2-stroke diesel is the (near) future?
Old May 8th 05, 09:55 PM
Dan
Diesel aircraft engines for certified and experiimental aircraft are here
now.
http://www.centurion-engines.com/c17/c17_start.htm
There are others also.
Old May 9th 05, 03:28 PM
Don Stauffer
now.
To prevent going to much OT in rec.auto.tech, if you wish to discuss
engines other than car engines, there is a Yahoo group called heat
engines, for discussion of any heat engine, IC, steam, or other.
http://groups.yahoo.com/group/heatengines/
You can access it as a web discussion group, or you can receive and post
via email.
We'd be happy to see more folks join, and liven up the discussions.
Old May 8th 05, 10:29 PM
John S.
That's not a new design.
Old May 12th 05, 07:40 PM
Andrew P.
Wandering aimlessly about the Web, I heard Max Kallio say:
Proposal for a future (helicopter) engine...
2-stroke diesel
2500cc two cylinder 45 degree V (120-150hp)
air cooled (cowlings)
common rail direct injection (high pressure)
supercharged (Whipple fixed displacement max. 25 psi twin-screw)
piston ported (or with LIM-type intake valve)
Links...
www.limtechnology.com
www.zoche.de
-- SNIP --
I've been watching Zoche for 6-7 years, and as far as I know, they still
haven't released anything to the market that you can buy. The material
on their web site hasn't been updated in three or four years. Their
aerodiesel designs look good -- excellent power/weight, fuel economy
significantly better than gasoline, use of more widely available jet
fuel or kerosene, projected high reliability and life due to much lower
component count than 4-stroke engines, compressed air starter eliminates
need for large, heavy cranking battery, etc., etc.
Unfortunately, Michael Zoche got wrapped around an axle in typical
German mindset by trying to get JAR-E and FAR-33 certification before
marketing the engines. That's kept them entangled in bureaucratic red
tape for years, particularly in Germany. (The bureaucracy in Germany is
phenomenal. It's little wonder Germans have been relatively
non-innovative in the world market, compared to Japan and the U.S.) It
would have been better to get some of their smaller, lighter engines
into the hands of homebuilders and experimenters on a non-certified,
use-at-your-own-risk basis to gain operational experience, while they
continued to work on JAR and FAA certification. After all, look at the
junk ultralight builders have been strapping to their machines for
years. A Zoche pre-production engine would probably be as good or better.
Andrew P.
[Post replies to this message on forum only]
Old May 12th 05, 08:43 PM
Sport Pilot
You have most of it right. Some things you have wrong,
1. Desiel injection timing is differant than on an Otto engine. The
fuel is injected during the intake cycle on the Otto engine and the
fuel is injected during the ignition cycle on the Desiel. On the
Desiel the fuel injection cycle starts just before TDC and ends well
after TDC. The fuel ignites as soon as it hits the hot air.
2. The parts count is not less on a two stroke Desiel, It is higher
because of the need for a supercharger and a way to port the exhaust.
I don't think you would want a four stroke Desiel in an aircraft
because of the increased weight and low power. Desiel engines don't
really produce more torque as a gas engine, its just that the fuel
burns slower and thus the engine cannot rev as fast, but it can produce
the same or slightly more torque at lower speeds, and at much lower
fuel flow rates. Because of this they should be ideal for an aircraft
engine that doesn't need to turn at a higher speed.
You do lose one advantage of the Desiel engine on an aircraft. Because
of the lack of a throttle and the fact that they can burn extreamly
lean at idle, Desiel engines are extremely efficient in stop and go
traffic. But we don't idle aircraft engines that much.
Old May 13th 05, 12:06 AM
Andrew P.
Wandering aimlessly about the Web, I heard Sport Pilot say:
etc., etc. --- SNIP ---
It's Diesel, not "Desiel".
Andrew P.
Old May 13th 05, 03:52 PM
MJC
"Andrew P." wrote in message
ink.net...
Andrew P.
Well if you're going to get picky, it's "Auto" engine, not "Otto" engine.
MJC
Old May 13th 05, 04:06 PM
N8N
ink.net...
The
well
Andrew P.
engine.
MJC
Actually, it is Otto, as in 4-stroke spark ignition.
nate
Old May 13th 05, 04:47 PM
Don Stauffer
N8N wrote:
hlink.net...
The
well
Andrew P.
engine.
MJC
nate
A 4-stroke diesel is still an Otto engine. An Otto cycle engine is one
with four strokes, intake, compression, power, and exhaust. Doesn't
care whether SI or CI.
Old May 15th 05, 04:23 PM
wingsnaprop
Dude, MJC was Joking
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 01:39 AM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 03:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 05:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 01:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 01:44 AM
