How did you get to this point in the first place, maybe based on that
we can make some suggestion. Was the design overweight by design or was it over built? How close is the empty weight to that of the prototype? |
"Fortunat1" wrote in message
. . . so I'm going to have to learn to build an aluminum tank.. Anyone know of a resource to show me how? ![]() The books by Tony Bingelis have excellent tips on this. http://www.amtbooks.com/sport_plane_...on_techniq.htm Rich Shankland |
I would check with a Van's builder. RVs have aluminum riveted tanks with
pro-seal. If you know a good tig welder, then a welded tank can be built. "Fortunat1" wrote in message ... "Rich S." sednews:_fydnZvUOMpYONnfRVn- : "Fortunat1" wrote in message . . . so I'm going to have to learn to build an aluminum tank.. Anyone know of a resource to show me how? ![]() The books by Tony Bingelis have excellent tips on this. http://www.amtbooks.com/sport_plane_...on_techniq.htm Mm, have all of his books and I don't remember seeing an article about ali tank construction, but I did find this article from SA on the net.. http://members.eaa.org/home/homebuil...About%20An%20A luminum%20Fuel%20Tank_.html |
"Cy Galley" sednews:4V41e.103754$r55.32258@attbi_s52:
I would check with a Van's builder. RVs have aluminum riveted tanks with pro-seal. If you know a good tig welder, then a welded tank can be built. OK, thanks.There are two down the road from me, in fact! I'll probably try and weld it myself, though I've never welded aluminum before. Then again, most ofthe things I've done on this contraption I've never done before. ![]() I'm assuming baffles (and I think I'd need them in a long shallow wing tank) aren't welded, though. I'm supposing that the tank would be assembled, but the back left open until the baffles are all riveted, and then closed up and welded? |
Fortunat1 wrote:
"Cy Galley" sednews:4V41e.103754$r55.32258@attbi_s52: I would check with a Van's builder. RVs have aluminum riveted tanks with pro-seal. If you know a good tig welder, then a welded tank can be built. OK, thanks.There are two down the road from me, in fact! I'll probably try and weld it myself, though I've never welded aluminum before. Then again, most ofthe things I've done on this contraption I've never done before. ![]() I'm assuming baffles (and I think I'd need them in a long shallow wing tank) aren't welded, though. I'm supposing that the tank would be assembled, but the back left open until the baffles are all riveted, and then closed up and welded? I see no reason not to weld the baffles as well. Probably less messy than sealing the rivets. Matt |
Having just finished the tanks for my RV-7, I agree with Cy. If you're
in the USA, call Van's A/C & get the name of a builder near you & go look at the plans for the tank/leading edge to get an idea of how they go together. If you can handle cutting & fitting the aluminum, the rest is pretty simple & you can build with a drill & a cheap 'pop' rivet tool using closed end pulled rivets. AD41H aluminum body steel mandrel is what's used to attach the back baffle to the ribs. You'll need at least a couple of internal ribs to stiffen the 2x4 foot top & bottom panels. The hardest thing will be bending up the 'box' but a good sheet metal shop can do that for you. (Be sure to tell them to use the proper radius on the bends.) You will be amazed at how light it will be. Charlie Cy Galley wrote: I would check with a Van's builder. RVs have aluminum riveted tanks with pro-seal. If you know a good tig welder, then a welded tank can be built. "Fortunat1" wrote in message ... "Rich S." sednews:_fydnZvUOMpYONnfRVn- : "Fortunat1" wrote in message . . . so I'm going to have to learn to build an aluminum tank.. Anyone know of a resource to show me how? ![]() The books by Tony Bingelis have excellent tips on this. http://www.amtbooks.com/sport_plane_...on_techniq.htm Mm, have all of his books and I don't remember seeing an article about ali tank construction, but I did find this article from SA on the net.. http://members.eaa.org/home/homebuil...About%20An%20A luminum%20Fuel%20Tank_.html |
| Thread Tools | |
| Display Modes | |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| Dutch Roll | SelwayKid | Piloting | 31 | June 20th 04 12:43 AM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
| F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 08:32 PM |
| Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 05:20 AM |
