Is it Possible to Self launch (no wingman) with CG hook??
Old November 8th 04, 01:14 AM
John Cochrane
I've used the "stick" method several times on retrieves -- find two
sticks, put them under the wings to hold them level. It works best
with 10 mph or so headwind. If you can talk the tow pilot into running
up for 30 sec or so so you get some prop blast before you start and
less prop blast halfway through the roll that helps too.
One thing nobody has mentioned is that a good tailwheel is much more
important to the success of this sort of thing than nose vs. cg hook.
Gliders with a skid are much more vulnerable to groundloops, and
gliders with cg hooks plus skid are really bad. Keep the tailwheel
planted on the ground with full back stick until you're really sure
which way the glider is going. If you have an old glued-on skid, spend
the $100 to get a tailwheel instead.
John Cochrane (BB)
(Jerz Rossignol) wrote in message om...
Hi Guys,
I'm curious if any of you guys have ever tried to self launch with no
wing man on a cg hook only glider. I have skids on my wingtips as
well. Would you put the wing that's on the ground further forward at
start? What's the technique!!
I think this is why having a cg hook is a disadvantage.
Regards,
Jerz
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Vandenberg Launch, April 17 Piloting 5 April 9th 04 03:21 AM
Ground launch and the incremental vanishing of soaring Mark James Boyd Soaring 24 March 8th 04 11:50 PM
Pegasus/TRACE Launch Photos Posted Brian Webb Military Aviation 0 February 21st 04 04:50 PM
Friendly fire pilot may testify against wingman Otis Willie Military Aviation 0 October 11th 03 10:32 PM
