Vacuum Gyro Question
Old January 8th 05, 10:45 PM
Jim Carriere
Default Vacuum Gyro Question
This is one of those questions where there must be a simple answer.
This is probably the forum to get the best explanation.
Why aren't vacuum driven gyro instruments driven by pressure instead?
The reason I'm wondering is because about 2" of suction is
sufficient to power a turn needle, and while attitude gyros require
more, about 5", either of those amounts is still much less than
standard atmospheric pressure, meaning that the absolute pressure
inside the instrument is still close to ambient pressure.
Note other than seeing one on an instrument panel, I've never
actually taken apart or looked at the inside of any of these instruments.
In other words, what am I missing and what don't I understand? Thanks!
Old January 8th 05, 10:52 PM
x
This is a fantastic question. I sure can't think of any good reason.
"Jim Carriere" wrote in message
This is one of those questions where there must be a simple answer. This
Why aren't vacuum driven gyro instruments driven by pressure instead? The
reason I'm wondering is because about 2" of suction is sufficient to power
a turn needle, and while attitude gyros require more, about 5", either of
those amounts is still much less than standard atmospheric pressure,
meaning that the absolute pressure inside the instrument is still close to
ambient pressure.
Note other than seeing one on an instrument panel, I've never actually
Old January 8th 05, 11:04 PM
nafod40
Well, they are. They are driven by a pressure differential between the
input and output.
As for why we lower the output pressure rather than raising the input
pressure...I'm guessing that a venturi in the airflow is
easier/better/more efficient than trying to use some sort of ram air
device to raise it.
Old January 9th 05, 12:01 AM
UltraJohn
Some systems ARE designed to work off of pressure. Depending on the system
designer.
John
Old January 9th 05, 12:16 AM
Colibri
designer.
John
If the carbon vanes in a vacuum pump fail, any debris will be blown
overboard. If the pump pressurizes the instruments, the debris will be
blown into the instruments, ruining them.
Old January 9th 05, 12:48 AM
Jim Carriere
designer.
Hmm, I learn something new every day.
I figured maybe there was some technical reason they had to use
vacuum, since most of the instruments one can buy seem to be either
electrical or vacuum. From your answer, I suppose there is no real
reason, maybe most of the non electrical ones are vacuum because that
is just the way things are.
Old January 9th 05, 01:31 AM
Jim Carriere
This is a good point, although hopefully a filter would protect
against this expensive possibility.
Old January 9th 05, 02:01 AM
UltraJohn
Colibri's response is why most are driven off the vacuum side but it isn't a
requirement. Like was mentioned the filter provides some protection.
According to an article in the newest Private Pilot magazine on twins. The
Beech Duchess Model 76 that they review is run off the pressure side of the
pumps (page 52, February 2005). They also mention most Beechcrafts are done
that way.
John
Old January 9th 05, 03:20 AM
Juan Jimenez
They _are_ being driven by air pressure. The air is sucked in from the cabin
and through an air filter by the vacuum generated by the pump (or venturi).
The filter is inside the cabin. This setup comes from the fact that when
faced with the choice of air from the outside (or from the engine
compartment), or air sucked in from the cabin using the vacuum generated by
a venturi or pump, the latter is considered more suitable to contribute to a
longer instrument working life.
ambient pressure.
Old January 9th 05, 05:43 PM
Jerry J. Wass
Most succinctly expressed!
ambient pressure.
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 06:17 PM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 09:27 AM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 16th 04 12:30 AM
Gyro Copter for Sale on EBAY EC155 Pilot Home Built 0 November 2nd 03 12:34 AM
NACA duct ventrui Chris W Home Built 7 October 27th 03 05:11 PM
