canopy surface
I'm still
in flight
The thought of
Has anyone had
by reflection,
outer surfaces, it
offset them.
were not there !
Old May 6th 04, 03:11 PM
BllFs6
Just an optical tidbit guys....
The amount of light reflected from such surfaces is usually only gonna be 5 to
10 percent...not much....and not enough to cause a problem
HOWEVER, if a light "ray" intercepts a surface at a VERY shallow angle, you can
get VERY high percentage rate reflections...80/90 percent or more....ie the
light ray is "grazing" the surface....focus THAT much light on a small area and
you can very definitly cause problems...as a matter of fact thats how space
telescopes focus xrays (think about it...how else would you focus xrays
Try it with a piece of glass or plastic or a canopy or a car windshield...
Put the old eyeball close to the surface , looking almost parallel the surface
and you will see stuff in the distance reflected VERY brightly.....almost as if
the surface was a mirror...
So, Im pretty sure that both the shape of the inside of the canopy and the fact
the sun is "grazing" some area of the inside surface is whats causing the
problem....
take care
Blll
Old May 6th 04, 06:41 PM
Greg Arnold
5% of the sun's energy is a big problem
problem....
take care
Blll
Old May 6th 04, 06:56 PM
BllFs6
Do the cals and get back to me....
And dont say the but the canopy is HUGE....because size in this case doesnt
matter
Within reason, the ONLY parameter that makes a difference in melting/burning
something using the sun and a lens or a mirror is the F ratio.....ie the focal
length of the lens/mirror divided by effective diameter....
And to get stuff hot enough that number needs to be around 2...give or take
....and that assumes a very high transmission/reflection number....drop that
number to 5 percent and no real problem...unless your target is a dark
chocolate bar....
Now bring that number back up to MOSTLY transmitting or reflecting and
poof.....hence worrying about grazing reflections....
Now, you may not believe me....but the "hotness" of the "burn spot" doesnt
really matter (to first order) whether I have a lens/mirror 2 inches across or
60 inches across....only the f ratio matters...
take care
Blll
Old May 6th 04, 07:05 PM
Greg Arnold
matter
Hmm, I wonder why astronomers use those huge telescopes. Or why a huge
array of mirrors is used for attempts to harness the sun's energy.
chocolate bar....
take care
Blll
Old May 6th 04, 07:06 PM
Greg Arnold
matter
The focal ratio of my canopy is about 1 when it is reflecting light onto
my glare shield
chocolate bar....
take care
Blll
Antonov vs Galaxy cockpit Emilio Military Aviation 13 July 2nd 04 07:15 AM
"Friendly fire" Mike Naval Aviation 3 April 6th 04 07:07 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 06:02 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
Redundant canopy latching John Soaring 5 March 16th 04 01:50 PM
