Electric motor assisted super- or turbocharger?
Old May 8th 05, 05:13 PM
Max Kallio
Default Electric motor assisted super- or turbocharger?
2-stroke diesels need compressed air for starting the engine, so the
turbo (exhaust driven centrifugal supercharger) is out of a guestion
and it produces very little boost at low rpm anyhow.
How about supplementing a centrifugal turbocharger with a high speed
electric motor to create boost needed for starting and to enhance
boost at low rpm?
This would pretty much eliminate the turbo lag and actually help suck
the exhaust out of the cylinder at low rpm.
When the rpm rises, the electric motor could disengage or perhaps even
work as an auxilary generator.
Also, if the turbo has some problems, the electric motor could be used
at full power to help the turbo to spin and create boost at least for
the time it takes to land safely. Of course, the engine should be
able to have enough power to stay airborne at least at low altitudes
(if the load is not exeeded) even when the turbo fails completely.
Links...
www.turbodyne.com
Old May 8th 05, 05:34 PM
Don Stauffer
Why not just have a small compressed air pump driven by gears from
crankshaft or camshaft, with a tank to store a few "starts" full of
compressed air? Seems like an easier fix than an electric driven
compressor.
boost at low rpm?
Links...
www.turbodyne.com
Old May 8th 05, 11:17 PM
"Max Kallio" wrote in message
om...
Unfortunately, I avoided the opportunity to learn about these engines. My
father ran some
3 cylinder 2 stroke diesels in earth moving equipment some years ago and was
very happy with them. I believe they were turbocharged, but am not certain.
They may have started with a pony engine but again am not certain.
Can you fill me in on the details?
Old May 8th 05, 11:51 PM
Pete Schaefer
The DeltaHawk uses both an electrically driven supercharger for starting and
low-rpm operation, plus a turbocharger for the usual stuff.
om...
boost at low rpm?
Old May 9th 05, 12:17 AM
On Sun, 08 May 2005 11:34:05 -0500, Don Stauffer
compressor.
And just how much air do you think it would take? If you have a 164 cu
inch engine (2.7 liters) you need 2.7 liters of air at above
atmospheric pressure fore each turn of the engine(2 stroke) for long
enough to get the engine producing enough exhaust heat to spin the
turbo enough to produce boost. Say 5 liters (at atmospheric) per turn
for 45 seconds of running at 1000 RPM - or 2500X5 liters = 12500
liters of compressed air.
boost at low rpm?
Links...
www.turbodyne.com
Old May 9th 05, 12:18 AM
. com...
father ran some
Jimmy 371 - supercharged but not likely turboed.
Old May 9th 05, 12:45 AM
Heywood
Nope, the Deltahawk uses a traditional Roots belt-driven blower for
starting and low-rpm operation.
Old May 9th 05, 01:54 AM
Bill Daniels
This actually makes sense. Electric motors have become much more powerful
for their weight. In the case of a two stroke diesel, electric boost would
only be used to get the engine running on the turbocharger. Thereafter,
it's unlikely to be needed except for an emergency air-start. Since the
power of the exhaust turbine exceeds what is needed for the compressor at
cruise power, the electric motor could become a generator. This rig is
likely to be simpler and lighter than a blower/turbocharger in series.
Bill Daniels
om...
boost at low rpm?
Links...
www.turbodyne.com
Old May 9th 05, 02:14 AM
Matt Whiting
Why do two-stroke airplane diesels need compressed air for starting?
The Detriot two-stroke diesels used in trucks and off-road equipment
have never needed that.
Matt
Old May 9th 05, 04:21 AM
Pete Schaefer
Yup, yer right. Just checked. Must be confusing the DH with another engine.
"Heywood" wrote in message
Desktop Wallpaper - "F/A-18F Super Hornet Sunset". T. & D. Gregor, Sr. Naval Aviation 0 December 1st 04 01:08 PM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 02:43 AM
Piper Arrow electric fuel-pump MC General Aviation 7 June 3rd 04 02:50 AM
Gyros - Electric vs Vacuum? Bill Denton Piloting 1 April 18th 04 05:56 AM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
