2NO wrote: When I then modify the points to exactly match what SeeYou reports, the distance becomes correct, but the 4th, 5th, and finish points are no longer labeled in green, and the following error messages are reported: "The finish time is after the end of the flight without propulsion. This is not allowed. Please adjust the finish time or the time of the end of the flight without propulsion. Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time. " ... which makes no sense at all. It might be that the times (take-off, departure, finish) are off by one hour. If the altitude reported at the finish time is too high or the position is not what it should be then try to advance the finish time. Harri |
A correction to my most recent post. I had wrong "End of flight without
propulsion" time entered. With the correct launch/soar/finish/land times, these are the error messages I get: "Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time." It's that last one that's frustrating me. I have verified multiple times that there is in fact a fix in the IGC file with exactly the finish time... -ted/2NO |
2NO wrote:
I get: "Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time." I have exactly the same problem (Cambridge Model 10). I have reviewed the raw file and confirmed that there are indeed B record fixes in the file corresponding to the fixes that OLC is showing as no good. I have verified multiple times that there is in fact a fix in the IGC file with exactly the finish time... Ditto. I have tried - CAI file direct to See-You 2.85. I have tried CAI file + conv-cam to create new IGC file then the OLC utility cai2igc to append the G records to the new IGC file & several variations thereon. All equally hopeless and resulting in the same errors as you have. I have wasted hours on this and I'm giving up unless someone has the process down. |
wrote: 2NO wrote: I get: "Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time." I have exactly the same problem (Cambridge Model 10). I have reviewed the raw file and confirmed that there are indeed B record fixes in the file corresponding to the fixes that OLC is showing as no good. I have verified multiple times that there is in fact a fix in the IGC file with exactly the finish time... Ditto. I have tried - CAI file direct to See-You 2.85. I have tried CAI file + conv-cam to create new IGC file then the OLC utility cai2igc to append the G records to the new IGC file & several variations thereon. All equally hopeless and resulting in the same errors as you have. I have wasted hours on this and I'm giving up unless someone has the process down. I had a very similar problem last year. With the help of the OLC team, it was determined that the file transfer to OLC was incomplete, so many B records were missing on the file on their system. I tried to upload the file again and was rebuffed with the message "Flight File already in OLC" or some such ... it wouldn't replace the partial file with a new copy. Again, the OLC team provided a trick that allowed me to eventually be successful. The trick is to change the name of the .igc file to be uploaded by bumping up the flight sequence number for the flight date. That's the digit in the eighth character position in the file name. Example: change ymdCxxx1.igc to ymdCxxx2.igc OLC treats the new file as if it is a new file for a new claim, giving a new shot at getting the complete file uploaded. |
Bob,
That was one of the first things I tried, but got the same results. Still stuck, and have just a few hours left ... ted/2NO |
Tuno,
I was just looking at a flight one of your ASA buddies (YB - yellow belly?) made on Saturday. Noticed it was truncated on the OLC display while they were still several thousand feet in the air. Downloaded the *.igc file, and the rest of the flight was there in the B records, all the way to landing. SeeYou could show the whole flight and came up with a much longer distance. I don't have a way to check the appended *.cai file, but it could be truncated on the server. I have had an incomplete upload of a file in the past, without any understandable error message, or obvious way to recover. That would explain the security failure reported. Could also be because the B records in the igc file were edited. Don't know what the OLC server does when it finds B records that don't match whats in the appended *.CAI file. It could stop processing the log right there. Tweaking the B records in the file is a no-no and will cause a security failure with these secure log files. Either might explain your error messages. You could try re-uploading as mentioned earlier in this thread with a modified file name. -Dave Leonard ZL Bob S wrote: wrote: 2NO wrote: I get: "Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time." I have exactly the same problem (Cambridge Model 10). I have reviewed the raw file and confirmed that there are indeed B record fixes in the file corresponding to the fixes that OLC is showing as no good. I have verified multiple times that there is in fact a fix in the IGC file with exactly the finish time... Ditto. I have tried - CAI file direct to See-You 2.85. I have tried CAI file + conv-cam to create new IGC file then the OLC utility cai2igc to append the G records to the new IGC file & several variations thereon. All equally hopeless and resulting in the same errors as you have. I have wasted hours on this and I'm giving up unless someone has the process down. I had a very similar problem last year. With the help of the OLC team, it was determined that the file transfer to OLC was incomplete, so many B records were missing on the file on their system. I tried to upload the file again and was rebuffed with the message "Flight File already in OLC" or some such ... it wouldn't replace the partial file with a new copy. Again, the OLC team provided a trick that allowed me to eventually be successful. The trick is to change the name of the .igc file to be uploaded by bumping up the flight sequence number for the flight date. That's the digit in the eighth character position in the file name. Example: change ymdCxxx1.igc to ymdCxxx2.igc OLC treats the new file as if it is a new file for a new claim, giving a new shot at getting the complete file uploaded. |
Thanks Dave. Where did you find YB's flight to download?! And which one
did you find? I've uploaded four versions and can't find them anywhere (have never got to the page with the "Claim Flight" button). Hack hack hack -ted/2NO |
I just tried again with a log file from YB's SN10, but I now get this
error message: "The flight can not be scored, because it is outside the claim time window. The flight is in the BHC claim window. It may be possible to claim it there." I thought we had until midnight local time Tuesday for uploads? *Sigh* time for a beer. -eltedro/2NO |
David Leonard wrote:
Tuno, I was just looking at a flight one of your ASA buddies (YB - yellow belly?) made on Saturday. Noticed it was truncated on the OLC display while they were still several thousand feet in the air. Downloaded the *.igc file, and the rest of the flight was there in the B records, all the way to landing. SeeYou could show the whole flight and came up with a much longer distance. I don't have a way to check the appended *.cai file, but it could be truncated on the server. I have had an incomplete upload of a file in the past, without any understandable error message, or obvious way to recover. Can't you just edit the flight, and hit Remove Flight to recover from this? |
| New File Library Email Service | Tom Allensworth | Simulators | 2 | July 19th 04 11:33 PM |
| Lifeguard flights: How to file a flight plan? | Peter R. | Piloting | 14 | April 8th 04 06:40 AM |
| Where is Pilot log file in FS2004? | [email protected] | Simulators | 2 | December 2nd 03 12:56 AM |
| gpligc map file | Mike Stramba | Soaring | 0 | October 3rd 03 09:20 PM |
