Eric Greenwell wrote:
Mark James Boyd wrote: In article , goneill wrote: If they can not find the sawhorse they have used an empty cardboard box to hold the wing up. I like the idea of the (softer) cardboard box better than the sawhorse. A sawhorse seems like overenginee...oops, over-building ![]() Who removes the sawhorse or cardboard box from the runway after the takeoff? Prevailing wind will plaster the box against the airport fence, to be recycled after the flight. The next 1-26 to land will take care of the saw horse. ;-) Shawn |
Shawn wrote:
Prevailing wind will plaster the box against the airport fence, to be recycled after the flight. The next 1-26 to land will take care of the saw horse. Be careful what you say about the 1-26: your Mosquito could catch a Virus. Jack |
I get to do this about a dozen times a summer, from
a public 8,000' agl airport that gets warm...behind a cub. Not that I particularly like doing it, but otherwise no flying. Typically I also have to deal with a crosswind. My technique as follows, not saying this is the only way but has worked for me. 1.) The ship is going to weathervane...so I line up downwind of center line. 2.) I also point the nose slightly downwind. 3.) The downwind wing goes on the ground, this helps slow down the weathervane and also allows the wing to be picked up later. As the tow commences...the weathervane starts, and quite quickly...heading towards the center line on an angle from the leeward side. This typically allows the downwind wing to be ruddered up. As I approach the centerline I attempt to rudder straight and get the windward wing down. Some operations such as Warner Springs launch from a diagnol..and it sort of the same idea. I also make a point of being friendly to the airport bums...so as to have an alternative to this technique ![]() |
acckkk-
I don't think any technique works from 8k' agl....please substitute msl. The point being I drag along for a while waiting for the cub to get a head of steam up. |
I've launched many a time from a grass strip without a wingman. Of
course the glider will have a tendancy to turn toward the down wing, but you simply correct for that with rudder as the low wing starts to come up. However there are variables that may make things different for you. For example a good strong tug can make a huge difference in your ability to safely launch with a wing down. If you can't accelerate quickly then you are likely to be pointed far off course before your wing starts to come up. We fly with a 180 HP SuperCub at sea level. Also, I fly from a grass strip so dragging a tip on the ground is no big deal. Lastly some wing tips have skids that might have more of a tendancy than others to "grab" the ground beneath them. Look at one of the LS gliders as compared to a Schleicher to see what I am talking about. Bottom line is that it can be safely done under the right circumstances, and in fact I personally encourage you to practice it. This could make the difference between being able to fly, or not, if you are short handed at the gliderport some day. Respectfully, (Jerz Rossignol) wrote in message om... Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz |
Jerz Rossignol wrote:
Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. My experience is it's more reliable with a nose hook. I discovered this after I had a nose hook retrofitted to my ASW 20 C while it was in the shop to have a damaged wing tip fixed (the damage was caused by a botched attempt to launch without a wing runner). I suggest you consider having a nose hook fitted. In any case, be much more alert than usual, and ready to release at the hint of trouble. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
At 16:24 05 November 2004, Jerz Rossignol wrote:
I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Did it a long time ago next to Fasnakyle Hydro Power Station near Inverness. I drove the winch (a scrap car jacked up with a drum full of piano wire bolted to one rear hub and the differential jammed). The pilot in an Olympia 460 with one wing balanced on a pile of tyres at the other end. He eventually went to 13,000' in the wave after I had exited the winch with giant steps as the released wire narrowly missed the 132Kv pylons running down one side of the field! |
I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I do it regularly. No problem, neither winch nor aerotow, neither paved nor grass runway, if the grass is not too long. Start with aileron and rudder fully deflected, hold them fully deflected until the wing rises and then correct as needed. Be prepared to release immediately if something goes wrong. Stefan |
Disadvantages of CG hooks are overblown.
Have launched AS-W20 (many times), Libelle, Std. Cirrus, DG, LS-4 and likely others with CG hook and tip skids with no wingrunner. Have towed many as well. A method that has worked for me in the past. Assess situation. Deside at what point you will release if it is not working out, what the obstacles are on the upwind side of the runway, how "up" you are mentally for this, and risk / benefit analysis. Decide before pushing out / rigging if it is worth the risk today. 1) Put a/c on downwind side of runway centerline to allow for max possible amount of lateral drift toward Xwind and dragging wingtip. Not on the absolute downwind edge, but downwind of centerline. How much is a judgement call. 2) Put upwind wing on ground. It will come up quickest in this attitude. 3) Point aircraft "slightly" downwind. "Slightly" is a function of intensity of Xwind, wind velocity in general, a/c handling characteristics, and ground surface conditions. Obviously, more downwind heading in larger X-wind components and softer ground surface. Less for hard surface, less X-wind, and greater headwind. 4) Hold full downwind ("up-wing") rudder BEFORE takeoff roll begins. The goal is to minimize any upwind / down-yaw yawing inertia you have to overcome. Getting ahead of the system by having full rudder in before the roll begins is a very powerful tool. It is much easier to remove rudder than it is to stop a yaw that has already begun. 5) Review where release handle is and at what point you will pull off if wing is not up, you begin to laterally leave the useful runway surface, or you do not have sufficient control authority to continue. I have punched off multiple times in ridge conditions back east (USA) in rough, gusty 20+ kt Xwind before finally getting airborne. A good ridge day made it worth it and an excellent tow pilot (thanks Dad!), and some sage advice helped made it work. 5) Have tow plane take up slack, hold brakes, and apply T/O power. Tuggie should watch propwash behind him and not begin roll until propwash has reached glider - and hopefully for a second or 3 after that. Crucial issue is to decide quickly if launch is not working out and pull off before it builds up enough energy to bust airplane / hurt you. One can always push back and try again. Kiwi's in Omarama, NZ routinely retrieve fiberglass gliders wingrunner-less from remote strip / fields by using sticks and rocks to prop up wing. Have done it this way from a narrow strip and it works fine as well. Of course, all of this is "Dangerous", and R.A.S. Theorists will likely tell you about all the crashes these procedures cause. Pay your Money and Take Your Chances (Or Not). Best, Mark |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 03:21 AM | |
| Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 11:50 PM |
| Pegasus/TRACE Launch Photos Posted | Brian Webb | Military Aviation | 0 | February 21st 04 04:50 PM |
| Friendly fire pilot may testify against wingman | Otis Willie | Military Aviation | 0 | October 11th 03 10:32 PM |
