general to the group: in spin training, what seems to have been been
the most popular way to screw up? i understand the drill and i'm having trouble picturing how to mess up that badly in the typical training cessana starting at maybe 2500' agl. As someone else mentioned, using aileron instead of rudder. Admittedly, I almost did it on my first ever spin while training....it's instinctive, and it's a *hard* habit to break, especially when you are at such an unusual attitude after the wing drops and the nose suddenly is pointed towards the ground. :-) I caught myself in mid-movement of the yoke, and corrected ailerons back to neutral for the rest of the recovery, but the instinct to correct with aileron before the plane is actually flying again, and not stalled, is overwhelming. On the first one or two spins, there is definately an "oh crap" factor that causes your hands to override what your head is telling you is the "right thing" to do. My instructor suggested that I "Wedge" my elbow somewhere on the door to prevent me from physically using aileron untill I got past the actual spin, and have recovered from it. That worked for me, although after the 3rd spin (I think we did 5 or 6 in the lesson plan) I had it pretty much down, and really didn't need to do that any longer. As for 2500 AGL you quoted, that's wayyyyy low.. Our training area is about 650' asl, and we were climbing through to 4500' before each spin... It was a comfortable height, and even after recovery from 2 or 3 turns in the spin, I never felt uncomfortably low. |
"Mark Morissette" wrote in message
... As for 2500 AGL you quoted, that's wayyyyy low.. Our training area is about 650' asl, and we were climbing through to 4500' before each spin... It was a comfortable height, and even after recovery from 2 or 3 turns in the spin, I never felt uncomfortably low. The only inadvertant spin that I ever encountered was in an S2B... We were doing 90 degree bank 90 degree turns and I didn't have the ball centered and ended up in an accelerated stall and then a roll through 270 degrees in the opposite direction to the turn in what seemed like less than a second... Next thing I knew, the nose was pointed towards the ground... I'm not sure of our altitude since it's been a few years since it happened, but I seriously doubt that it was more than 2000 ft MSL (which basically equals AGL in Houston)... Coming out of it was no big deal in the S2B with plenty of room to spare... The instructor even had time to ask me if I knew what I had done and how I was going to recover from it... |
On Sat, 02 Apr 2005 21:38:42 -0500, Mark Morissette
wrote: As for 2500 AGL you quoted, that's wayyyyy low.. Our training area is about 650' asl, and we were climbing through to 4500' before each spin.. At Chandler AZ, they set the altimeter at field altitude, which was the same altitude as the desert to the southeast where they did their training. As I recall, we were always above 4,000 feet before starting any maneuver. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
houstondan wrote:
general to the group: in spin training, what seems to have been been the most popular way to screw up? The best way to make it terminal seems to be to get the loading wrong in such a way that you can't recover from the spin. According to a fellow I spoke to at the Maule factory, it is nearly impossible to recover in an MX-7 with the CG at one extreme of the envelope (he did not remember which extreme but thought it might be aft). Maule placards the aircraft "Intentional spins prohibited." Between 5 and 10 years ago, two CFIs died in a PA-28 near Solberg when the spin went flat. The last time this thread surfaced, several people said that loading is also critical in some models of C-172. George Patterson Whosoever bloweth not his own horn, the same shall remain unblown. |
George Patterson wrote:
houstondan wrote: general to the group: in spin training, what seems to have been been the most popular way to screw up? The best way to make it terminal seems to be to get the loading wrong in such a way that you can't recover from the spin. According to a fellow I spoke to at the Maule factory, it is nearly impossible to recover in an MX-7 with the CG at one extreme of the envelope (he did not remember which extreme but thought it might be aft). Maule placards the aircraft "Intentional spins prohibited." Between 5 and 10 years ago, two CFIs died in a PA-28 near Solberg when the spin went flat. The last time this thread surfaced, several people said that loading is also critical in some models of C-172. Loading is important is pretty much all airplanes. Having the CG too far aft will tend to induce a flatter spin and give the rudder less authority. Matt |
"houstondan" wrote in message oups.com... general to the group: in spin training, what seems to have been been the most popular way to screw up? Well, maybe not the most popular, but there are also odd things that can go wrong: A guy practicing spins in his Citabria down in Borrego Springs managed to get a loose seatbelt in the empty seat wrapped around the control stick. He chose to join the Caterpillar Club rather than ride his airplane down (wise choice). An instructor and his student in Canada managed to jam the rudder on a Cessna 152 when a maintenance man made undocumented modifications to the rudder. Attempts to un-jam it just made it worse. They landed in a lake. They both survived the initial landing, but the instructor got tangled in his seat belt and drowned. |
One of our "anal" preflight checks on our 172 is to be SURE the
rudder squarely contacts the stops on the extreme of travel. Mis- alignment of these stop screws on a Cessna caused a rudder to jam at full deflection causing a fatal crash a few yrs ago... ![]() Dave On Sun, 3 Apr 2005 13:11:58 -0700, "C J Campbell" wrote: "houstondan" wrote in message roups.com... general to the group: in spin training, what seems to have been been the most popular way to screw up? Well, maybe not the most popular, but there are also odd things that can go wrong: A guy practicing spins in his Citabria down in Borrego Springs managed to get a loose seatbelt in the empty seat wrapped around the control stick. He chose to join the Caterpillar Club rather than ride his airplane down (wise choice). An instructor and his student in Canada managed to jam the rudder on a Cessna 152 when a maintenance man made undocumented modifications to the rudder. Attempts to un-jam it just made it worse. They landed in a lake. They both survived the initial landing, but the instructor got tangled in his seat belt and drowned. |
Hmmm.
