Clearance with an Odd Intersection
Old February 25th 05, 01:50 AM
is MONDI on a SID ?
Information on fix MONDI
Identifier: MONDI
ARTCC: ZBW
Fix to be published? yes
Navaid radial/DME: MAD /cgi-bin/navaid-info?a=MADr126.00
GON /cgi-bin/navaid-info?a=GONr226.45
HTO /cgi-bin/navaid-info?a=HTOr033.56
I-GON SW CRS/13.23
Charts: IAP
Fix use: Reporting point
if you don't under stand the clearance ask ? for clarification
try not to accept any clearance you don't understand
jon
Old March 11th 05, 02:21 AM
Charlie Derk
Typically, if you file your IFR flight plan with /G, I think ATC assumes
that its an IFR Certified GPS and that the intersection is in the
database. I've gotten something like this before, but it was enroute
and ATC asked me if I could identify the intersection. After I
acknowledged that I could, ATC told me "Direct to" that intersection.
Regards,
Charlie
Marco Leon wrote:
Has anyone received a route clearance that included an intersection that was
only on an approach chart and not in an Enroute Chart?
Flew IFR from FRG to GON with the following clearance: Farmingdale Three,
radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct.
For the life of me I couldn't find MONDI on the enroute. However, it was in
my (up-to-date) Garmin 430 database and it was pretty much on the way
(albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is
only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the
active approach which made it even more difficult to figure out.
Is this commom anywhere else? Should they have told me it was only on an
IAP chart? Are all the fixes on any of a given airport's approach charts
fair-game to include in an enroute clearance?
Regards,
Marco Leon
Old March 11th 05, 02:23 AM
Steven P. McNicoll
"Charlie Derk" wrote in message
database.
Why would ATC assume anything else?
Old March 11th 05, 03:30 PM
jsmith
Yes, but to enter the intersection into your flight plan on your GPS,
you must first know how it is spelled. If you are not familiar with the
area you are flying in and the controller speaks the name of an
intersection, you may not know where to look on the chart to see how it
is spelled.
Old March 11th 05, 04:16 PM
The recommended procedure if you don't know how to spell the identifier
is to respond with "Say Identifier". If it will take awhile to program
the intersection into the GPS, you could also ask for a heading.
it
is spelled.
assumes
enroute
intersection.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 11:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 07:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 10:11 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 05:55 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
