Scott Moore wrote: Bob Gardner wrote: http://www.avweb.com/newswire/10_18a.../187168-1.html This will link you to an article that describe LAAS as being delayed for quite a while. Don't hold your breath. Bob Gardner The principle problem with LAAS is that the government has a schedule to replace ALL of the GPS sats with higher precision versions. I.e., the precision of GPS is going up, without any particular new infrastructure going into place on the ground or in the air. Actually, a principle problem with LAAS is that the funding was seriously scaled back. The CAT I portion of the program was still in the R&D phase, as they were working the issues (problems with interference/iono, i believe, were still not resolved). Which means that by the time any LAAS program got on its feet, standard GPS, and presumably WAAS, might well offer the same capability. -- Samiam is Scott A. Moore I'd be sufficiently impressed if WAAS could provide CAT III, even with dual-frequency, denser network of ground reference stations, algorithm tweakage etc. Regards, Jon |
An important part of the precision approach environment is the airport
surface itself: an adequate runway clear zone and adequate approach lighting. Just because you can get a WAAS signal does not mean a particular runway is going to be appropriate for a 200 ft minimum. Dave wrote: I have the ear of some local government development people, who are contemplating upgrading some airports. Money is tight, so an ILS is probably not under consideration. So, I want to recommend to them checking into a WAAS installation. Does anyone know what the prices of such equipment for an airport are, which companies are selling them, and how much it costs to get the FAA to then create a WAAS IFR approach? Sincerely, /iaw |
Dave S wrote: An important part of the precision approach environment is the airport surface itself: an adequate runway clear zone and adequate approach lighting. Just because you can get a WAAS signal does not mean a particular runway is going to be appropriate for a 200 ft minimum. For whatever it's worth, the runway markings, taxiway spacing, and obstacle clearance areas are what make for a 200-foot Decision Altitude (DA). Approach lights (ALS) are for visibility credit. With everything else satisfied but no ALS the DA will still be 200 feet, with a visibility of 3/4. Add ALS to that environment and it becomes 200 and 1/2. |
Now this I find interesting.
I understand obstacle clearance, but had no idea that runway markings and taxiway spacing affects DA. I can understand runway markings (although I thought they were standard for precision approaches) but taxiway spacing? Porque? On Wed, 16 Feb 2005 05:06:50 -0800, wrote: Dave S wrote: An important part of the precision approach environment is the airport surface itself: an adequate runway clear zone and adequate approach lighting. Just because you can get a WAAS signal does not mean a particular runway is going to be appropriate for a 200 ft minimum. For whatever it's worth, the runway markings, taxiway spacing, and obstacle clearance areas are what make for a 200-foot Decision Altitude (DA). Approach lights (ALS) are for visibility credit. With everything else satisfied but no ALS the DA will still be 200 feet, with a visibility of 3/4. Add ALS to that environment and it becomes 200 and 1/2. |
surface itself: an adequate runway clear zone and adequate approach lighting. Just because you can get a WAAS signal does not mean a particular runway is going to be appropriate for a 200 ft minimum. For whatever it's worth, the runway markings, taxiway spacing, and obstacle clearance areas are what make for a 200-foot Decision Altitude (DA). Approach lights (ALS) are for visibility credit. With everything else satisfied but no ALS the DA will still be 200 feet, with a visibility of 3/4. Add ALS to that environment and it becomes 200 and 1/2. For now, the lowest possible DA for WAAS approaches (LPV minima) is 250 feet. Getting down to 200 feet (GLS minima) will require major system changes, probably including a second civil GPS frequency, and will not happen before 2013 at the earliest. |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 04:03 AM |
| Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 06:35 PM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Piloting | 16 | January 20th 04 05:02 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
