All three legs. With a distance penalty no less (no kidding!). |
Graham Hodgson wrote:
What aircraft did you do your silver distance qualifying 50k flight in? Ka-6e. And when I am about to land out, I always wish I was back in it! It climbed so well in weak lift, landed slowly, and had powerful terminal velocity dive brakes. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
1-26 in Washington State @ 15 years old.
What aircraft did you do your silver distance qualifying 50k flight in? Annebula. A 15 meter homebuilt with a Stan Hall Cherokee fuselage and a new wing. Built by my dad. Flown by him and all three of his sons on various badges up to and including all three Diamond legs. From Kansas. Altitude was in a TG-3A. Duration in a Slinsgby Swallow. So far, each badge has had each leg in a different sailplane. What to use for the Diamond altitude.... Steve Leonard |
In message , Graham Hodgson
writes What aircraft did you do your silver distance qualifying 50k flight in? Astir CS 77 Robin -- Robin Birch |
Grob 102 Astir, same one as Vorsanger/Charles I'll hazard a guess.
If I remember correctly I got 'down' to 4000 ' AGL at about the midpoint and wasn't sure I was going to make it. I think I took about 20 thermals to do it too. I do remember the run back from the TP ( it was an out and return totaling 100km ) I got under a cloud street and in spite of flying straight and flat out I got back home higher than I had turned the TP. Took all of 20 minutes to get back after nearly 2 hours to get out there. Ian "Graham Hodgson" wrote in message ... What aircraft did you do your silver distance qualifying 50k flight in? |
"Graham Hodgson" wrote in message ... What aircraft did you do your silver distance qualifying 50k flight in? ASK 18. Dunstable to Husbands Bosworth. Up the M1 and turn right at Jct 19. Two thermals, 1hr 37mins. 13 years after getting the five hours. My 714th aerotow (too much instructing!!). Alistair Wright |
Alistair Wright wrote: "Graham Hodgson" wrote in message ... What aircraft did you do your silver distance qualifying 50k flight in? ASK 18. Dunstable to Husbands Bosworth. Up the M1 and turn right at Jct K18 here too !!! on may 21, 1988. Parham to Lasham. Had to be towed some 10 km in the other direction first (Washington roundabout) to make it 50k and nearly managed to land out coming back from there, before setting off on the task. Ended up getting the height gain and duration on the same flight. CV |
What aircraft did you do your silver distance qualifying 50k flight in? I'm tempted to claim I've forgotten. Actually it was a Skylark 2. -- Soar the big sky The real name on the left is richard |
Schweizer1-26 from what was then Henderson Sky Harbor, NV, to Searchlight,
NV. I arrived with only 10,000 feet to spare. I'm a little bit conservative. "Graham Hodgson" wrote in message ... What aircraft did you do your silver distance qualifying 50k flight in? |
| Thread Tools | |
| Display Modes | |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Declaring a free distance fight | Basil Fairston | Soaring | 0 | September 1st 03 09:27 AM |
| 15 M Time Management Nationals | Kilo Charlie | Soaring | 12 | August 15th 03 04:09 AM |
| Silver Badge Fun (?) | Mark Zivley | Soaring | 43 | July 14th 03 08:52 PM |
