"Rich S." wrote in message
... The end result was a smooth, compound-curved, thin, light, streamlined shell of a body. Hah! I thought I had one - just one - picture around here someplace. You can see it at http://tinyurl.com/4xqyw Rich S. |
"Rich S." wrote: "Rich S." wrote in message ... The end result was a smooth, compound-curved, thin, light, streamlined shell of a body. Hah! I thought I had one - just one - picture around here someplace. You can see it at http://tinyurl.com/4xqyw Rich S. Forget that. I want the four-foot long micrometer secret! -- Alan Baker Vancouver, British Columbia "If you raise the ceiling 4 feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
BA-100 wrote:
Does the cedar strip technique you mention use multiple layers of veneer? Presumably you need a form to wrap this around. Does it have to be solid or can you just use formers, say, every 9 inches or so? How do you clamp to get a good bond between layers? http://www.oneoceankayaks.com/Kayaks.htm The web site I was looking at for a kayak. Yes to your question of formers Their plans give you full size former layouts that you cut out put on the plywood and cut the formers from there. They then attach the formers to a central beam and proceed to lay up the wood strips using whatever wood to get the design they want mostly cedar with mahogany for designs. after they do the top half they cover with fiberglass and epoxy. They then remove from the formers (you did use waxpaper on the formers right?) and fiberglass and epoxy the inside. They then repeat with the bottom side. Then you fit the two sides together and apply fiberglass tape and epoxy to both inside and outside of the joint. Basically instead of using foam for a core they use wood strips. As soon as I finish this KR-2 in my garage (about another 10 years) I'm going to start on my Cape Ann Double Kayak! John |
Question: Does the cedar strip technique you mention use multiple layers of
veneer? Presumably you need a form to wrap this around. Does it have to be solid or can you just use formers, say, every 9 inches or so? How do you clamp to get a good bond between layers? Response: Some of the cedar strip boats that I built were made from 1" x 6" cedar planks, which means they were about 3/4" thick. Then I ripped those planks on a saw (table saw, band saw or radial arm saw - whatever is handy). This will give you long strips that are about 3/4" wide and 1/4" thick. Cedar is used because it bends easily, looks good and is light. Stations are built conforming to the curved shape you want. Each station is about 12" to 16" apart. Wax paper or tape are put over the plywood forms. The first strip is installed, and following strips are glued adjacent to the first step. The strips are stapled onto each form. Alignment between stations can be assured by clamps over the strips you are gluing. The glue does not matter, becase no strength comes from it. You can butt joint each piece. Although some perfectionists angle the edges of the strips going around a curve, it is not necessary. If there is a slight opening, epoxy will seep in and make the structure stronger. The cedar simply replaces foam, and the strength comes from the layers of cloth and epoxy resin. Carbon fiber is stronger and lighter, but would cover up the beautiful cedar strip finish, but could be used on the inside. Obviously, the application and strength of the epoxy will control the strength of the overall structure, but it can be quite high. The strength requirements for the fuselage of something like a Bowlus would be quite low - but there would obviously need to be some method of attaching the wings to the fuselage and spreading out the stress of the lifting point. However, the pod itself could be created similar to a cedar strip kayak. My 17 foot cedar strip kayak weighs about 50 pounds and I made no effort to save weight. One other process, which could be used is a process developed for the HK-1 Hughes "Spruce Goose" It is built of laminated birch. As I understand the process, the it was plywood made in the shape required for the aircraft and known as Duramold. The aircraft companies made a number of small boats using the same process to perfect it. The Evergreen museum no doubt has some information on the process. The inventive can replace the Molt Taylor Aerocar of yesteryear with a Glider/kayak. When making an outlanding, simply land by a lake ro river, remove and store the wings and tail, and paddle home. Colin N12HS |
COLIN LAMB wrote:
Question: Does the cedar strip technique you mention use multiple layers of veneer? Presumably you need a form to wrap this around. Does it have to be solid or can you just use formers, say, every 9 inches or so? How do you clamp to get a good bond between layers? Response: Some of the cedar strip boats that I built were made from 1" x 6" cedar planks, which means they were about 3/4" thick. Then I ripped those planks on a saw (table saw, band saw or radial arm saw - whatever is handy). This will give you long strips that are about 3/4" wide and 1/4" thick. Cedar is used because it bends easily, looks good and is light. Stations are built conforming to the curved shape you want. Each station is about 12" to 16" apart. Wax paper or tape are put over the plywood forms. The first strip is installed, and following strips are glued adjacent to the first step. The strips are stapled onto each form. Alignment between stations can be assured by clamps over the strips you are gluing. The glue does not matter, becase no strength comes from it. You can butt joint each piece. Although some perfectionists angle the edges of the strips going around a curve, it is not necessary. If there is a slight opening, epoxy will seep in and make the structure stronger. The cedar simply replaces foam, and the strength comes from the layers of cloth and epoxy resin. Carbon fiber is stronger and lighter, but would cover up the beautiful cedar strip finish, but could be used on the inside. Obviously, the application and strength of the epoxy will control the strength of the overall structure, but it can be quite high. The strength requirements for the fuselage of something like a Bowlus would be quite low - but there would obviously need to be some method of attaching the wings to the fuselage and spreading out the stress of the lifting point. However, the pod itself could be created similar to a cedar strip kayak. My 17 foot cedar strip kayak weighs about 50 pounds and I made no effort to save weight. One other process, which could be used is a process developed for the HK-1 Hughes "Spruce Goose" It is built of laminated birch. As I understand the process, the it was plywood made in the shape required for the aircraft and known as Duramold. The aircraft companies made a number of small boats using the same process to perfect it. The Evergreen museum no doubt has some information on the process. The inventive can replace the Molt Taylor Aerocar of yesteryear with a Glider/kayak. When making an outlanding, simply land by a lake ro river, remove and store the wings and tail, and paddle home. Colin N12HS Sounds like some of the early Curtis flying boats. I think they'd be fun. Dan, U.S. Air Force, retired |