I've done lots of spin training - in Canada. There are all kinds of stats, which can be made to say pretty much anything that you want. So is the teaching of spins dangerous? It sure as hell is if you are with a brand new 300 hour CFI. But would you take spin training with Dudley, or Gene, or Bob, or CJ? I would. I took my spin training with a 3000 hr CFI. But I sure as hell wouldn't do it with a newly minted CFI. And yes - I do accept that they have to practice somewhere - but not on me and not on my dollar. Oh - and if you happen to own a Cirrus - this discussion doesn't apply to you - those guys managed to build the first aircraft since WW1 that can't recover from a spin! Flame away - it's true! Tony In article , Mark Morissette wrote: What's eveyrones opinion regarding the lack of spin traning for students in the US? I see that there was a thread about this from an instructor viewpoint a while back, but not necessarilly from the student viewpoint. Personally, there was only two lessons that I didn't look forward to - Spin training, and spiral dives. Spiral dives turned out to be nothing at all.. 15 minutes, 4 or 5 spirals, quick and safe recoveries, and that was over. Nothing to it, I was worried about something which amounted to easy training. Spins however, as comfortable of a student as I am, got me a little excited. However, we went out, did them, and that was it. Looking back on things, I'm *very* glad that they are still part of the curiculum here in Canada. It's easy to "read" about something in the POH and try to cram all that into your cranium should the situation ever occur, but... Can anyone here honestly say that everything they've ever read, versus practiced in the air, equals the same training-wise? For example, if you never had spin training, and suddenly found yourself in a spin, would you be confident that everything you "read" about them will get you out of it? Yes, you can read what's necessary, but can you automatically recall all of that in the air, when your first inintentional "lesson" on spins could possibly be at 1000AGL in the circuilt? I've consistently found that lessons practiced quickly become second nature, whereas things I've read take much more time to fully grasp untill it comes into real-life practice...and there is no substitution for the real thing - anyone who has spent time flying MS Flight Simulator before flying the real thing can certainly attest to this. Yes, the spins were not fun.. I wasn't one of the students who were so paranoid of them that I was cancelling flights to avoid the inevitable, and then ended up in the fetal position on the floor of the plane during them - I just wasn't "excited" about them like everything else. grin Yep, there was a whole lot more "Ground" in the windscreen all of a sudden then I ever want to see again. But I'm glad I did it. During the actual training, my proficiency with initiating, and (more importantly) recovering from the spins gained rapidly. By the 4th or 5th spin, I was able to recover consistently and quickly, without much "thinking" about what to do, and more "automatically" just doing it. More importantly, I was in the 100's of feel of alt lost, instead of the 1000's in the first spins. If an unintentional spin ever happened in the circuit, I'm much more likely to be able to recover before hitting terra-firma now, then I would have been initially. I can't honestly say that if spin training was not part of the curriculum here still, that I wouldn't ask for it regardless..fun or otherwise.. But reading here in the newsgroups, it seems as if most schools in the US no longer train them, even if they are still technically allowed, but not required? Opinions? Mark Morissette Courtice, Ontario, Canada (Flying out of CYOO) http://oshawapilot.blogspot.com -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
"tony roberts" wrote in message
news:nospam-FC7608.22253002042005@shawnews... Oh - and if you happen to own a Cirrus - this discussion doesn't apply to you - those guys managed to build the first aircraft since WW1 that can't recover from a spin! What about the AA1? NASA had to add a drogue chute to them for their spin testing... |
My instructor followed his own rules, and a spin demonstration was one of them. That was in 1996. The demonstration fascinated me enough that a couple years later I went out to Chandler AZ for spin training and some minor aerobatics. www.pipercubforum.com/chandler.htm -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 03:18 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
