"Dick" wrote: George or Richard, A little off the subject. A fellow at my airport had heard of a method to remove scratches. It involved plastic, I think acrylic, figurines and a propane torch heating slightly the scratches to "erase" them. I was wondering if anyone had any such knowledge. My yet-to-be installed, 20year old canopy was lightly sanded with the wrong grit and scratched up both inside and outside. After researching the methods available to sand/polish them out and considering greatly differing opinions, I'd like to find another method short of buying/making a new canopy. Thanks, Dick I have an experiment: 1. Take a piece of Plexiglass scrap and cut it qith a bandsaw. 2. File the big scratches and gouges out of the sawed end. 3. Start wet sanding with #320, then #400, then #600, then #1200, then #2000 grit, stepping up the grit as smoothness is reached. Wash between sandings. 4. Take automotive rubbing compound to the edges worked and look for polished areas. 5. When the whole desired area appears polished, apply automotive polishing compound. (You can also use tooth powder.) Use lots of water in all processes. You can also start with a piece of scratched-up Plexiglass and work through the same steps. The end result is a piece of polished Plexiglass with no visible scratches. |
George/Dave: I used balsa wood sheets tacked down to the correct contour on a
former rather than felt. It worked well for small size side windows in our kitchen oven. Larry |
| Mini-500 websites, answered by Dennis Fetters | [email protected] | Home Built | 0 | January 23rd 05 12:29 AM |
| Would you like to write about your hobby for one of the UK's top websites? | Steve Roche | Home Built | 0 | February 13th 04 11:36 AM |
| Zenith Ch 701 Builder's info and websites?? | DL152279546231 | Home Built | 1 | February 10th 04 09:21 PM |
| homebuilder websites updated daily? | Joa | Home Built | 6 | December 28th 03 08:30 PM |