"COLIN LAMB"
thlink.net: Question: Does the cedar strip technique you mention use multiple layers of veneer? Presumably you need a form to wrap this around. Does it have to be solid or can you just use formers, say, every 9 inches or so? How do you clamp to get a good bond between layers? Response: Some of the cedar strip boats that I built were made from 1" x 6" cedar planks, which means they were about 3/4" thick. Then I ripped those planks on a saw (table saw, band saw or radial arm saw - whatever is handy). This will give you long strips that are about 3/4" wide and 1/4" thick. Cedar is used because it bends easily, looks good and is light. Stations are built conforming to the curved shape you want. Each station is about 12" to 16" apart. Wax paper or tape are put over the plywood forms. The first strip is installed, and following strips are glued adjacent to the first step. The strips are stapled onto each form. Alignment between stations can be assured by clamps over the strips you are gluing. The glue does not matter, becase no strength comes from it. You can butt joint each piece. Although some perfectionists angle the edges of the strips going around a curve, it is not necessary. If there is a slight opening, epoxy will seep in and make the structure stronger. The cedar simply replaces foam, and the strength comes from the layers of cloth and epoxy resin. Carbon fiber is stronger and lighter, but would cover up the beautiful cedar strip finish, but could be used on the inside. Obviously, the application and strength of the epoxy will control the strength of the overall structure, but it can be quite high. The strength requirements for the fuselage of something like a Bowlus would be quite low - but there would obviously need to be some method of attaching the wings to the fuselage and spreading out the stress of the lifting point. However, the pod itself could be created similar to a cedar strip kayak. My 17 foot cedar strip kayak weighs about 50 pounds and I made no effort to save weight. I'm pretty sure that the process would be to heavy for the strength it would provide, unless it were modified to provide several very thin crossing layers, all of which woul have to be tightly glued to each other to have any real strenght. But an idea has just popped into my so-called mind.. If I were to make three mold of each side freehand over a male mold, each 90 deg to the last, and then take them and stack them over the same mold and vacuum bag the whole lot together.... Hmm. One other process, which could be used is a process developed for the HK-1 Hughes "Spruce Goose" It is built of laminated birch. As I understand the process, the it was plywood made in the shape required for the aircraft and known as Duramold. The aircraft companies made a number of small boats using the same process to perfect it. The Evergreen museum no doubt has some information on the process. This isn't to far off the original method of manufacture for the Baby as i understand it. The inventive can replace the Molt Taylor Aerocar of yesteryear with a Glider/kayak. When making an outlanding, simply land by a lake ro river, remove and store the wings and tail, and paddle home. Would have come in handy at least once in my gliding career when I left a waterline on a 2-33! |
I'm pretty sure that the process would be to heavy for the strength it would provide, unless it were modified to provide several very thin crossing layers, all of which woul have to be tightly glued to each other I'm no expert in (or any field) but several people have mentioned about the lack of strength a single layer plywood would have and you'd need several layers (ad various angles) etc etc. Yet the most common new "core" constructions uses styrofoam for a core, I'd think the plywood at almost any thickness would be stronger. The reason for use the plywood would be for the looks (at least that's my guess). John |
In article . net,
"COLIN LAMB" wrote: I just looked at the fueslage of the Bowlus and it would be easily duplicated using cedar strip techniques. Assembly is very quick with almost no tools required, except for a saw to cut the wood strips. I did use some mahogany in one of my canoes, just to try it, and it works fine. Because the inside of the fuselage does not require the transparancy that the outside does, you could even use one of the lighter and stronger cloths (such as carbon fiber). This would result in increased strength and lighter weight. Now I may have to build one. The tube from front to rear could be constructed easily using carbon fiber cloth rolled into a tube, or a commercial tube purchased. Colin You might want to explore this site: http://single-handedskiffs.com/pages/453349/index.htm That is a sailboat constructed along the lines being discussed. What's interesting and germane to note is the *loads* on such a boat created by the rigging. Typical standing rigging (that which holds up the mast) is tensioned to hundreds of pounds, so you can get some idea of the loads created between the rigging pulling upward and the mast pushing down. There are some notes about the resin system used (from West, IIRC) and some strength testing done on sample panels. -- Alan Baker Vancouver, British Columbia "If you raise the ceiling 4 feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
| Thread Tools | |
| Display Modes | |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| Randolph Wing Walk Compound | Larryskydives | Owning | 7 | March 7th 04 10:44 PM |
| Plywood | Kathi Jo | Home Built | 3 | January 12th 04 11:48 PM |
| Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 03:40 PM |
| Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 09:02 PM |
